LG 55EC930V power supply problem
  • Teletoby
    • Jun 2019
    • 24
    Re: LG 55EC930V power supply problem
    Originally posted by Diah
    take new one and compare the Vlose % & ESR... replace it. if the PWB still no 12 24V replace the PWB. the issue at same section with some SMT component. such Q , the problem we cant find replacement parts.
    ok... i have to check if i have some spare parts with this values.
      When you force on the power supply, are you getting the PFC Boosted Voltage of around 380 ~ 400VDC as measured between the two legs of the main filter caps? The 12V/24VS and 24VD SMPS require that Boosted Voltage to work.
      https://www.shopjimmy.com/lg-eay6334...5ec9300-ua.htm
      https://assets.shopjimmy.com/media/c...348801-top.jpg
      https://assets.shopjimmy.com/media/c...801-bottom.jpg
      • Teletoby
        • Jun 2019
        • 24
        Originally posted by budm
        When you force on the power supply, are you getting the PFC Boosted Voltage of around 380 ~ 400VDC as measured between the two legs of the main filter caps? The 12V/24V SMPS require that Boosted Voltage to work.
        I have to check that hold on...
        • Teletoby
          • Jun 2019
          • 24
          i've measured 318VDC and after a few seconds the relay starts clicking and clicking
            So when you force on the power supply board you only get 318VDC and the power relay is also clicking, correct? You need to check to see if the standby power supply output is also going up and down in sync with the relay clicking or not.
            BTW, can you read the printing on the power relay RL101?
            • Teletoby
              • Jun 2019
              • 24
              The voltage collapses when the relay starts clicking.
              • Diah
                • Feb 2013
                • 6565
                good point budm
                let start with disconect load on 12 24 V SMPS. solder out or take out complete the 6 of them with heat sink HS10
                • Teletoby
                  • Jun 2019
                  • 24
                  good point budm
                  Which one exactly do you mean? Do you have the Numbers?
                  • Teletoby
                    • Jun 2019
                    • 24
                    good point budm
                    Ah i think i found them... Yeah i will solder them out and check them
                    Its D251-D256
                    • Teletoby
                      • Jun 2019
                      • 24
                      I've disassembled the HS10, and i checked them. This is the average value of all of them.
                      • Diah
                        • Feb 2013
                        • 6565
                        can you show us your measurement equipment?
                        • Teletoby
                          • Jun 2019
                          • 24
                          I have a TrueRMS Multimeter Unitest Hexagon. A universal component tester. A Weller Soldering station. Unfortunately my Osci got lost during i moved.
                          • Diah
                            • Feb 2013
                            • 6565
                            ok.. dont do the second short contact as the pdf.. only the first one.. never do now the second one... we need to focus to have the 12 and 24 v on socket 201 and keep all 6 diode out now
                            before that check the Fuse which goes to the transformer T104 and read the voltage of it when you just plug in. the - should be primary section chasis
                              C503, 504 are filter caps for running the STBY SMPS, C503, 507, and 513 are for running the relay, 12V/24VS SMPS, and 24VD SMPS so I would check them all at this point.
                              Q501 is the relay driver.
                              • marcoecca
                                • Feb 2019
                                • villacidro
                                #35
                                hi guys i'm new on this forum and i'm an italian engineer. i wanted to let you know i'm fixing the same defect and if you want i can tell you what i'm trying to fix on this pwb. I have already repaired the 24 volt 20 amp section of the panel power supply. I replaced the L5699ad controllers and the 2nd stage I solved it. now I miss the 12volt section and 24 volts at low current, because despite having replaced everything, I'm still with this section locked. how can I find out something? I'll let you know. ps this TV turned off while they were watching it, and not because of lightning or other problems. it is a recurrent fault but I have to find out the problem because, even if with 100 euro I could replace the pwb, I don't feel like putting it aside but I want to find the real problem, to then make you participate and help the other technicians without having to lose too much time behind to carry out the repair. sorry if I followed the discussion but being new, I still need to get acquainted with your group. I'm using google traslator to translate and I apologize if in some cases there will be misunderstandings. thanks
                                • Teletoby
                                  • Jun 2019
                                  • 24
                                  This would be great!
                                  • marcoecca
                                    • Feb 2019
                                    • villacidro
                                    #37
                                    hello guys to today, unfortunately I'm stuck with the repair because I have not yet found the wiring diagram of the PSU. I even sent an email to LG but without any reply from them and I don't understand why the power supply wiring diagram is not in the pdf of the service manual. I kindly ask you if anyone in the group owns it and I can also pay for the EAY 63348801 service. Thank you very much! Now I am waiting for news because I am stuck and I have no intention of spending euros on a new PSU.
                                      So you do not have the 12V, correct?
                                      Is fuse F102 for the 12V SMPS power supply good?
                                      Are R174, C167 good?
                                      • xmandarkx
                                        • Dec 2013
                                        • 54
                                        hello, apologies for jumping in here but this thread has the most useful information i have found so far, i can start a new thread if needed thou.
                                        i have the same tv but it wont come on, i have tested all the voltages and they are correct but the relay is not clicking on and i have no standby light.
                                        i have the 3.5v on pins 3 and 5 of p2300 and when i jumper pins 1-3 and 5-2 im getting the 24v on pins 8-14 on P202
                                        any thoughts?
                                        thanks in advance
                                        * the power board is EAY63348801*
                                          any thoughts?
                                          thanks in advance
                                          Are you saying that the control Voltages are also correct? You need to post all the power supply Voltage readings AND the control Voltages. It sounds to me that the main board is not sending the control Voltage to turn on the rest of the power supplies.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
