My Vizio P502UI-B1 TV has no backlight and from what I can tell no image. The TV power indicator turns on for a few minutes then begins flashing for about 30 seconds then turns off. I've tested Power board and that looks good. Even changes the eeprom, but that didnt help. One thing I noticed is that the LED driver board has no power going to the LED plugs. In my image, I can see there is power on the green connection/capacitors but I get no power on the red connections/capacitors. Is it safe to say that the led driver board is bad? Anything else I can check before ordering a new board?
Vizio LED Driver
Re: Vizio LED Driver
You need to check if you are getting PS-ON and BL-ON signals from the main board and if all your voltages are good.
https://www.badcaps.net/forum/showthread.php?t=76708Comment
I don't see anything labelled BL-ON. But I get 2.9V for PS-ON.You need to check if you are getting PS-ON and BL-ON signals from the main board and if all your voltages are good.
PS-ON = 2.9v
BL-ON = Don't see anything labelled BL-On
cn805
Black - 0
Brown - 0
Red - 3.1v
Orange - 0
Yellow - 0
Green - 0
Blue - 0
Purple - 4.9v
Grey - 0.05v (pin 9)
White - 12.14v
cn801,2,3,4 = 0v
It looks like the issue may be with CN805 pin 9 since I'm only getting 0.05v. What should I be testing from here?Comment
cn801,2,3,4 is:
cn801
cn802
cn803
cn804
They all have 0v on all pins, so no power is going to the LED's.
ZD801: 24.3v and 4.3v
D865: 4.03v and 0.05v
C8027: Not shortedComment
There is one labelled On/Off and DIM, but neither are connected to anything. Might be because this TV supports dynamic back light, which is probably controlled by the motherboard. Here is a picture from Shopjimmy of the board.
https://assets.shopjimmy.com/media/c...425xb6-top.jpgComment
Hi, this model commonly has no backlight symptom. Many people try the eeprom as they are sold on eBay and a lot of them available. We just repaired 3 of these models last week all same symptom and all same fix. Failed bga solder on main board. To fix it properly you will need to reball the bga on the main board. To test the theory you can heat the chip alittle and see if your symptom changes. Hope this helps and saves you from buying unneeded parts.Comment
Where is the BGA located on the mainboard? I've already tried replacing the eeprom but no luck.Hi, this model commonly has no backlight symptom. Many people try the eeprom as they are sold on eBay and a lot of them available. We just repaired 3 of these models last week all same symptom and all same fix. Failed bga solder on main board. To fix it properly you will need to reball the bga on the main board. To test the theory you can heat the chip alittle and see if your symptom changes. Hope this helps and saves you from buying unneeded parts.Comment
The model P502UI-B1 is in the eeprom replacement video for M43-C1 on Shopjimmy with no backlight which I repaired by replacing the main board after a new eeprom didn't fix it. Thread linked in post #3. Probably had the same issues.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by Hink85Hi All,
I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors... - Loading...
