Panasonic 58-TXAX802B Stuck on Panasonic Logo
  • Adrock
    • Jun 2019
    • 6
    • United Kingdom
    I'm new to this place and repairing TVs so go gentle with me. I was donated this TV and after doing lots of research managed to determine my TVs A board needs changing.
    The symptom I'm getting is that the TV powers up, I get a solid green LED and the Panasonic logo is on the screen. It stays that way for a couple of minutes before what seems to be a reboot, after waiting another couple of minutes it switches off. There are no red LED flashes at any time.
    The remote control does nothing, I've tried getting onto the test pattern screen and that doesn't work.
    I thought I'd just do a quick search for the part number (TNPH1100) and replace the board but there aren't any available, I missed out by a day on one of them.
    I've read a similar thread on here and someone suggested dodgy NAND. My question is, would it be feasible for me to attempt a repair on the board or is it a lost cause?
    I have experience with soldering and testing/returning old amps so I'm not completely green. Any help would be great.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Panasonic 58-TXAX802B Stuck on Panasonic Logo
    Have you tried a firmware update from USB ?
    • Adrock
      • Jun 2019
      • 6
      • United Kingdom
      I have, I put it onto a FAT32 formatted USB drive and tried all three USB ports on the rear, restarting the TV each time.
      I managed to find the service manual for a similar model, the AX800, and found its an eMMC chip, not NAND, if that makes a difference.
      • Adrock
        • Jun 2019
        • 6
        • United Kingdom
        I opened the TV up and found a Hynix H26M31003GMR. I have checked the voltages and everything seems to be within the parameters mentioned within the service manual.
        My question now is, do I have to use exactly the same product to replace what I'll be removing? Also, do I need to flash the chip before I install it on the PCB?
        The chip installed is a 4gb, 3.3v, MMC4.5 eMMC in an 11.5x13x1.0 package.
        I've found https://www.mouser.co.uk/ProductDeta...5T%252BA%3D%3D that on mouser. Would that work?
        • diif
          • Feb 2014
          • 6978
          • England
          It needs programming first.
          • Adrock
            • Jun 2019
            • 6
            • United Kingdom
            I rushed into this without thinking it through, it seems. I removed the existing eMMC this evening and now I'm stuck working out how to programme a newly purchased eMMC without spending lots of money on an eMMC153 socket I'll probably only use once.
            Thanks for your help so far diif.
            • diif
              • Feb 2014
              • 6978
              • England
              No harm done, it had to come off anyway.
              It's usual to use a known working dump to program the eMMC as it's likely the old one failed due to bad blocks.
              I've had a quick look but couldn't find a dump, but if you find one or want to chance copying what you already have from one to the other, you're welcome to post it to me and I'll do it for you.
              • Adrock
                • Jun 2019
                • 6
                • United Kingdom
                Thank you very much for the offer diif, I have found a firmware update online, which I downloaded originally. The zip file contained a .sec file, which I've never come across before. I take it that isn't what is required.
                When I receive the new eMMC I'll be sure to contact you.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Yes, t's a copy of the whole contents that's a required, often referred to as a dump.
                  The update file will just overwrite certain parts of the original.
                  • Paul112004
                    • Sep 2019
                    • 14
                    • United Kingdom
                    Hi I have a tx-50ax802b version of same tv with same problem can I do exactly the same and are my part numbers the same as mentioned ect
                    I tried looking for service manual but cant find my model type would the 50 and 58 be exactly the same chip models ect
                    Could someone possibly direct me to where the nand is I bought the device to flash it but not sure where it will be
                    Thought I'd give it ago if it works good if not il just sell the parts instead
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Under the big metal heatsink. A programmer capable will be over £100, you also need a good copy of the firmware (dump).
                      • Paul112004
                        • Sep 2019
                        • 14
                        • United Kingdom
                        Hi I'm assuming your talking about the black plate that's screwed on top
                        • Paul112004
                          • Sep 2019
                          • 14
                          • United Kingdom
                          Also thanks for replying I was meant to say before
                          The firmware latest file is that what I need to put in to the new chip
                          Has anyone managed to find out what software tv engineers use when they plug in the laptop into the service port on the board would be handy to know what it is called ive googled but find no answer to it
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Yes, I did a quick Google of the mainboard and it seems Ro be covered with a large heatsink but if you want to add photos I can confirm.
                            • Paul112004
                              • Sep 2019
                              • 14
                              • United Kingdom
                              Hi where did you manage to obtain the service manual please
                              • Paul112004
                                • Sep 2019
                                • 14
                                • United Kingdom
                                Ok thanks when I get home il send some photos to you much appreciated
                                • Paul112004
                                  • Sep 2019
                                  • 14
                                  • United Kingdom
                                  As requested photos of board I numbered so you can see and reply easier with the number of chip ect
                                  I tried doing a usb firmware update but it doesnt even let you do that it just starts up stays on panasonic logo then turns of and gives u 13 flashes which I believe is loss of communication so could that be the big chip number 1
                                  Or if not what part holds the firmware on the tv
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    1, 2, and 3 look like processors. I see RAM connected to No1, are all four black rectangles identical as a couple of them are obscured.
                                    • Paul112004
                                      • Sep 2019
                                      • 14
                                      • United Kingdom
                                      Oh what an idiot I am I knew they were processors why did I think it was that part I needed lol
                                      The bit I need is where the firmware is installed
                                      I will take a closer picture for you of the area you mentioned and check them out and get back to you in a bit but I think they are the same yes but il check again
                                      • Paul112004
                                        • Sep 2019
                                        • 14
                                        • United Kingdom
                                        Hi yes all 4 look identical to me
                                        I took few more photos if they are any good
                                        Watched a video last night on a samsung tv the man removed a 8vlegged chip out in this machine then put a new dump into it refitted tov then worked fine
                                        Should hopefully be the same on panasonic tvs
                                        It had exactly the same issue stuck on logo
                                        Il post the link if any help to others
                                        https://youtu.be/TBQsCu0dzUk
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • justice171
                                          JVC LT-50N795 Stuck on Wisdom Share Logo
                                          by justice171
                                          I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                          It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                          Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                          Thanks in advance!
                                          11-04-2024, 02:55 AM
                                        • mr.Data
                                          Macbook A1990 stuck on logo
                                          by mr.Data
                                          This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                          All the normal methods of resetting this Macbook have been tried but do not work.
                                          I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                          Any help would be greatly appriciated....
                                          04-18-2024, 11:51 PM
                                        • platinumsteel
                                          Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                          by platinumsteel
                                          Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                          03-18-2024, 05:16 PM
