Sony 46EX400 dim picture
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Just picked this tv up for free. I haven't opened it up yet to take pictures as everything seems to work except the picture is dim.
    I've never worked on an lcd before.
    Does this mean that one of the bulbs is out?
    If so, can they be replaced?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony 46EX400 dim picture
    It looks as either the lower tubes are not lighting at full brighness (aged) or there is an issue with the inverter.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Thanks.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Ok, I got the tv working but now another issue has cropped up.
        When I try to turn it on, the front led changes from red to green as it should but nothing comes up on the screen.
        If I unplug the IR board, the tv functions as it should by using the side buttons.
        I can even plug the IR board in while it’s on and use the remote but if I turn the tv off, it won’t turn on again until I unplug the IR board.
        Does that suggest a faulty main board or faulty IR board.
        I can order an Ir board for under $10.
          • 12206
          • U.S.
          Could be bad cap/s on ir board.
            I can even plug the IR board in while it's on and use the remote but if I turn the tv off, it won't turn on again until I unplug the IR board.
            So what did you do to get the TV working as far as the Dim picture is concerned?
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              Ummm, hooked up the cable and scanned for channels.
                Hmm, I dot see the relationship between the dimming pictures issue and the TV cable/scanning. So if you only use DVD or BluRay the pictures were not dim?
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  I’m not exactly sure what the problem was bud. I picked the tv up as not working. Didn’t ask any details because it was free and left on the porch for me.
                  Brought it home, plugged it in and saw the dim picture and figured that was the issue, bad cfl’s.
                  After taking the pics and posting, I tried to actually set it up and the picture was fine. Hooked it up to my cable and scanned for channels and it seemed fine.
                  So I’m guessing the not working part was actually the IR sensor or the main board because last night it wouldn’t turn on, neither by remote or side buttons.
                  The front led would change from red to green but nothing on the screen at all.
                  So today I opened it up. Tried some things, one of them being disconnecting the Ir sensor board from the main board.
                  At that point, I could turn the tv on and off, do everything by the side panel.
                  While on, I plugged the Ir board back in and could use the remote. If I turned the tv off, it wouldn’t turn on again unless I unplugged the Ir board.
                  I ordered one from eBay for $10, it comes with a 60 free return
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    Just took this pic.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      Replacement IR sensor board fixed it.
                      • CapLeaker
                        Leaking Member
                        • 8179
                        If it’s not too late, could you post a pic of that IR board?
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          Here you go.
                          • CapLeaker
                            Leaking Member
                            • 8179
                            Funny, ther is nothing much on it. Is a cap shorted?
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Didn’t bother even trying to check. The whole board is tiny. I would not even want to replace one of those tiny smds.
                              For $10 it’s just easier replacing it.
                              • CyberPhoenix
                                Issue with picture quality of Sony bravia TV
                                by CyberPhoenix
                                Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                01-22-2024, 02:08 AM
                              • noisykid
                                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                by noisykid
                                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                12-30-2024, 07:15 PM
                              • tree5656
                                diagnosing sony XBR-75X900H. NO PICTURE
                                by tree5656
                                This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                11-09-2023, 04:55 PM
                              • DKWS89
                                Sony XBR 49x900E - Sound and backlight on but no picture
                                by DKWS89
                                Hey Guys,
                                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                12-14-2023, 04:30 PM
                              • ronni
                                Sony KD-43XE8005 with sound, backlight, no picture
                                by ronni
                                I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                Removing the LVDS cable results in...
                                12-01-2022, 08:44 AM
