Vizio E370VA wont turn on
  • nbnb
    • Nov 2019
    • 13
    • usa
    I have a Vizio E370VA that won't turn on. It was working fine until I didn't use it for several weeks. When I press the power button, the Vizio logo below the screen gets bright for about 1 second and then dims. The screen remains blank and the Vizio screen logo never displays.
    I have tried unplugging the set, holding the power button for 30 seconds, and then powering it up. That didn't help.
    I pulled the back off and measured 3.66 volts on the standby port labeled 5V. I disconnected the main board from the power board and then the 5V port read 5.25 volts. Does this indicate that the power board is bad? Or, does this indicate that the power board is operating correctly and that the main board may be bad?
    Any ideas on how to fix this?
  • R_J
    • 9517
    Re: Vizio E370VA wont turn on
    Did the standby voltage change when you turned the tv ON? Also check if you have the PS_ON voltage when the power buttonis pressed. The +5v could be low (3.6v) in standby but would increase when the PS_ON is high. If the voltage stays low, check C952, C954, C958 and C960
    • nbnb
      • Nov 2019
      • 13
      • usa
      Thanks for your reply. PS_ON voltage is 3.60 volts when the TV is off. When I turned the TV on, PS_ON voltage went to 0 volts and the standby voltage went to 5.16 volts. Also, the 24 volt pins measure 24.6 when off and 0 volts when the tv is on. The 12 volt pins measure 12 volts when off and 0 volts when on.
      Is the PS_ON voltage supposed to go to 0? What else can I check to narrow down the problem?
      • R_J
        • 9517
        I think you have the voltages backwards, When the tv is ON The PS-ON voltage will high (3.6v) . When the TV is OFF the +12 & +24v will be 0. When they are at +12 & +24V the tv is ON.
        Post some pictures of the complete rear of the tv so we can see what we are dealing with. You may have a backlight issue. Try shining a flashlight at the screen and press the menu button to see if you can see anything on the screen. You could also try connecting a HDMI source and see if the tv goues to that input and gives you sound etc.
        • nbnb
          • Nov 2019
          • 13
          • usa
          I plugged it in (so the TV should be off) and get the following voltages:
          3.60 (5v)
          3.60 (ps/on)
          24.6 (24v)
          12 (12v)
          When plugged in, the vizio bezel logo glows dimly.
          Pressing the power button, the bezel logo gets bright for about a second before dimming. I get the following voltages:
          5.16 (5V)
          0 (ps/on)
          0 (24V)
          0 (12V).
          If I press the power button again, the bezel logo darkens and then returns to a dim state.
          I don't see anything when using a flashlight to illuminate the screen. I don't get any sound. I never see the screen startup logo. It's as if the TV is not turning on.
          Several pictures are attached.
            "3.60 (5v)
            0 (ps/on) This cannot be 0V and still having switched 12V and 24v to be on.
            24.6 (24v)
            12 (12v)"
            • nbnb
              • Nov 2019
              • 13
              • usa
              Thanks, and sorry. You are right. I had the correct voltage in post #3 for when the TV is off. I edited my post to note that it is 3.6 volts.
              Originally posted by budm
              "3.60 (5v)
              24.6 (24v)
              12 (12v)"
              • R_J
                • 9517
                If you look at the inverter board (small board on the right in pic#1) , there is a small led (LED1)that should light for a few seconds then fade out when the tv is first turned on. If this does not happen, When there is +24 volts at the inverter, check the voltage on both sies of the fuse (F1) and also check the voltages on pins 14,13 & 12.
                Pin 12 is the inverter on/off
                • nbnb
                  • Nov 2019
                  • 13
                  • usa
                  The LED1 does not light up at all. When I have 24.6 volts on PIN 1 of the inverter, the F1 fuse measured 24.7 volts on both sides of the fuse. Pin 14 was 0.28V, pin 13 was 2.46V, pin 12 was 0.09V, and pin 11 was 0.10V.
