Sharp LC-32D44E-BK possible lamp error???
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Hi, I have a Sharp LC-32D44E-BK that when switched on, the standy light turns green for 5 seconds, then turns red.
    Nothing else happens, no backlights etc.
    A quick search seems to suggest this is a safety feature relating to a lamp error, and there is some way to reset it and test it??
    I have never looked at an LCD with a CCFL before, so dont know where to start, so any advice greatly appreciated.
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: Sharp LC-32D44E-BK possible lamp error???
    Probably a bad CCFL or a bad CCFL connection. If still met with a failure after correctly reconnecting CCFLs that are not faulty, then it's time to check the inverter board!
    Also a click to a solid red light, can mean a short. IIRC, I had tiny water droplets cause my 1995 Fisher (Sanyo) TAD 5024 stereo to have that issue.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Also a click to a solid red light, can mean a short. IIRC, I had tiny water droplets cause my 1995 Fisher TAD 5024 stereo to have that issue.
      How would I go about checking/reconnecting CCFLs? Ive never had anything to do with these type of TVs at all.
      It describes my problem in the image of the manual below, but dont see how I can reset anything without being able to see anyhing on the screen, dont know if im missing some sort of trick with these things lol
        I would expect the backlights to come on for seconds at least before it goes into shutdown protection if it detects bad lamp/circuits, it will only take one bad lamp to cause the protection shutdown.
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          After a quick google search, I read something about holding VOL- and Input, and I did, and screen came on, but went off when I released it, people mention something about getting into some reset menu to delete something to reset the lamps so Im studying the manual atm
            That is for the lamp error counter reset and you are able to get the backlights to come on for seconds.
            So a this point, it can be bad lamp, bad lamp connection, bad inverter transfomer, etc. so more idepth troubleshooting required.
            You can do easy test such as checking the resistance of the high Voltage winding of each inverter transformers, they should be within 3% from each other.
            • Bloopeta
              • Jun 2018
              • 526
              • United Kingdom
              Yes, by holding VOL- and Input the TV came on as you say, backlights came on for few seconds, and went off, and TV is staying on with green light now.
              • Bloopeta
                • Jun 2018
                • 526
                • United Kingdom
                Just an update, found an old thread on here from 2013, with a link to a very useful video from tom66
                https://m.youtube.com/watch?v=5wUuARpFe90
                Tv is now functioning properly, thankyou to everyone who posted
                  That is not a fix, it bypass the protection circuit and stop it from shutting down, be real careful.
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    I understand what you mean but I removed the bypass once id managed to reset the lamp errors in the service menu, and so far its still working, so ill see how it goes.
                      Good, most people will leave the bypass in place. The circuit must have detected error enough to fill up the counter, so keep an eye on it.
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        I will do, thankyou for the advice
                        • Eric D.
                          Sharp LC-60LE810UN Lamp error
                          by Eric D.
                          Hello everyone!
                          I just acquired a Sharp Aquos for free.
                          When I plug it in, it will try to power on, but it fails.
                          The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
                          I did a bit of research and did what I found could be the possible issues;
                          I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
                          I also tested the leads going into the psu board from the wall connector; I get 120V.
                          I disconnected...
                          01-18-2025, 05:14 PM
                        • Yanleb
                          Sharp LC-60LE810UN Lamp Error
                          by Yanleb
                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                          I've tried all the key...
                          08-24-2021, 11:48 PM
                        • mikey5791
                          Help on Samsung Syncmaster T220 dead ccfl lamp
                          by mikey5791
                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                          10-18-2020, 03:17 AM
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          The TV does not turn on, the standby indicator is on. All voltages are present.
                          Emms is dead. Not readable, not detected.
                          Replaced emmc.
                          But with another dump there is no launch
                          Terminal log
                          UART
                          AC_ON
                          RPMB key is not yet programmed
                          HASH1_VERSION=0x00000000 64bit
                          E-B
                          FDE enabled
                          layout pattern onebin by SAR7,0...
                          06-01-2025, 02:11 AM
                        • michalk3777@gmail.com
                          Sharp Hisense - LC-65N7004U Error codes
                          by michalk3777@gmail.com
                          Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                          Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                          Regards,...
                          12-15-2024, 09:20 PM
