Intergraph TDZ 2000 mainboard post code 2F/2E
  • Sorrow1
    • Mar 2023
    • 4
    • CZ
    I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
    It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
    When I recorded video of POST card and played it in slow motion, the sequence of post codes is: E0/E8, 88/E6, 0C/0E, 80/0E, 28/17, 3A/28, 2A/3A, 2E/2E and finally 2F/2E.​
    The POST code table says that code 2F means: "Enable cache before system BIOS shadow". However, as I tested both CPUs in another machines AND the cache is located on the CPU cards, I wonder what the given post code indicates. Any other ideas?
    Jan
  • Sorrow1
    • Mar 2023
    • 4
    • CZ
    It seems to be a problem with memory slots or lines. It POSTed after I swapped the CPUs (those already plugged in). But some combinations of memory modules still do not work.
      LCD LED TV Service Menu Codes
      ALL LCD LED TV SERVICE MENU CODES
      Service Menu Code with Board Name
      China Universal Board / Jumper Board Service Menu Code
      Changhong Ruba Service Menu Code
      Ecostar LED TV Service Menu Code
      Orient LED TV Service Menu Code
      Haier LED TV Service Menu Code
      TCL LED TV Service Menu Code
      Samsung LED TV Service Menu Code
      LG LED TV Service Menu Code
      Videocon LED TV Service Menu Code
      Supra LED TV Service Menu Code
      Toshiba LED TV Service Menu Code
      Symphony LED TV Service Menu Code
      Veste/ LED TV Service Menu Code...
      10-31-2024, 03:58 AM
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • DynaxSC
      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
      by DynaxSC
      Hi Folks
      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
      09-29-2024, 04:27 PM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
