Panasonic tv Tx-55ax630b bootloop
  • nervero
    • Jan 2015
    • 30
    • NL
    Hi ,
    I have tv with main board tnph1112 with bootloop colors white red blue green then black and again wrgb.
    After hours trying pushing many combinations of buttons on tv and remote I can't get off this kind of test menu.
    I've seen many same issues on yt and no one of the solutions with pushing buttons works by me.
    Can it be some eeprom fault or software?
    Other main board buyed from eBay and still same.
    Voltage on psu is good and I didn't found any of bad or shorted caps on screen flex and screen board , also no defective cof around screen .
    When one of flex from Tcon is out then I get some kind of bad picture 1sec with stripes and then goes to black and wrgb loop again .
    Any ideas what can it be? Where should I begin to check ?
    • 12206
    • U.S.
    Re: Panasonic tv Tx-55ax630b bootloop
    Probably needs firmware update, try it with a flashdrive, try put in flashdrive with the update then plug in tv, power on, see if it does it automatically. Might not be able to update without a display, one tutorial says turn tv on then insert flashdrive, try one then the other.
      • 12206
      • U.S.
      https://av.jpn.support.panasonic.com...uk_cis_06.html
      • budwich
        • Jul 2015
        • 3097
        Quote: "When one of flex from Tcon is out then I get some kind of bad picture 1sec with stripes and then goes to black and wrgb loop again ".
        Does this happen the same with either cable or just a particular side. further, does the disconnected side go white? Look closely at the the connectors on the boards to see if there is some "stuff" in them. Also check the connectors at the panel edge board side.
        • nervero
          • Jan 2015
          • 30
          • NL
          Can’t start firmware update and I’ve checked connector already with usb microscope for “dirt and stuff” also cleaned every contact points with isopropyl and still nothing ,
          • Diah
            • Feb 2013
            • 6399
            Originally posted by nervero
            Can't start firmware update and I've checked connector already with usb microscope for “dirt and stuff” also cleaned every contact points with isopropyl and still nothing ,
            disconnect the both ribbon cable from T-CON to Panel and turn on... it stay on or not ??
            • nervero
              • Jan 2015
              • 30
              • NL
              It stays still on but only with blank screen and backlight but no restarts
              • Diah
                • Feb 2013
                • 6399
                first of ll take out both ribbon cable and inspect the end of them with a good magnifier
                  • 12206
                  • U.S.
                  This may be a match, usually need to match up the numbers on the white sticker: https://www.ebay.co.uk/itm/PANASONIC...oAAOSws~pb1u85
                  • nervero
                    • Jan 2015
                    • 30
                    • NL
                    I've did it already and other visual inspection before my 1st post.
                    I have also tried other ribbon and tcon flex from other with same pins and nothing changed.
                    Does anybody have eeprom dump from this board ?
                    I can't find it on many sites
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • rascao
                      iMAc A1418 Board 820-00034 some kind of bootloop
                      by rascao
                      I have a iMac A1418 board 820-00034, the problem is when the board is cold i can get to the mac os log in for like 1 min and then start the bootloop, but is a fast bootloop sometimes i can just see the apple logo for 1 sec and keeps doing it until i un plug the power, if i try to turn on again the bootloop continues, if i let the board un plug for 15 or 20 min i can turn on again and log in on Mac os but the bootloop start again under 1 min.
                      I try to get to the recovery and i can, when try to install a new mac os it starts loading the usb and then start the bootloop,...
                      10-17-2024, 02:33 AM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • aa10aa10
                      Panasonic Toughbook CF-33 mk1 BIOS repair
                      by aa10aa10
                      Good day,
                      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                      01-21-2025, 06:13 AM
