JVC EM55FTR No Picture, Yes Sound, Yes Backlight
  • TheTesterMan
    • Apr 2015
    • 91
    Re: JVC EM55FTR No Picture, Yes Sound, Yes Backlight
    I gave it one last shot and spent about 4hrs troubleshooting and tapping pins. In the end I was not able to find the short so I had to recycle the TV.
    I am almost certain that the issue was with the panel and not the panel PCBs, but we will never know.
    Thanks to all of you that assisted.. on to the next one.
      • 12330
      • U.S.
      Thanks for the feedback, reminds me of when I couldn't fix my damn fridge about 2 years ago...STILL pissed off about that.
        • 12330
        • U.S.
        Today I've been defeated by these Harmon/Kardon pc speakers secondary speaker don't work, rewired it and it worked, put the pcb board back in the other speaker buttoned it up second speaker dead again, took the main speaker back apart but second speaker don't want to work like before, second speaker wire and rca cable and end are all good. Tested on tv, when I turn off the speakers with the on off/volume there is that slight turn off sound getting thru, thinking it's my rca output jack coming out of main speaker.
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • Rozp
          70LE660U dark cloud or black screen with sound.
          by Rozp
          Hello Everyone,
          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
          08-29-2023, 05:25 PM
        • JohnML1975
          Samsung UA50TU8000W no picture and no sound
          by JohnML1975
          Hello All
          have seen posts on this model in here but my problem sounded different so thought i would create a thread
          TV will not turn on
          There is no standby light
          When I press ON button for remote the red standby light does flash but no picture and no sound
          From the back of the TV I can see the red light on the back of the mother board
          Holding torch to the screen I cannot see a picture
          I removed the back cover
          Observing the boards I cannot see any damage
          I disconnected the main board from the power supply
          the back...
          08-30-2025, 09:40 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
