T470 not starting - error code 0285
  • SmartSmurf
    • Jul 2023
    • 5
    My good old T470 out of sudden hung while starting up, unable to power off while pressing the power switch for a minute or so. After 10 minutes I removed the battery.
    Now the BIOS plays the 0285 sound (decoded with diagnosis app).
    The BIOS was not protected by user nor supervisor password.
    I have no flash dump, but I am experienced to dump it. Is it worthwhile? I read that this error can be solved my deleting the ME part of the BIOS.
    Any advise?
  • mon2
    • 14662
    Re: T470 not starting - error code 0285
    Same message here:
    https://www.reddit.com/r/thinkpad/co...mment/fne01na/
    • SmartSmurf
      • Jul 2023
      • 5
      Yes, this is exactly the symptoms I am encountering, too.
      I plugged off all power sources, disassembled the device and removed the CMOS battery. I let it drain overnight, turned on today - but error is persistent.
      • SmartSmurf
        • Jul 2023
        • 5
        Just for the records - and in case anyone else runs into the same issue:
        I dumped the U49 chip, verified it contains the string "20JN" (which matches my device) and then flashed this BIOS
        https://www.badcaps.net/forum/showpo...8&postcount=13
        Everything looks good now.
        • mon2
          • 14662
          So the original bios was corrupted? Interesting. Thanks for the resolution. Very much appreciated.
          • SmartSmurf
            • Jul 2023
            • 5
            It looks so, yes. I am running a Grub based dual-boot between Ubuntu and Win10.
            The system was working for long time like this, but some days ago it was stuck on booting *before* Grub showed the menu. So it seems to had been corrupted by itself and/or one of the other OSes. No FW update was involved.
            • kicker12
              T470 and 0285 error
              by kicker12
              Hi everyone!
              I have a T470 which makes beeps at the startup and they lead to 0285 error (TCG-compliant functionality-related error (might be the TPM initialization failure)).
              I have read a bit around and looks I may try to upload a new/modified BIOS: I am attaching the dump of the original one (defective).
              Anyone can point me to the right direction on how to move next???
              Type: 20JN-S5UV00
              Serial: PF-1J98FY...
              03-13-2025, 02:23 PM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              08-26-2025, 04:42 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • Maalobs
              Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
              by Maalobs
              I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
              The relevant service manual for the chassis is available here.
              The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
              When I short the SDM to ground I get the layer-2 error code 53.
              The inside of the TV has no damaged components and no swollen capacitors.
              In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
              04-02-2019, 01:15 PM
            • fredyjbi
              please help friends thinkpad T470 error post "bottom cover tamper detection error"
              by fredyjbi
              please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
              I've already
              flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
              06-15-2024, 09:56 AM
