Panasonic TX-L37E3B Green light but nothing else..
  • sickboy
    • Jun 2015
    • 86
    Hello everyone.
    So I have this Panasonic TX-L37E3B which when switched on, the green LED flashes rapidly for 2 or 3 seconds, then stays on. No picture and no backlight at all. I can't determine if there's any sound.
    I immediately thought it will be a bad backlight LED so stripped the screen down, but the backlight strip is not like the Vestel ones I'm used to. It's on one aluminium strip at the bottom of the screen. I have a backlight tester but the strip seems more complicated, with 3 wires connecting at each side. I've tested each individual LED and they all work. While the TV is switched on there is zero voltage at the strips however. I cannot test voltage at the exact moment of switch on (I need an extra pair of hands!)
    Does anyone have experience of this model or this fault?
  • Diah
    • Feb 2013
    • 6613
    Re: Panasonic TX-L37E3B Green light but nothing else..
    1- Panasonic always suffer from bad LED back light socket due temperature they mild or the solder will be out of work. take the plate out and inspect the socket first
    if the socket OK. then you have open Zinner Diode on one of the groups which will not forward currents to next LED, need to test them all one by one as diode test. when you change the probe Red black at test it should read diode. and when you reserve the probe it should lid on lightly
    • sickboy
      • Jun 2015
      • 86
      Thank you, do you mean the sockets on the LED strip?
      • Diah
        • Feb 2013
        • 6613
        yes
          https://www.badcaps.net/forum/attach...3&d=1560434141
          You have 4 strings of LED's, One red wire for 4 blue wires for 4 LED strings, same for another set, so the test each string you will remove the connector from the LED driver board then put red probe on red wire and Black probe on each blue wire of the LED set, the do the same for the second set of the LED's.
          • sickboy
            • Jun 2015
            • 86
            Thanks guys.
            I've resoldered the plugs on the LED strip Diah but still the same problem unfortunately.
            Budm, thank you for the info. Using the backlight tester, all 4 strings of LEDs operate correctly with no fault shown. It looks as if my fault lies further back possibly? I'll try and rig something up so that I can monitor the backlight voltage at switch-on.
              You have two set of 4-String, so 8 LED strings total.
              • sickboy
                • Jun 2015
                • 86
                Yes sorry Budm, I meant 4 strings each side. I've just managed to get back to this TV and the first thing I did was test for voltage on the LED plug at switch on and there is none at all, with the plug in or out there are zero volts. I wish I tried that before stripping the screen down lol, lesson learnt.
                Checking around on the small LED driver board it does have a 24v supply, not sure what other voltages should be there though. One electrolytic cap has a voltage rating of 160v but this remains at a steady 24v across it when switching on so clearly somewthing amiss.
                These LED driver boards are really cheap on ebay so I might buy one, but would prefer to get the fault to component level if possible?
                  The 24V is the feeding Voltage to the boost converter circuits (you can see the two inductor 470C printed on top and associate MOSFET's and that LED driver IC. The output should be over 100V when BL-ON signal is present.
                  • sickboy
                    • Jun 2015
                    • 86
                    Happy to report this is now fixed. The annoying thing though was that I needn't have even removed a single screw - never mind disassembling the screen!
                    Someone on another forum pointed me in the direction of a PDF file which described the TV being locked up due to "changes in the way EPG data is now being broadcast".
                    The fix was to power the TV on at the mains while holding the channel up button on rear of the set.
                    I'll try and link the PDF shortly for future forum users. Thanks for everyone's time who tried to help!
                    • sickboy
                      • Jun 2015
                      • 86
                      Panasonic EPG lockout.
                      We have had a number of reported cases of the TV being locked up, i.e. not operating normally.
                      We believe that this is due to the changes in the way EPG data is now being broadcast and
                      found that this primarily affects units produced between 2011 to 2013, and occurs if the
                      TV is left in standby overnight.
                      In order to recover normal operation of the TV, please follow the steps below.
                      (Note: It may not be necessary to carry out all steps, e.g. if TV recovers after
                      step 1 you do not need to carry out steps 2 and 3).
                      Firstly switch off the mains supply and disconnect the aerial from the TV.
                      1) Press and hold the power button located on the unit (not the remote control)
                      and switch on mains supply whilst holding the power button until the unit powers up.
                      Or
                      2) Switch on mains supply, then press and hold the program up button (+) on the side
                      of the unit, until the unit powers up.
                      Or
                      3) Switch on mains supply, press and hold the power button on the unit until the unit powers up.
                      Once the TV has powered up, re-connect the aerial input.
                      To prevent, this phenomenon re-occurring, we advise the following steps are carried out:
                      A) Carry out a shipping mode on the unit and retune stations.
                      B) Turn Off New Station Found function.
                      C) Turn Off New Software Update.
                      D) It is recommended to power off completely and NOT to leave the unit in standby overnight.
                        • 12323
                        • U.S.
                        Nice fix, thanks for sharing.
                          So basically, the broadcaster can screw up lot of people TV's out there.
                          https://www.theregister.co.uk/2014/0..._freetime_epg/
                          I am surprise that it can screw up the TV that bad, but if you only use TV for games or DVD only then you are safe from the screw up.
                          Do you have the link to that web site?
                          • sickboy
                            • Jun 2015
                            • 86
                            It was basically just a link to a pdf file stored on another TV repair forum (and wasn’t accessible unless you were a member of that forum). I didn’t want to risk breaking any forum rules here so instead I copy and pasted the full text of the original pdf above.
                            Presumably Panasonic must’ve given themselves quite a headache with this EPG glitch on older sets. I’m surprised they didn’t foresee it since it seems they played a role in developing the newer EPG data themselves.
                            • MOSSEP
                              Monitor Audio RSW12 - Green light, but no sound
                              by MOSSEP
                              Hi
                              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                              I have already tried replacing all of the...
                              01-26-2025, 08:33 AM
                            • MOSSEP
                              Monitor Audio RSW12 - Green light but no audio
                              by MOSSEP
                              Hi
                              01-26-2025, 08:18 AM
                            • lcdcaps1
                              820-2610-A Sys onewire help, no green light. Please help from the gurus
                              by lcdcaps1
                              Hi
                              I have an 820-2610-A motherboard that has no green light.
                              I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                              From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                              The sys onewire circuit on this model and others is more involved
                              I was hoping if anyone knows about this and how it works, can reply and let me know
                              I know this is an old model but I am sure there are people who still works on these or knows about them
                              I get 1.1v on the C7771 capacitor and will replace...
                              11-06-2023, 01:28 PM
                            • ItepK
                              Panasonic TX-P42G30E green light blinking, no video, no audio
                              by ItepK
                              Hey everyone!
                              I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                              This post describes my entire troubleshooting process of this TV.
                              When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                              I've taken the unit apart, and I've started to check some voltages:
                              • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                              12-22-2023, 05:06 AM
                            • blazzelia
                              MBP A1286 820-2915 green light only, no start
                              by blazzelia
                              Hi guys,
                              I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                              09-30-2024, 07:20 AM
