Sharp LC-37B20E need to change channel plan
  • dkneyle
    • Dec 2013
    • 441
    This TV is a UK model brought into Australia a few years ago. Repaired it by changing out the inverter and now realise it doesn't tune to our Australian DTV frequencies. Owner now tells me he uses a set-top box to drive the TV.
    I'm investigating the possibility of loading in compatible firmware for Australian frequencies. Looking into the matter last night, I don't recognise a direct one-for-one between the UK model and any of the Australian models sold by Sharp.
    I've downloaded the firmware for the three 37" TVs sold by Sharp into Australia, of which only two are 1080 TVs, so I'm down to two possibilities. I also have downloaded the firmware for the UK model.
    My concern is if I start mucking around with incompatible firmware I might not be able to get it back to the original firmware.
    I've thrown the question back to Sharp Australia Technical Support but doubt I'll get any reasonable response as the TV was not sold here in Australia.
    Anyone had this challenge with other brands of TV and how did your experience go?
  • dkneyle
    • Dec 2013
    • 441
    Re: Sharp LC-37B20E need to change channel plan
    Also, does anyoner have a ready-reckoner of DTV channel frequencies used in Europe? I went looking on the net and could easily find a table for the UK, let alone for any of the other countries.
    This TV can be set for any European country. I was hoping I must stumble across one which was similar to what we use here. I only need five freqencies: CH29=536.5MHz, CH30=543.5MHz, CH31=550.5MHz, CH32=557.5MHz, CH33=564.5MHz
      • 12276
      • U.S.
      Isn't there like Country codes in the service menu?
      • dkneyle
        • Dec 2013
        • 441
        Yes there are Country Codes, but this set only has options for Europe. Obviously it was only intended for sale in that market. I suspect models sold in our region have options for Oceania or Asia.
          • 12276
          • U.S.
          Ran across this conversation:https://www.cnet.com/forums/discussi...-to-uk-616274/
            • 12276
            • U.S.
            More reading there, some say you need a set top box: https://www.pomsinoz.com/topic/14808...-in-australia/
            • dkneyle
              • Dec 2013
              • 441
              Thanks NOMORESONYS for your research. I just tried the Germany option, but it doesn't resolve the DTV issue. The references in those posts to compatibility with European countries were with regards analogue TV, which was switched off here some years ago.
              Customer will continue to watch via a set top box and I'm sure will have just as enjoyable viewing experience.
                • 12276
                • U.S.
                Forgot to look at the dates. Pal is Pal, Uk. and AU. are both Pal, seems like it should work, might have to do a factory reset and initialization, curious to know why it won't work? Quite a head scratcher.
                • R_J
                  • 9588
                  There are different versions of PAL ie PAL-M and PAL-I etc. But these are the old analog broadcasting standards, In the U.K. it is now DTT (digital terrestrial television ) using DVB-T or DVB-T2 (HD)
                  Australia also uses DVB-T but the modulation might be different (QPSK,16QAM,64QAM)
                  In N.America the standard has changed from NTSC to ATSC for digital over the air broadcast, They can use the same VHF channel (except for channels 2-7) but its not brodcasting an analog video signal but a digital signal.
                    • 12276
                    • U.S.
                    Wrong info.
                      • 12276
                      • U.S.
                      So Australia is DTV then, so no way around a decoder/set top, xbox etc?
                      • R_J
                        • 9588
                        You may have missed this
                          • 12276
                          • U.S.
                          Nope seen it, just wondering why it needs the set top, according to wiki both countries do DVB-T2: https://en.wikipedia.org/wiki/DVB-T#...VB-T_or_DVB-T2
                            • 12276
                            • U.S.
                            Ok, so it may be a modulation issue, any fix for that, besides the boxes? Not moving there just curious.
                            • dkneyle
                              • Dec 2013
                              • 441
                              It is not an issue with DTV modulation compatibility (we are the same here in Australia as the UK and most of the rest of the world). The issue is our channel plan is unique to Australia. The allocated frequencies here in OZ can't be detected when the tuner does a scan as it is looking at particular frequencies depending upon the country code set up of the TV. (With this set, you do a factory reset and then allocate the country in which it will be used. But as prevoiusly mentioned, the only option are European countries.)
                              And that is why the current owner uses a set-top box and looks like that is the only solution going forward. Without a firmware change that includes Australia there appears to be no other option, but was worthwhile throwing it out there to see whether anyone had any other thoughts on the matter.
                              • petehall347
                                • Jan 2015
                                • 4438
                                • United Kingdom
                                mad thought but it maybe could be done .that is fitting set top box into tv somehow .
                                • dkneyle
                                  • Dec 2013
                                  • 441
                                  Yes, probably a mad thought! LOL
                                  • R_J
                                    • 9588
                                    I thought they should all be the same modulation but was'nt sure so I thought I would suggest it.
                                    • eccerr0r
                                      old X58 triple channel board... memtest86 memory speed?
                                      by eccerr0r
                                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                      06-28-2025, 09:06 AM
                                    • spleenharvester
                                      Reverse engineering of 18650 4-channel tester
                                      by spleenharvester
                                      Hi friends
                                      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                      05-04-2025, 02:43 AM
                                    • mikey5791
                                      Help on car amplifier only one channel works
                                      by mikey5791
                                      Hi all forum members,
                                      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                      08-06-2025, 10:36 PM
                                    • dicky96
                                      American Audio VLP1500 Distorting on one channel
                                      by dicky96
                                      Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                      Protection and Clip LED are off
                                      There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                      I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                      The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                      07-13-2022, 05:25 AM
                                    • dicky96
                                      Hitachi V19B01922 Channel Tune problem
                                      by dicky96
                                      Hi Guys
                                      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                      He also has an LG TV, so three screens in the bar
                                      I installed three Satlink ST-6503 DVB-T Modulators
                                      This model https://www.aliexpress.com/item/32916553905.html
                                      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                      02-09-2023, 09:20 AM
