Blaupunkt 49/235z Backlight Inoperative
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Blaupunkt 49/235z, got this TV described as sound no picture, had a quick look, and backlights came on at first, but the LED inverter was buzzing very loudly, left TV on and after around 20 mins the backlights went out. Turning TV off and back on would bring them back on for a while but always went off sooner or later.
    I stripped the TV right down, tested the LED strips, both as strips and single LEDs and all of them illuminate with tester.
    I took readings from PCB for LEDS, which were
    LED+ 231v (when backlights were illumiated)
    LED+ 132v (times when LEDs had gone off)
    As mentioned when LEDs where illuminated, the inverter was very noisy and loud, when the LEDs wont come on, this is silent.
    Other readings from PCB are -
    +12v 12.40v
    SGND
    +5v 5.21v
    +5vSB 5.22v
    PSON 4.38v
    SGND
    +12v 12.40v
    BK 5.19v
    ADJ 4.66v
    SGND
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Re: Blaupunkt 49/235z Backlight Inoperative
    Am I looking at a PCB? As they are very cheap for a replacement, wouldnt be worth repairing the board at all.
      Did you try lowing the backligts level down as low as possible to see if the backlights will stay on longer (if you are able to keep it on long enough to get to the settings)?
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Yes put them on low as possible, it did stay on for a good while at first, but lat time I tried wouldnt come on at all
        • CapLeaker
          Leaking Member
          • 8178
          Bad backlight leds...
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Even though Ive tested them all??
              How much drive current did you test them at? 200 ~ 300 mA?
              • Bloopeta
                • Jun 2018
                • 526
                • United Kingdom
                Tested them with LED tester as previously advised on here. as in, they all lit up.
                Is there another way to determine which, if any are faulty please?
                • Bloopeta
                  • Jun 2018
                  • 526
                  • United Kingdom
                  Anyone?? When I turn on TV they all illuminate, but then all go off after a while, if I illuminate the LEDs as strips or singular, they all seem to work.
                  If I turn TV off and back on, they illuminate again
                  What can I do to find out which ones are at fault??
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    As already said by others it looks like a led problem. Led testers don't test the leds at full current which is why led testers can operate the led strings. Post #8
                    • Bloopeta
                      • Jun 2018
                      • 526
                      • United Kingdom
                      Thanks for the reply, so is there a way I can test and determine which LEDs are at fault please?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        If you don't have a current limiting power supply you can use a pair of AA batteries as in this thread https://www.badcaps.net/forum/showth...ght=AA+battery
                        • Bloopeta
                          • Jun 2018
                          • 526
                          • United Kingdom
                          I will give that a shot and let you know the results.
                          At present Ive had them running as normal for 25 mins and they havnt gone out as yet, so just waiting to see how long it will take for it to go off again
                            What is the DC Voltage when you measure it between the two wires of the LED connector (Connector still in place)?
                            • Bloopeta
                              • Jun 2018
                              • 526
                              • United Kingdom
                              At present, whilst all LEDs are illuminated, 229v
                              • Bloopeta
                                • Jun 2018
                                • 526
                                • United Kingdom
                                Ran for 58 minutes before went off, once off is putting out 138v.
                                Turned off and back on again, and ran for less than a minute before they went out.
                                Turned off and back on again, all still illuminating, but goes off pretty much straight away, now when try to turn on and off they just flash on for a milisecond and go straight off
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  • United Kingdom
                                  Have now tried, with a pair of AA batteries, all LEDs illuminate, and im now partially blind lol
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    possibly something heat related but what? is a new power supply cheap? maybe worth ruling it out you could always resell the board on ebay etc and get your money back if it does not fix the issue
                                    • Bloopeta
                                      • Jun 2018
                                      • 526
                                      • United Kingdom
                                      Ive actually swapped out the PSB this morning as I picked one up for pennies, just to rule it out, no change
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        sounds like a led issue then maybe a led failing when hot if thats possible, are all the led strips the same number if so maybe buy one strip and swap each strip in turn?
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • THE GTC
                                          Insignia NS-37D20SNA14 intermittent LEDs
                                          by THE GTC
                                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                          11-03-2020, 02:40 AM
                                        • VitalComputing
                                          Replacing Mode Indicator LEDs
                                          by VitalComputing
                                          I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                          I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                          I thought I could just put a resistor...
                                          09-17-2023, 04:43 PM
                                        • jimbofz
                                          just a quick question do all qled leds appear blue when fault finding ?
                                          by jimbofz
                                          i have replaced many leds strips that have changed blue when they are worn
                                          and the new replacements are perfect white
                                          but when fault finding do quantum leds always look blue?
                                          08-28-2024, 06:51 AM
                                        • Quantum IC
                                          LEDs for TV Backligth
                                          by Quantum IC
                                          Hello everyone
                                          I'm new to LED strip LED replacement.
                                          The original LED comes with a single internal LED or chip. I only get at the moment LEDs with two internal LEDs or chips.
                                          I understand that this is due to the tone of the light they emit.
                                          My Doubt is:
                                          Can I use the LED with two internal chips without problem?
                                          Will there be much difference in the picture?
                                          I'm going to replace all the LEDs.
                                          Both LEDs (original and replacement) are 3V and the same size....
                                          03-04-2022, 04:03 PM
