Panasonic TX-50DX700E turns on by itself
  • Egidio85
    • Jul 2019
    • 38
    • italia
    hi, I have a strange problem with a Panasonic TX-50DX700E TV, it has a TNPA6198 power supply.
    the TV initially switched on by itself and responded very late to the volume-change controls etc. both from the remote control and from the TV keys.
    now it sporadically turns on if I switch off the power and plug it back in, after a few minutes of operation it emits a strange whistle from the speakers and turns off.
    could anyone tell me if it can be a problem of the power supply card or motherboard?
    any tips on the components to check?
    capacitors and diodes are ok. I am attaching a photo of the voltages from off
    thank you
  • budwich
    • Jul 2015
    • 3097
    Re: Panasonic TX-50DX700E turns on by itself
    if you have the tv connected to hdmi, remove the cable. Also try disconnecting the IR receiver board if possible to see if the problem changes.
    • Egidio85
      • Jul 2019
      • 38
      • italia
      I removed the HDMI cable and the IR receiver but the problem persists. the TV stays on for 1 minute then the image freezes and a whistle sounds from the speakers. after 5 seconds it turns off
      • mostachio
        Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
        by mostachio
        Hi Badcaps,
        I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
        TV Details:
        Model # - TH-65DX700Z
        Symptoms:
        The television turns on and displays a picture then makes a clicking sound and turns off.
        I haven't opened it up yet but...
        09-04-2024, 02:32 AM
      • PanasTC
        Panasonic TC-60CX800U turns off after 2 seconds.
        by PanasTC
        Panasonic TC-60CX800U with Power board: TNPA6060 1P
        The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
        Also, I could see HDM in the top corner for a second.
        Is it possible that the issue is a bad LED light that forces the TV to turn off?​
        11-27-2023, 09:02 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
