Vizio M3D460SR Connector CN604 Main Board
  • Taterbug
    • Dec 2013
    • 114
    I have a replacement main board for my Vizio M3D460SR. The only difference is that the new board has an additional connector. CN604 right beside CN601 both board numbers have the exact part number. Is this a later revision for Bluetooth and will it be ok to use. All other connections are the Same. I am including photos of the new and old board.
    Re: Vizio M3D460SR Connector CN604 Main Board
    Did you match the PCB assembly P/N as printed on the barcode sticker?
    Same blank P[CB can be stuffed to make the PCBA for many TV model.
    The EEPROM for the replacement board may not be made for your TV chassis that you have. You can take a chance trying to use it and hope for nothing to get damaged, or order the correct PCBA for your model.
    • Taterbug
      • Dec 2013
      • 114
      Yes I even took a picture of it and sent the guy I bought it from just to make sure it worked
      The board I received had the extra connector but part of the sticker is missing. I bought it off eBay and am contacting the guy now to see if he will exchange it. I hope he does. The original problem is the typical Vizio intermittent on / off problems. He has a good rating so hopefully he will.
        Hmm, shopjimmy shows the connector that is missing on your board:
        https://www.shopjimmy.com/vizio-cbpf...r-m3d460sr.htm
        Does your TV have:
        Panel Sticker Number: T460HB01 V.1
        Panel Manufacturer: AU Optronics
          • 12274
          • U.S.
          Looks like there's a difference in the sticker numbers, think yours is TXBCB02K012, the replacement with cn604 is TXBCB2K012, your number has an extra 0, don't know if they are compatible.
            • 12274
            • U.S.
            My first thought is maybe the extra connector has to do with 3d sets, is yours 3d?
              BTW, what is the reason for replacing the main board?
              • Taterbug
                • Dec 2013
                • 114
                Got the tv fixed. The eBay seller exchanged the board for the correct main board. He said the extra connector was for surround sound. Got the replacement board today and it works like a charm. The original problem was intermittent turn on/off and freezing up. It is a 3D set and my friend that gave it to me said he paid over $1000.00 for it.
                  • 12274
                  • U.S.
                  Glad to hear it.
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    07-28-2025, 08:34 AM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
                  • howardc64
                    A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
