LG 50LF6100 Glitchy Picture
  • philtvman
    • Jun 2016
    • 94
    • America
    This TV will have a glitchy, flickering, double picture. It does not effect the splash screen at all. The picture will flicker (doesn't appear to be backlights, I checked them all and they are all good) and eventually the entire screen will flash white and then black...the TV will stay on, but there will be no picture.
    Unplugging each half of the TCON seems to produce a normal half-picture. Only when they are both plugged in does it have issues.
    Any ideas on where I should start?
    • 12196
    • U.S.
    Re: LG 50LF6100 Glitchy Picture
    Can you post a picture of the "double picture" you mentioned?
    • philtvman
      • Jun 2016
      • 94
      • America
      Maybe "double picture" isn't the best way to describe it. I attached a closer up picture of what it is doing. The image that passes through the particular section will become 'stretched'. The picture will flicker and eventually the screen will quickly wash white (from one side to another) and then black...backlights all stay on, just no picture.
      Again, this only happens with both sides of the TCON plugged in. Unplugging in will result on a perfectly fine half screen.
        • 12196
        • U.S.
        Try heating the capacitors on mainboard with a hairdryer, see if anything changes.
          • 12196
          • U.S.
          Can you post some good clear pictures of each board and one of the whole back and how they are connected?
          • philtvman
            • Jun 2016
            • 94
            • America
            No change with the hair dryer. Attached are pics of the entire back, each board, and of a test image on the TV.
            Here is a Gif of what the display does in case that helps any.
              • 12196
              • U.S.
              Try reseating the two tcon ribbons and lvds cable going from mainboard to tcon, might as well clean them while you're in there, can use ISA alcohol or a pencil eraser, be careful they can be delicate, they are easily removed, looked for the clips that pop upwards with a finger tip, lvds cable usually just squeeze the ends, look closely at how things are connected. Never force anything, usually if you have to force something it isn't being done properly.
              • philtvman
                • Jun 2016
                • 94
                • America
                No luck with that, Attached are pictures with each half of the TCON unplugged.
                (no idea why the attachment tool flips them, they're oriented correctly)
                  what do you see if you have just OSD user menu up without video source?
                  https://www.badcaps.net/forum/attach...1&d=1567169442
                  What does the picture look like without having the user OSD showing?
                  • philtvman
                    • Jun 2016
                    • 94
                    • America
                    Just went to check. TV turned on fine, menu opened fine, but after about three minutes the picture went black. Backlights stay on, but no picture.
                    This is a GIF of the TV turning on after it lost picture juts now
                      So right now you cannot even get the video back on any more back to original symptom?
                      • philtvman
                        • Jun 2016
                        • 94
                        • America
                        If it sits turned off for a while, it will turn back on fine. After about 30 seconds though, black screen. Seems to have progressed quickly from the problem I had last night
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • fixit007
                          Samsung flicker - BN44-00932T board or else?
                          by fixit007
                          I picked up this TV that the prior owner said - just died.
                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                          05-04-2024, 06:14 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
