LG 55EC930V power supply problem
  • Teletoby
    • Jun 2019
    • 24
    Hi folks, I am having a problem with a LG 55EC930V. I've checked the power supply, and it only delivers 3,5V. When i bridge the PWR_ON with 3.5V, i ain't got any power at the 12V ans 24V outputs. When i bridged the DRV_ON to start the 24V panel output, i also get no voltage. The power supply is the EAY63348801 B12D198801, but i have no idea where to start fixing the power supply.
    Re: LG 55EC930V power supply problem
    1) So when you bridge (force on) the connection, did you disconnect the cable between the power supply board and the main board first?
    2) We need pictures of the whole backside of the TV showing all the boards, and pictures of the the whole board of the power supply board.
    • Teletoby
      • Jun 2019
      • 24
      Yes i did... the power supply was completely removed from the TV.
      Pictures will be uploaded soon...
      • R_J
        • 9624
        Check F101 and F102 fuses, check the voltage on one of the main filter caps (C620) F501 will be ok if you have standby voltage
        • Diah
          • Feb 2013
          • 6568
          when you make contact to turn on 12 & 24 V you should hear relay Click. if no Click then you have open SMPS
          follow this trouble shooting for yours OLED TV
          • Teletoby
            • Jun 2019
            • 24
            The Relay makes a click... but no voltage, and then after a few seconds the relay clicks on and off and on and off, and when i unplug the plug, it becomes faster and faster, until the capacitor is running out of energy i guess then it stops.
            By the way, this file, i used to test the power supply
            • Diah
              • Feb 2013
              • 6568
              1-you need disconnect the socket between PWB and T-CON driver board, also MB should be out from any test connection
              2- the first bridge you made for STB as point one 1 in pdf it should remain connected when you do the second bridge and the third
              3- still waiting on very clear photo as suggested by other member to the PWB from both side.
              • Teletoby
                • Jun 2019
                • 24
                Yes, i did it exactly as described in the PDF... and i got no other voltages then the 3,5VDC
                Pictures are following...
                • Teletoby
                  • Jun 2019
                  • 24
                  Here are the pictures. In the zip file are the HiRes pictures.
                  • Diah
                    • Feb 2013
                    • 6568
                    check C564 , replace it with same or good esr type
                    • Teletoby
                      • Jun 2019
                      • 24
                      I will do that
                      • Teletoby
                        • Jun 2019
                        • 24
                        could you give me a hint where i can find it?
                        • Diah
                          • Feb 2013
                          • 6568
                          at the primary section near to the 4 Opto
                          • Teletoby
                            • Jun 2019
                            • 24
                            I am not sure which one you mean. I can't find any with this number.
                            • Diah
                              • Feb 2013
                              • 6568
                              sorry C504 not 564
                              • Teletoby
                                • Jun 2019
                                • 24
                                sorry C504 not 564
                                I'll have a look!
                                • Teletoby
                                  • Jun 2019
                                  • 24
                                  sorry C504 not 564
                                  This is the Value of the C504 it seems to be ok!
                                  • Diah
                                    • Feb 2013
                                    • 6568
                                    did you check it out of board?
                                    • Teletoby
                                      • Jun 2019
                                      • 24
                                      Of course
                                      • Diah
                                        • Feb 2013
                                        • 6568
                                        take new one and compare the Vlose % & ESR... replace it. if the PWB still no 12 24V replace the PWB. the issue at same section with some SMT component. such Q , the problem we cant find replacement parts.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
