Panasonic tv Tx-55ax630b bootloop
  • nervero
    • Jan 2015
    • 30
    • NL
    Hi ,
    I have tv with main board tnph1112 with bootloop colors white red blue green then black and again wrgb.
    After hours trying pushing many combinations of buttons on tv and remote I can't get off this kind of test menu.
    I've seen many same issues on yt and no one of the solutions with pushing buttons works by me.
    Can it be some eeprom fault or software?
    Other main board buyed from eBay and still same.
    Voltage on psu is good and I didn't found any of bad or shorted caps on screen flex and screen board , also no defective cof around screen .
    When one of flex from Tcon is out then I get some kind of bad picture 1sec with stripes and then goes to black and wrgb loop again .
    Any ideas what can it be? Where should I begin to check ?
  • nomoresonys
    • 12331
    • U.S.
    Re: Panasonic tv Tx-55ax630b bootloop
    Probably needs firmware update, try it with a flashdrive, try put in flashdrive with the update then plug in tv, power on, see if it does it automatically. Might not be able to update without a display, one tutorial says turn tv on then insert flashdrive, try one then the other.
    • nomoresonys
      • 12331
      • U.S.
      https://av.jpn.support.panasonic.com...uk_cis_06.html
      • budwich
        • Jul 2015
        • 3097
        Quote: "When one of flex from Tcon is out then I get some kind of bad picture 1sec with stripes and then goes to black and wrgb loop again ".
        Does this happen the same with either cable or just a particular side. further, does the disconnected side go white? Look closely at the the connectors on the boards to see if there is some "stuff" in them. Also check the connectors at the panel edge board side.
        • nervero
          • Jan 2015
          • 30
          • NL
          Can’t start firmware update and I’ve checked connector already with usb microscope for “dirt and stuff” also cleaned every contact points with isopropyl and still nothing ,
          • Diah
            • Feb 2013
            • 6610
            Originally posted by nervero
            Can't start firmware update and I've checked connector already with usb microscope for “dirt and stuff” also cleaned every contact points with isopropyl and still nothing ,
            disconnect the both ribbon cable from T-CON to Panel and turn on... it stay on or not ??
            • nervero
              • Jan 2015
              • 30
              • NL
              It stays still on but only with blank screen and backlight but no restarts
              • Diah
                • Feb 2013
                • 6610
                first of ll take out both ribbon cable and inspect the end of them with a good magnifier
                • nomoresonys
                  • 12331
                  • U.S.
                  This may be a match, usually need to match up the numbers on the white sticker: https://www.ebay.co.uk/itm/PANASONIC...oAAOSws~pb1u85
                  • nervero
                    • Jan 2015
                    • 30
                    • NL
                    I've did it already and other visual inspection before my 1st post.
                    I have also tried other ribbon and tcon flex from other with same pins and nothing changed.
                    Does anybody have eeprom dump from this board ?
                    I can't find it on many sites
                    • BigPete
                      Panasonic Heatpump Dryer Repair
                      by BigPete
                      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                      Unfortunately the whole machine has to come apart to fix it.
                      I have...
                      11-01-2025, 06:40 PM
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • rascao
                      iMAc A1418 Board 820-00034 some kind of bootloop
                      by rascao
                      I have a iMac A1418 board 820-00034, the problem is when the board is cold i can get to the mac os log in for like 1 min and then start the bootloop, but is a fast bootloop sometimes i can just see the apple logo for 1 sec and keeps doing it until i un plug the power, if i try to turn on again the bootloop continues, if i let the board un plug for 15 or 20 min i can turn on again and log in on Mac os but the bootloop start again under 1 min.
                      I try to get to the recovery and i can, when try to install a new mac os it starts loading the usb and then start the bootloop,...
                      10-17-2024, 02:33 AM
                    • AquaMan Ua
                      Problem with PANASONIC CF53 laptop after changing BIOS settings
                      by AquaMan Ua
                      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                      05-17-2025, 09:40 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      I happened several times, in the search for help from the web, to consult this very interesting forum.
                      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                      Having said that I come to the gist of my post on the forum as the title suggests.
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
