BenQ W1070 Projector 5v rail
  • bermo96
    • Jan 2019
    • 45
    • Belgique
    Hi, I've a BenQ W1070 projector and the lamp isn't working, I replaced it but same problem. Then I checked the voltage inside and the 5v rail is showing 2.3V. The commands for the ballast is powered by this 5v rail. I've the schematics but I can't find any 5v regulator an the 5v isn't coming from the power supply board. Can someone help troubleshoot this ?
    Have a nice day
  • budwich
    • Jul 2015
    • 3097
    Re: BenQ W1070 Projector 5v rail
    page 14 is likely where your answer lies but not sure where that circuit actually sit as the page labelling doesn't reference a board.
    • R_J
      • Jun 2012
      • 9625
      U42 is located on page 20, top right side of board, L29 is located near U42
      • bermo96
        • Jan 2019
        • 45
        • Belgique
        Yes I can see the PMD1000 on the board, do you think I must change this IC ? I've checked all the bypass capacitor and they are good
        • bermo96
          • Jan 2019
          • 45
          • Belgique
          Ok so at L29 I've 2,5v at the pin 23 and 2,25v at the pin 24
          • budwich
            • Jul 2015
            • 3097
            how did you check the capacitors?
            Its quite possible that one of the circuits is loading down the 5v circuit.
            • bermo96
              • Jan 2019
              • 45
              • Belgique
              Only for short to ground, but I will check it with my esr meter.
              • budwich
                • Jul 2015
                • 3097
                I had some "5v supply" circuit caps on an xbox go bad... instead of 3300uf, they were 10kuf... so you might be wise to check them. Mine were also visibly in trouble with slight bulged tops.
                • bermo96
                  • Jan 2019
                  • 45
                  • Belgique
                  The caps are good... I've order a new PMD1000, I hope this will fix it.
                  • R_J
                    • Jun 2012
                    • 9625
                    Do you have a good +12v into the ic? I would also check the other output voltages, that might indicate how the ic is working, Check that D14 is ok.
                    On page 6 there are a bunch of regulators that are supplied from the P5v, one of there outputs could be shorted loading the regulator and also lowering the input voltage
                    • bermo96
                      • Jan 2019
                      • 45
                      • Belgique
                      Ok I'll test all the regulators. I must desolder them to test right ?
                      • budwich
                        • Jul 2015
                        • 3097
                        depending on the track layout, you might think about cutting the track of the 5v leaving pmd1000 (some where on the other side of the caps) and see what happens to the voltage which is then basically in "open circuit" mode. that may help determine if the IC is bad or sometime else is sucking it down. Of course, be wise where you do the cut so that you can repair it readily.
                        Further... notice that there two 5v being generated / supplied... have you checked both?
                        • R_J
                          • Jun 2012
                          • 9625
                          I would leave the regulator ic's in place and check for a short to ground on there outputs, If you find one that has its output pin shorted, then I would unsolder it.
                          There are also a couple regulators, (U18 & U20) on page 4, that are feed by the P5V line.
                          You may want to unplug J14 (ballast ?) to rule that out.
                          • bermo96
                            • Jan 2019
                            • 45
                            • Belgique
                            When I remove the two regulators UQ1 and UQ3 I have the 5V back, theirs output are shorted to ground in the circuit but when I remove them they aren't shorted. I've removed all the capacitors but the short is still there.
                            • R_J
                              • Jun 2012
                              • 9625
                              So you have shorts on two different voltage lines? TVDD_3.3V and CVDD_1.8V, page 6, U29 uses both of those supplies.
                              Does the projector turn on without those two regulators?
                              • bermo96
                                • Jan 2019
                                • 45
                                • Belgique
                                Yes TVDD_3.3V and CVDD_1.8V are shorted but only TVDD_3.3V make the 5v disapear. The projector turn on and the lamp is on too. This is fine for me but the power supply make a loud noise (bzzzzz).
                                • R_J
                                  • Jun 2012
                                  • 9625
                                  When you say shorted, what is the actual resistance, Is the noise from the main power supply or from the lamp inverter?
                                  • bermo96
                                    • Jan 2019
                                    • 45
                                    • Belgique
                                    The noise come from the power supply but only when UQ3 is on the board. And the short are close to 0 ohm. I can't find the actual cause of the shorts. It is strange that TVDD_3.3V and CVDD_1.8V are shorted together. The projector turn on fine but the HDMI input are not working.
                                    • R_J
                                      • Jun 2012
                                      • 9625
                                      I would guess that U29 is bad, I looked up the number from the schematic but find nothing. That ic does handle the hdmi signals.
                                      I never did like hdmi, I have seen more blown ic's etc on hdmi inputs than any other input.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        Perhaps it is likely that the draw from the 1.8 isn't great enough to pull down the 5v but puts enough load on some of the power supply points (ie. transformers or such) to make them "noisy".
                                        BUT... it looks like you are making good progress... projector on / lamp on.... what more can you ask for... :-)
                                        Your findings appear to point at the u29 as RJ suggests.... you need a parts listing... :-(
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                          Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 06:11 AM
                                        • lefetylorant
                                          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                          by lefetylorant
                                          Hello Everyone,
                                          Long story short, I got this unit for very cheap.
                                          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                          I've performed some measurements:
                                          - 20V rail perfectly...
                                          09-14-2023, 05:05 AM
                                        • bimole
                                          Weird behavior on 3.3V rail of a CORSAIR CX600
                                          by bimole
                                          A colleague gave me an apparently ill CORSAIR CX600.
                                          He told me that he heard a banging noise, and smelt the magic smoke.
                                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                          It's another story on the 3.3V rail...
                                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                          02-13-2025, 04:49 AM
