LG 50uh5500 no picture
  • slip
    • Oct 2019
    • 27
    I'm sorry for making a second thread but it seems like my first one died. To recap, LEDs are working and t con has been replaced but still no picture. Power to the mainboard is on point. This is my first time repairing a TV like this and I'd love to know how to fully test and diagnose the issue accurately. Thank you. My multimeter and I are standing by.
  • nomoresonys
    • 12332
    • U.S.
    Re: LG 50uh5500 no picture
    New threads about same tv just clutters up the boards, all you need to do is bump your thread, that way what has been discussed and tried already is not lost, plus you probably won't get too many responses because it's a no no.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Your TV has bad Backlights. You would need to open up the Panel and carefully remove the very fragile glass screen. Replace ALL the Backlights strips though not all would be defective but it is good practice to replace all as you would not want repeated failure to have to open up the Panel innumerable times risking breaking the fragile glass Screen. The LED Strips would be in pairs and would have a Part No. for left and right pairs. A 50 inch TV like yours may have five pairs probably with 8LEDs on one side and 7 LEDs on the other. Good Luck.
      • neilc6
        • Nov 2015
        • 1550
        Previous thread said he replaced all the backlights and now has backlight but no picture and replaced tcon already. Probably damaged something in the process. Try powering on the tv with only one side of ribbons to the panel connected at a time. If one side has an image, then main board is good and there is damage to the panel.
        • slip
          • Oct 2019
          • 27
          Okay so when both ribbons are plugged in, there's no visual display it's just the back lights. When I plug them in one at a time, the display shows up each time but one connection has a clear image on half the screen and the other connection shows a distorted image on the screen with a lot of vertical lines.
          • slip
            • Oct 2019
            • 27
            Sorry about that, how should I correct it?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              can you upload a picture of what your seeing on the screen as we may of seen this fault before
              • nomoresonys
                • 12332
                • U.S.
                No biggie, it's just kind of like a step backwards because the 37 posts that were covered are missing from this thread if someone just types bump, then those posts are still right there easy to see.
                • slip
                  • Oct 2019
                  • 27
                  Update: after that ribbon test, somehow it turns on now. This is the most working I've ever seen this TV and it's really close to usable at this point. There is a horizontal line going all the way across the TV I'm not really too concerned about that unless there is a cheap and easy fix for it. It's only one single line and the rest of the image is there. The only current issue seems to be that the right side of the screen is distorted with what I would describe as an image burn issue. Everything on the right side of the screen is darker and the colors are a little bit distorted more towards the darker end of the spectrum and Frames don't disappear as quickly as they supposed to.
                  I have tried swapping ribbon cables and it was still the same issue and I also tried swapping the t-con boards and it actually worked but it's still the same issue.
                  • nomoresonys
                    • 12332
                    • U.S.
                    From description seems like a panel issue, could try the "cut tape" method, may have to adjust tape width, works quite often: https://www.youtube.com/watch?v=j7vl7-vZEL8
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • CyberPhoenix
                      Issue with picture quality of Sony bravia TV
                      by CyberPhoenix
                      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                      01-22-2024, 02:08 AM
