BenQ W1070 Projector 5v rail
  • budwich
    • Jul 2015
    • 3097
    Re: BenQ W1070 Projector 5v rail
    Originally posted by bermo96
    When I remove the two regulators UQ1 and UQ3 I have the 5V back, theirs output are shorted to ground in the circuit but when I remove them they aren't shorted. I've removed all the capacitors but the short is still there.
    when you say "all the capacitors" which "all" (ie. numbers) are you referring to?
    • R_J
      • Jun 2012
      • 9588
      There does seem to be a dozen caps on the TVDD_3.3V line and 5 on the CVDD_1.8V line, You can use a 1.5 volt battery and with ground connected, touch the positive from the battery to the shorted line (only for a second at a time) while keeping a finger on the suspected cap, If the ic is shorted it should get hot also.
      1.5 volts is below the 1.8 or the 3.3 the circuit would normally see, so the voltage won't harm the ic.
      • bermo96
        • Jan 2019
        • 45
        • Belgique
        U29 is an ADV7612 (HDMI Receiver), when i remove U29 the shorts are gone and the voltage coming from the two regulators is good. I'm going to order a new one and hope for the best. Thanks for all your answers it was really helpful !
        • bermo96
          • Jan 2019
          • 45
          • Belgique
          I've received the µc and everything is working fine ! Thanks everyone !
          • R_J
            • Jun 2012
            • 9588
            Thank you for following up on the repair. Good to here you have it working.
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
              Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-06-2024, 06:11 AM
            • lefetylorant
              Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
              by lefetylorant
              Hello Everyone,
              Long story short, I got this unit for very cheap.
              I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
              I've performed some measurements:
              - 20V rail perfectly...
              09-14-2023, 05:05 AM
            • bimole
              Weird behavior on 3.3V rail of a CORSAIR CX600
              by bimole
              A colleague gave me an apparently ill CORSAIR CX600.
              He told me that he heard a banging noise, and smelt the magic smoke.
              After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
              I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
              It's another story on the 3.3V rail...
              I have some devices to test deeply PSUs (scope, AC source, electronic load)...
              02-13-2025, 04:49 AM
