Bad driver(s)? Sharp LED TV
  • scuby
    • Jan 2014
    • 33
    • netherlands
    So I recently fixed my first main board, I should say diagnosed and replaced, to get a 50" Sharp up and running again.
    I've got my eye on another one that's acting up. I haven't gotten my hands on it yet. It's a gamble. But for a 5 year old tv that has seen little use at 70 inches I'm intrigued. I'm pretty sure these things divide the screen up into four sections on the LED driver side, is that right? I had 4 24v out's on the 50" and it's a similar model. Just a wild guess
    It powers up fine, so for now that rules out power board issues, but only gives about a quarter of the screen and it's blue. Nothing else.
    Could this be a driver issue? Happened one day to the next. No falls or anything like that, just boom: it's like this, see attachment.
    It's not a lot to go on but any ideas? input? what to look for?
    I can pull the back off and get relatively far with my DMM but untill then I'm looking to get as much info as possible on probable problems. A lot of p's there...
  • scuby
    • Jan 2014
    • 33
    • netherlands
    Re: Bad driver(s)? Sharp LED TV
    at this point I have this TV
    The backlight lights up. It has sound. it shows no image whatsoever.
    The first few minutes it gave the blue screen as shown in the pictures above. Though it did stay on the left side size and shape changed a little per power cycle. Once it filled the screen with a purplish hue, the entire screen, giving me some confidence that the LCD panel itself is ok.
    After a few cycles the screen remains blank. The backlight working and sound as well.
    Am I to suspect a faulty T-con board? or could it be the main board graphics processor?
    I suppose both. Neither have any visible issues with capacitors etc.
    A recent fix of a 50" Sharp LCD LED was the replacement of the main board. I was told a common error: that TV refused to boot up though.
    This one starts up. Just no picture.
    The European model designation is: LC-70LE835E
    The US model designation is: LC-70E735U
    • scuby
      • Jan 2014
      • 33
      • netherlands
      I just disconnected the Tcon ribbons carefully and I was able to get a full white clear screen on each half. The first time the left half was fully white and right half looked like it had been smashed! all kinds of lines and colours. Put it all back, fired the tv up: blank screen again.
      Pulled the ribbons again. This time the right half was fully white and the left half mostly grey.
      Is it safe to conclude the panel itself is ok?
      Bueller?
      • scuby
        • Jan 2014
        • 33
        • netherlands
        Here are some pics.
          • 12206
          • U.S.
          Can try cleaning your tcon ribbon cable ends, some use a pencil eraser, also make sure you have a good and clean connection at the lvds cable going from mainboard to tcon, could be a faulty tcon.
          • scuby
            • Jan 2014
            • 33
            • netherlands
            thanks. Can I rule out either mainboard or faulty panel? Is Tcon the most likely?
            • Diah
              • Feb 2013
              • 6397
              Bueller?
              did you got the white screen when you disconnected the ribbon with signal or with out ? you need with signal to see if half screen come out with picture... if you did it with signal then you have much likely issue on main boards
              • scuby
                • Jan 2014
                • 33
                • netherlands
                I disconnected them wihtout signal and with the power off.
                I should do this test with the set on and a signal playing?
                What am I looking for?
                  • 12206
                  • U.S.
                  Well I don't think you can rule out mainboard, tcon or panel yet, it can be tricky pinpointing a problem, probably why a lot of people start with throwing a replacement tcon at it if they can get one cheap enough, nice testing video here, he checks the power and mainboards over and Budm posted a tcon checking procedure the other day: https://www.youtube.com/watch?v=ocqnqmBxiqY
                    • 12206
                    • U.S.
                    The tcon training is post #29 there: https://www.badcaps.net/forum/showthread.php?t=76056
                    • scuby
                      • Jan 2014
                      • 33
                      • netherlands
                      cheers
                      some of might be a littel too finnicky for me. I'm a mechanic by trade and the fiddly stuff gets me under my skin
                      I'll have a good look day after next. Meanwhile I've orderd a Tcon for 22 euro's because, well honestly I'm hoping to throw a part at it and have that work.
                      I also need to pick up finer pointed probes for my dmm.
                      Is it worth mentioning that the television is not flashing any error codes? I'm not sure what kind of diagnostic this TV is capable of but perhaps worth noting...
