Sony KDL-43WD750 Turns on, no display
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Hello, I am troubleshooting a Sony TV with 173587112 board in it. AUO T-CON.
    The TV turns on and draws 2A of power at 19.5V, backlight comes on and the center light glows white. There is no image being produced whatsoever, and I'm unsure how to test for audio at this point.
    I performed a reflow on the main mediatek chip as well as the D4758 chip between the CPU and LVDS connector, the TV behaves exactly the same after doing this, no change.
    It reacts to remote, I can turn it on and off with it and the white light blinks when it detects the remote activity.
    I would replace this main board if it can't be repaired but I would like to know if there is a way to test if the LCD panel is good? Can't return a new board so yeah, need to be sure.
    As far as I know, the TV was damaged after an atmospheric discharge event nearby.
    Thanks in advance!
  • Diah
    • Feb 2013
    • 6439
    Re: Sony KDL-43WD750 Turns on, no display
    start to upload photo on whole back of the tv to see how boards connected together.. also photo on T-CON.
    did you test the T-CON fuse ?
    plug in USB stick with JPG photo on the root of it and check the LED indicator of the stick blinking ??
    did you try to inter diagnose mode from stand by if it come the screen on
    • CapLeaker
      Leaking Member
      • 8327
      Test the LVDS on the main board with an oscilloscope, while flicking the menu on and off all the time. That will tell you if the main board is good or not.
      Check the Tcon that it is getting power and then there are little buck converters on the Tcon, check them too.
        Need good clear pictures so we can see what we are dealing with.
        T-CON is integrated into the LED panel?
          • 12276
          • U.S.
          Unplug tv from power, unplug cable from powerboard to mainboard leave it unplugged, plug power back into outlet, does anything change?
            • 12276
            • U.S.
            Kdl's are easy to bork up firmware, try a firmware update, firmware on a flashdrive, some kdl's will update automatically, have tv plugged in, plug in flashdrive turn tv on.
              • 12276
              • U.S.
              Read the instructions, it might not work without a display, some older kdl's will: https://www.sony.co.uk/electronics/s...loads/00016216
              • FrozenHaxor
                • Jun 2015
                • 260
                • Poland
                Heres a photo of TV's back. Shields off, everything connected.
                The fuse on T-CON is good. Should I measure waveforms of any random lines of the LVDS cable with an oscilloscope? Or any particular points there?
                T-CON power rails measure good voltages.
                As I've mentioned in my first post, this TV stopped working after lightning storm. Would that be a cause of firmware failure? It was probably zapped through DVB-T tuner.
                  • 12276
                  • U.S.
                  Read much???????
                  • FrozenHaxor
                    • Jun 2015
                    • 260
                    • Poland
                    There is no power board in this model, it uses 19,5V external brick that plugs straight into the logic board.
                    According to those instructions I have to navigate through many menus and options to update the firmware, which is impossible given current state of the TV.
                      • 12276
                      • U.S.
                      One possible reset method:
                      Unplug the TV. Hold down the "Power" and "Down" buttons at the same time and plug the power back into the outlet while holding the buttons for 30 seconds. When a green LED light comes on, release the buttons. Wait while the TV reboots multiple times and runs through the reset cycle. Those diy reflows are a temporary fix, most don't last past a few months.
                      • Diah
                        • Feb 2013
                        • 6439
                        1- remove the tuner board from MB and check menu come out ?
                        2- i mentioned before to inter diagnose mode from stand by state to check it will come the screen.
                        3- as its use external power adapter. the Panel will have one Fuse on the left side of its Tap.
                        • FrozenHaxor
                          • Jun 2015
                          • 260
                          • Poland
                          Doesn't look like this method works on this particular TV, it just turns on and keeps blinking while I hold the buttons.
                          1 - The board behaves exactly the same without the tuner board, same amperage draw.
                          2 - Can you tell me the combination to try and enter this mode?
                          3 - Interesting, I will investigate that. Is that fuse for display or backlight though? Because backlight works.
                          • FrozenHaxor
                            • Jun 2015
                            • 260
                            • Poland
                            Right, so the motherboard was replaced, now the TV shows an image and appears to be working.
                            BUT
                            None of the channel programming functions work. When trying to search for DVB-T channels, the TV shows 0 channels found for a brief time and then restarts. Won't even attempt to find any analog ones either. I have updated the firmware successfully, but that didn't help. What could be wrong now?
                            This is the tuner board I have: (RE243ZP)
                              • 12276
                              • U.S.
                                • 12276
                                • U.S.
                                Wonder if the tuner is bad, maybe try swapping your old tuner to the new board.
                                • FrozenHaxor
                                  • Jun 2015
                                  • 260
                                  • Poland
                                  I have bought a new tuner board, it behaves identically to the old one. If I turn it on without a tuner board in, all the tuning options are correctly grayed out so it does communicate with it at least in some way.
                                    • 12276
                                    • U.S.
                                    You have tv set to the correct source during tuning attempt?
                                    • FrozenHaxor
                                      • Jun 2015
                                      • 260
                                      • Poland
                                      Seems like it does not make a difference which source I chose, still hangs and reboots when enabling any tuning option.
                                      • FrozenHaxor
                                        • Jun 2015
                                        • 260
                                        • Poland
                                        I think this board is defective. It is impossible to turn off this TV - after I turn it off, it boots back on in several seconds. Oh ffs I'm so annoyed with this repair.
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • NanoTesting
                                          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                          by NanoTesting
                                          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                          With charger it turns on, fan spins but gives no image.
                                          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                          Reflashed BIOS, same problem.
                                          Replaced both main mosfets.
                                          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                          10-30-2024, 10:48 PM
                                        • BoardHoarder
                                          XBR-65X850D Backlight/Power On Help
                                          by BoardHoarder
                                          Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                                          02-09-2024, 11:00 PM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
