Hi folks, I am having a problem with a LG 55EC930V. I've checked the power supply, and it only delivers 3,5V. When i bridge the PWR_ON with 3.5V, i ain't got any power at the 12V ans 24V outputs. When i bridged the DRV_ON to start the 24V panel output, i also get no voltage. The power supply is the EAY63348801 B12D198801, but i have no idea where to start fixing the power supply.
LG 55EC930V power supply problem
Re: LG 55EC930V power supply problem
1) So when you bridge (force on) the connection, did you disconnect the cable between the power supply board and the main board first?
2) We need pictures of the whole backside of the TV showing all the boards, and pictures of the the whole board of the power supply board.Never stop learning
Originally posted by budm View Post1) So when you bridge (force on) the connection, did you disconnect the cable between the power supply board and the main board first?
Pictures will be uploaded soon...
Originally posted by Diah View Postwhen you make contact to turn on 12 & 24 V you should hear relay Click. if no Click then you have open SMPS
follow this trouble shooting for yours OLED TV
By the way, this file, i used to test the power supply
Originally posted by Teletoby View PostThe Relay makes a click... but no voltage, and then after a few seconds the relay clicks on and off and on and off, and when i unplug the plug, it becomes faster and faster, until the capacitor is running out of energy i guess then it stops.
2- the first bridge you made for STB as point one 1 in pdf it should remain connected when you do the second bridge and the third
3- still waiting on very clear photo as suggested by other member to the PWB from both side.
Originally posted by Diah View Post1-you need disconnect the socket between PWB and T-CON driver board, also MB should be out from any test connection
Pictures are following...