                      Either way I'll give this all a read over again tomorrow. The Tcon trainng is on a Samsung. am I looking for similar if not identical voltages in and out on my Sharp? Where can I get that information if there are variations?
                        • 12206
                        • U.S.
                        Very good question, I don't know if they are all the same, I usually just throw a tcon at it, if cleaning cables don't work, unless it's something very obvious like a bad fuse or such. Not much patience for dealing with the real small components that might be involved.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Being a Sharp, check this thread:
                          https://www.badcaps.net/forum/showthread.php?t=48477
                          Series LC-XXLEs are the worst offenders!
                          (The XX, is the place holder for the 2 digits of the screen size, in inches.)
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • scuby
                            • Jan 2014
                            • 33
                            • netherlands
                            cheers.
                            The LE's are the wost offenders in what way? I'm reading a bunch of symptoms/solutions. Worst offenders in panel failure?
                            Seems so strange to me that the panels fail one moment to the next. I have no codes. I'm still not clear on the Tcon ribbon unplug test that proves a faulty panel (and why/how). Any insight?
                            Thanks for the help folks. Much apreceated.
                            • scuby
                              • Jan 2014
                              • 33
                              • netherlands
                              basically my train of thought too
                              • budwich
                                • Jul 2015
                                • 3097
                                you should still try doing the "cable removal test" again and feed in an input signal. Depending on the outcome, it will readily point you in a direction.
                                • scuby
                                  • Jan 2014
                                  • 33
                                  • netherlands
                                  Ok. I need a clear guide on that test. Could be me but I'm not reading a consistent methodology.
                                  Give it a signal: verified by audio
                                  Remove outer Tcon cable (I have four). That half should go white?
                                  Reconnect and remove opposite and that half should go white?
                                  Don't need to remove the inner cables?
                                  My backlight always comes on. I have no codes flashing.
                                  thanks
                                  • scuby
                                    • Jan 2014
                                    • 33
                                    • netherlands
                                    allright: here's wat I've done:
                                    I have 4 cable/ribbons running from the Tcon to the panel. My backlights always come on every time I power up the set. I have no codes flashing at any time.
                                    I have a source playing verified by it's audio.
                                    Unplug the right most cable/ribbon: corresponding half of screen lights up mostly white/grey but lot's of colored lines. See Pic 1
                                    Unplug the second cable from right: corresponding half of screen goes completely white. See Pic 3
                                    Same is true of the left. 1 cable results in a more colorful lighting up of the screen. Disconnect both it's all white. See pic 2, it goes fully white like pic 3 on the other side too.
                                    Disconnect all four and the set switches off.
                                    What can we conclude from this?
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      cheers.
                                      The LE's are the wost offenders in what way? Worst offenders in panel failure?
                                      Yes, they're the worst offenders of panel driver failures, if not also deep into the panel!
                                      Arc A770 16 GB
                                      • scuby
                                        • Jan 2014
                                        • 33
                                        • netherlands
                                        I followed this procedure to reset the set (even though I have no codes).
                                        Unplug set. Hold down Vol - & Input while plugging set back in, release. TV powers up and shows variations of the following image (see attachments). A partial blue screen. Which can hold, flash off for a second and back on. I can't get any menu or other image to show.
                                        After the reset I cannot see a "K" as suggested by some posts.
                                        Hope this helps narrow things down. I can get a Tcon locally quickly relatively cheaply. Is it worth it? Or has this panel suddenly and dramatically died? Astounding how many Sharp Tv's have issues out there!
                                        Please ignore the mess. I'm in the middle of a divorce and living in my office. The TV working would be a good thing come the holiday's lol
                                        thanks again.
                                        PS: with one side disconnected from the Tcon the white side will dimm after a few seconds as if saving power. Hitting the menu button or volume will trigger the screen to illuminate fully again. It seems to respond that much at least. It also does this when displaying the blue screen which varies in size when turned off and on again but is always on the same side.
                                        Hoping for input. Cheers
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Megan0
                                          Sharp LC-70UD1U Half screen Normal half screen is white
                                          by Megan0
                                          My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
                                          Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
                                          Result:
                                          I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
                                          Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
                                          Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
                                          Only in the first test, where I did not
                                          01-19-2022, 11:20 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
