Sony KDL-43WD750 Turns on, no display
  • nomoresonys
    • 12276
    • U.S.
    Re: Sony KDL-43WD750 Turns on, no display
    Ah, I see, sure seems like they sent you a bad one.
    • nomoresonys
      • 12276
      • U.S.
      The numbers on the white stickers matched up?
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Yes it was supposed to come from the same model.
        • nomoresonys
          • 12276
          • U.S.
          Just going by same model won't always work, you usually need to match up the numbers on the white sticker, what is your panel number? should be on a sicker on the back metal chassis somewhere.
          • Diah
            • Feb 2013
            • 6440
            Originally posted by FrozenHaxor
            I have bought a new tuner board, it behaves identically to the old one. If I turn it on without a tuner board in, all the tuning options are correctly grayed out so it does communicate with it at least in some way.
            log in SM and register the type of your new Tuner there..
            • FrozenHaxor
              • Jun 2015
              • 260
              • Poland
              #26
              The board was mismatched to the TV. I have got another one with the same issue and what I did to fix this issue was to simply reball the old board's NAND memory and solder it to the new board. This fixed all issues and the TV works again. Thanks to everyone for participating in this thread.
              • nomoresonys
                • 12276
                • U.S.
                #27
                That's probably what was wrong with the old/original board.
                • FrozenHaxor
                  • Jun 2015
                  • 260
                  • Poland
                  #28
                  What? How could the old board's NAND be wrong if I moved it to the new board? Old board had dead CPU.
                  • nomoresonys
                    • 12276
                    • U.S.
                    #29
                    WHAT WHAT?? YOU didn't say it had a dead cpu NOW did you???
                    • FrozenHaxor
                      • Jun 2015
                      • 260
                      • Poland
                      #30
                      That's the only logical conclusion to the failure mode of the original board. The NAND memory was good and so taking it off the original board and placing to new donor made the new board fully compatible with the TV. Old tuner is still good also.
                      • nomoresonys
                        • 12276
                        • U.S.
                        #31
                        If there was nothing wrong with the NAND then why did you reball it?
                        • FrozenHaxor
                          • Jun 2015
                          • 260
                          • Poland
                          #32
                          I don't think you've read what I wrote carefully enough. You have to reball the memory in order to reuse it on the new donor board. How else would you solder it again?
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            Well that makes sense, it's pretty early here, I'm not quite awake.
                            • FrozenHaxor
                              • Jun 2015
                              • 260
                              • Poland
                              #34
                              Haha thats okay, cheers mate.
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • iglitare
                                Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                by iglitare
                                i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                Backlight seems to work, Sound (Setup menu after reset) works.
                                If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                With my small knowledge i would think at least the cables are good.
                                Can this happen because of a bad tcon board?
                                Or is it always a bad/shorted...
                                09-04-2025, 07:13 AM
                              • NanoTesting
                                Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                by NanoTesting
                                I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                With charger it turns on, fan spins but gives no image.
                                Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                Reflashed BIOS, same problem.
                                Replaced both main mosfets.
                                Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                10-30-2024, 10:48 PM
                              • BoardHoarder
                                XBR-65X850D Backlight/Power On Help
                                by BoardHoarder
                                Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                                02-09-2024, 11:00 PM
                              • thelankanguy
                                Sony KD-55X9000F TCON Issue
                                by thelankanguy
                                The TV shows a black screen with no image.
                                TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                Later both ribbons were disconnected and TCON voltages were tested.
                                12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                There is also a short to ground in this circled inductor.
                                Is this a TCON issue or something else ?...
                                12-13-2024, 12:27 AM
