Intergraph TDZ 2000 mainboard post code 2F/2E
  • Sorrow1
    • Mar 2023
    • CZ
    I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
    It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
    When I recorded video of POST card and played it in slow motion, the sequence of post codes is: E0/E8, 88/E6, 0C/0E, 80/0E, 28/17, 3A/28, 2A/3A, 2E/2E and finally 2F/2E.​
    The POST code table says that code 2F means: "Enable cache before system BIOS shadow". However, as I tested both CPUs in another machines AND the cache is located on the CPU cards, I wonder what the given post code indicates. Any other ideas?
    Jan
  • Sorrow1
    • Mar 2023
    • CZ
    It seems to be a problem with memory slots or lines. It POSTed after I swapped the CPUs (those already plugged in). But some combinations of memory modules still do not work.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • DynaxSC
      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
      by DynaxSC
      Hi Folks
      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
      09-29-2024, 04:27 PM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