                  I attached some pictures of the inverter board with the cover off.
                    https://www.badcaps.net/forum/attach...0&d=1573102972
                    pin 13 (Dimmer control) was 2.46V,
                    pin 12 (BL-ON) was 0.09V
                    You do not have BL-ON to turn on backlights circuits.
                    • nbnb
                      • Nov 2019
                      • 13
                      • usa
                      Does that mean the inverter board is bad and should be replaced?
                        PS-ON, BL-ON, DIM signals are from the main board.
                        You can try forcing on the inverter board by disconnecting the BL-ON wire from the inverter board connector then use 1K resistor between the BL-ON pin of the Inverter board and the Standby 5V pin to force on the inverter board.
                        You should read Basic LCD TV and monitor troubleshooting guide.
                          BTW, I do not know which main board you have, but shopjiimy is EEPROM for this TV model, see the description of what the EEPROM will fix.
                          https://www.shopjimmy.com/catalogsea...q=Vizio+E370VA
                          • nbnb
                            • Nov 2019
                            • 13
                            • usa
                            • R_J
                              • 9517
                              If ypou want to check the power supply and inverter/backlights. disconnect the cable from the power supply going to the main board. Then connect about a 1K resistor between the +5V (pin 12 or 11) and pin1 (ON/OFF) then place another 1K resistor between +5V and pin10 (or you can short between pins 10&11) Then plug in the tv. this should turn on the power supply and the backlight (there will not be a picture)
                              You may also need a third 1K resistor between +5 and pin2 (DIM) if the backlights don't turn on
                              • nbnb
                                • Nov 2019
                                • 13
                                • usa
                                If I do this, and the backlight turns on, does it indicate that the power supply and inverter/backlights are good and that the problem is with the main board? Or, could the problem still be with the power supply?
                                • R_J
                                  • 9517
                                  Yes, that test would turn on the power supply, the inverter and the backlights. That would indicate the main board is at fault and could point to a corrupt eeprom.
                                  If you have a can of freeze spray or an inverted can of canned air, you can try this to see if the eeprom may or may not be the issue:
                                  Unplug the tv, freeze the eeprom ic, wait 10~15 seconds, plug in the tv and see if turns on.
                                  If this test does work the fault is with the eeprom ic and the rest of the main board is likely ok. If this does'nt work you could still have a faulty eeprom
                                  Being a Vizio and this model I would highly suspect a corrupt eeprom ic
                                  • nbnb
                                    • Nov 2019
                                    • 13
                                    • usa
                                    Thank you.
                                    • Mulp
                                      VIZIO M65-C1 Does Not Turn On
                                      by Mulp
                                      Hi All,
                                      I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                      When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                      I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                      01-13-2024, 09:57 PM
                                    • EazyBone
                                      Vizio V705-H3 Won't power up
                                      by EazyBone
                                      This TV has the white light on the front. When you click the power button or hit the remote nothing happens the lights stays solid. I checked the main board for the voltage for that signal and everything is fine.
                                      The power supply is giving 13 volts and 2.7 on AC detection. Zero on PSOn and nothing changes when hitting power. The led lines show zero and those caps won't turn on
                                      ​​​​​​ it seems the PSU won't turn on to supply voltage to LEDs. The main caps sit at 170v.
                                      It's odd to me the led lines go from PSU to main board and THEN to LEDs.. as a note....
                                      03-01-2025, 01:34 PM
                                    • pajdek
                                      Lenovo Y700-17ISK turn on and off
                                      by pajdek
                                      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                      09-20-2023, 02:49 AM
                                    • triplefour
                                      TCL 75S421 has sound but no backlight not even a flash
                                      by triplefour
                                      TCL 75S421
                                      PSU BOARD: 40-L402H8-PWD1CG
                                      it shows not even a flash of backlight when powering up.
                                      but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                      testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                      unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                      i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                      with mb connected, PSON...
                                      11-17-2023, 09:54 PM
