Panasonic Viera TX-L32E3B won't power up, green LED flashing
  • Diah
    • Feb 2013
    • 6399
    Re: Panasonic Viera TX-L32E3B won't power up, green LED flashing
    my messages over this forums are link ..LOL
    • lamlash
      • Aug 2019
      • 26
      Originally posted by Diah
      NO, you can use your DM in Diode mode. ( peep ton ) and test each one. the reading will be if - + correct it will light on a little depend on your DM battery. and when you exchange the red and black at opposite place it should read Diod round 0.75ß-0.540. if one not goes on but read correct Diode it mean its OPEN. if one powered on but no Diode reading or it peep mean its shorted. and this most case.
      I tried this on my DVM. They all read about 0.740V on diode mode but they didn't light up at all. I'm sure all the LEDs are OK because they all have the exact same behaviour. I think I need to look at the LED driver PCB in more detail.
      • Diah
        • Feb 2013
        • 6399
        at this point then yours LED okay.. and driver too,, Panasonic never seen LED driver failed
        lets back to yours PSU did the sockets had pin lable ??
        • lamlash
          • Aug 2019
          • 26
          I'm not sure I understand what you mean. Here's a picture of the connectors on the power board.
          • Diah
            • Feb 2013
            • 6399
            take the psu out and look on the down side if there printed label described the name or volts of the socket pins which connected to MB
            • lamlash
              • Aug 2019
              • 26
              #26
              Can't see anything like that on the back of the board. Photos attached.
              • Diah
                • Feb 2013
                • 6399
                bad things.. so how we will know which pins PW-on and DR-on ..
                disconnect MB to PSU. just keep the LED driver socket connected and plug it on and read all pins volts .. need to narrow and compare with yours first post reading
                • lamlash
                  • Aug 2019
                  • 26
                  #28
                  OK. So here's the readings:
                  P2
                  1. 5.75V
                  2. 5.75V
                  3. 0V
                  4. 2.1V (seems to be falling)
                  5. 2V (falling)
                  6. 2V (falling)
                  7. 0V
                  8. 0V
                  9. 5.7V
                  10. 2.7V (falling)
                  11. 2.8V (falling)
                  12. 5V (falling)
                  13. 0V
                  14. 0V
                  15. 0V
                  16. 0V
                  P4
                  pin 4 is at 3.2V, the others are 0V
                  • Diah
                    • Feb 2013
                    • 6399
                    please unplug PSU and discharge it carefully and make new measurement after plug in
                      I tried this and the blue wires all seem to be at a floating voltage. There isn't any distinct change in the meter reading when the power is switched on. I did this with the LED panels wired up but the TV screen panel disconnected. Everything else was connected.
                      What is the Voltage on the Brown wires?
                      • lamlash
                        • Aug 2019
                        • 26
                        #31
                        On my TV those anode wires for the LEDs are red. They are only at 24V DC which is nowhere near enough voltage for the LED strips which seem to need at least 70V per strip from what I can tell. I will have a look at the schematic for the LED driver board later today.
                        • Diah
                          • Feb 2013
                          • 6399
                          i took a look on the service manual of this chassis GLP26. i can say your PSU either good. we do have problem with main board and exactly at eeprom. some time load complete start script then work and some time not.. freeze it and turn on the set i think the BL will come on.
                          • lamlash
                            • Aug 2019
                            • 26
                            #33
                            ? Freeze it ? Put the main board in the freezer? Are you kidding?&
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #34
                              Not the whole board, just the eeprom.
                              Using freeze spray, a can of compressed air held upside down or a can of lighter gas with a nozzle on.
                              • lamlash
                                • Aug 2019
                                • 26
                                #35
                                I'm not sure if you're serious!
                                About 30 years ago there was an urban myth that you could wipe the security code from a car radio by putting it in the freezer. I think it was a wind up so I'm sceptical about this too!
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #36
                                  Yes we are being serious. You can do a search on the forum for verification.
                                  It's not guaranteed to work, but sometimes when an eeprom or NAND have issues, freezing it can cause it to work/be fully read. It won't damage it if it doesn't work.
                                  • Diah
                                    • Feb 2013
                                    • 6399
                                    diff cleared it enough. at end its all up to you.
                                    • lamlash
                                      • Aug 2019
                                      • 26
                                      #38
                                      Thanks I will try it tonight
                                      • lamlash
                                        • Aug 2019
                                        • 26
                                        #39
                                        Hi, the EEPROM freeze didn't work. I froze IC8901 and IC8902 then powered the TV up. No change : no red standby LED, about 44 fast flashes of the green LED then nothing once a key is pressed on TV or remote.
                                        • lamlash
                                          • Aug 2019
                                          • 26
                                          #40
                                          Can you let me know if the following is correct?
                                          1. The TV won't come on because BL_SOS is at 3.3V (asserted)
                                          2. The BL_SOS signal originates in the main board (Board A)
                                          3. The BL_SOS signal goes into to the power board at connector P2 then out of P4 and into the LED driver
                                          4. The LED driver inhibits the voltage booster circuit so the anode only has 24V on it and the PWM signals for the FETs for the cathodes are not switched
                                          So my focus of investigation should be Board A?
                                          • mostachio
                                            Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                            by mostachio
                                            Hi Badcaps,
                                            I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                            TV Details:
                                            Model # - TH-65DX700Z
                                            Symptoms:
                                            The television turns on and displays a picture then makes a clicking sound and turns off.
                                            I haven't opened it up yet but...
                                            09-04-2024, 02:32 AM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
                                          • Ama Chur
                                            Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                                            by Ama Chur
                                            After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                                            02-21-2025, 08:12 PM
                                          • fixxy88
                                            Panasonic 55DX600u repair help - no display fast green then slow red led flash
                                            by fixxy88
                                            Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
                                            Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
                                            02-22-2023, 09:14 PM
                                          • ItepK
                                            Panasonic TX-P42G30E green light blinking, no video, no audio
                                            by ItepK
                                            Hey everyone!
                                            I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                            This post describes my entire troubleshooting process of this TV.
                                            When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                            I've taken the unit apart, and I've started to check some voltages:
                                            • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                            12-22-2023, 05:06 AM
