Ue60f6100k aerial connection damaged
  • sordids999
    • May 2013
    • 2161
    • uk
    Hi guys
    Does anyone know another way of using freeview without using the aerial connection point it's been totally damaged and I cant find a replacement board
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Ue60f6100k aerial connection damaged
    How damaged is the connection ? I've removed and replaced the connector on a couple of TVs in the past where they have been damaged.
    • petehall347
      • Jan 2015
      • 4450
      set top freeview box
      • XxMicroSoldering
        ASUS Rog Strix G17-712LV Laptop Liquid damaged
        by XxMicroSoldering
        Hello Guys
        I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
        10-17-2024, 10:45 AM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • Phil289
        Bush eled32240fhdcntd3d - no aerial signal
        by Phil289
        Hi
        Could somebody guide me as to what to check next?
        This tv has slowly become harder and harder to pick up a signal from the aerial.
        Sometimes if i leave it on long enough it will find all the channels and work great until the next cold boot.
        Ive tryed another tv in the same aerial socket and it works fine.
        Ive tryed the ‘faulty' tv in another working aerial socket and it doesn't find any channels at all.
        There's no looseness to the aerial socket on the tv and checking inside on the power board and mainboard there's nothing obvious to see - its all...
        12-02-2022, 01:54 PM
      • budwich
        Lithium 12v tool battery charger... no negative connection?
        by budwich
        I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
        03-18-2025, 09:12 AM
      • dmcabs
        SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
        by dmcabs
        Hey guys,
        I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
        This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
        FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
        I'm a bit rusty but still have ability to dig right down.
        I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
        09-21-2024, 11:09 AM
