UN6060FH6003 blinking screen, not all LEDs light up
  • withalligators
    • Jun 2013
    • 267
    Hey folks, long time since posting last. Friend adopted an old Sammy destined for the bin.
    Plugged in as found: red indicator light pulses 2 quick sets of 2 flashes, backlight flashes regularly.
    With main disconnected from power: backlight flashes quicker.
    With main and power connected, but backlight disconnected from power: "No signal" message on screen but no backlight (obviously).
    Fearing bad LEDs, I pulled the bezel and screen to look at the LEDs. Several of them from all over are not lighting. Disconnecting one of the strips caused them to start strobing when plugged back in. If it was a single light, or a single strip, I would replace that and expect all to be well. But the sheer number of them has me worried it's perhaps something else with the power board, and I'm pretty rusty. Any alternative ideas, or should I have him order a set of LED strips and replace the whole lot?
    Cheers,
    Alex
  • neilc6
    • Nov 2015
    • 1550
    Re: UN6060FH6003 blinking screen, not all LEDs light up
    Samsungs that I have worked on with bad LEDs tend to have 70 to 90% of them burnt out because the power supply doesn't have a protection mode to shut them down like in LG TVs. It is necessary to do a full replacement. I have seem cases where the power supply can also be damaged when this occurs. If they are still lighting, then the power supply is probably ok.
    • KYBOSH
      Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
      by KYBOSH
      Picked this up to resurrect.
      When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
      I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
      Sometimes the TV would produce an expanding blob on the screen before going black.
      See Video here
      I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
      Did I get another defective board or is there an issue with...
      09-16-2024, 07:48 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • esqmooo
      HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
      by esqmooo
      I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
      03-07-2025, 05:55 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • YasaCh
      Sony kdl 40p5500 red light keeps blinking 3 times
      by YasaCh
      Hello...
      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
      i opened the back cover no sign of damage on the powery suply or motherboard
      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
      07-07-2025, 11:53 AM
