Vizio LED Driver
  • Kaveman42
    • Jun 2019
    • 7
    Vizio LED Driver
    My Vizio P502UI-B1 TV has no backlight and from what I can tell no image. The TV power indicator turns on for a few minutes then begins flashing for about 30 seconds then turns off. I've tested Power board and that looks good. Even changes the eeprom, but that didnt help. One thing I noticed is that the LED driver board has no power going to the LED plugs. In my image, I can see there is power on the green connection/capacitors but I get no power on the red connections/capacitors. Is it safe to say that the led driver board is bad? Anything else I can check before ordering a new board?
    Last edited by Kaveman42; 06-10-2019, 11:50 PM. Reason: Submitted before finishing
  • Kaveman42
    • Jun 2019
    • 7
    Re: Vizio LED Driver
    Thought I'd also mention that if the TV is left plugged in, the power indicator comes on then begins to flash then turns off. It keeps doing this until I plug it in. Sometimes I have even heard audio coming from the TV, but not always.
    • neilc6
      • Nov 2015
      • 1550
      You need to check if you are getting PS-ON and BL-ON signals from the main board and if all your voltages are good.
      https://www.badcaps.net/forum/showthread.php?t=76708
      • R_J
        • 9632
        Check if you get +5 volts on CN805 pin 9 of the driver board, all the other pins on cn805 are clock/data lines
        Do you get any voltage on L801,2,3 or 4 when the tv is first turned on, that should be the boosted led voltage.
        • Kaveman42
          • Jun 2019
          • 7
          I don't see anything labelled BL-ON. But I get 2.9V for PS-ON.
          PS-ON = 2.9v
          BL-ON = Don't see anything labelled BL-On
          cn805
          Black - 0
          Brown - 0
          Red - 3.1v
          Orange - 0
          Yellow - 0
          Green - 0
          Blue - 0
          Purple - 4.9v
          Grey - 0.05v (pin 9)
          White - 12.14v
          cn801,2,3,4 = 0v
          It looks like the issue may be with CN805 pin 9 since I'm only getting 0.05v. What should I be testing from here?
          • R_J
            • 9632
            What is cn801,2,3,4 =0v ? Does CN805 pin9 connect to the main board?
            Check the voltage on ZD801 anode and D865 cathode, check if C8027 is shorted?
            • neilc6
              • Nov 2015
              • 1550
              Checking the power supplies on shopjimmy, there should be an ON/OFF pin which should be the backlight control pin.
              • Kaveman42
                • Jun 2019
                • 7
                cn801,2,3,4 is:
                cn801
                cn802
                cn803
                cn804
                They all have 0v on all pins, so no power is going to the LED's.
                ZD801: 24.3v and 4.3v
                D865: 4.03v and 0.05v
                C8027: Not shorted
                • Kaveman42
                  • Jun 2019
                  • 7
                  There is one labelled On/Off and DIM, but neither are connected to anything. Might be because this TV supports dynamic back light, which is probably controlled by the motherboard. Here is a picture from Shopjimmy of the board.
                  https://assets.shopjimmy.com/media/c...425xb6-top.jpg
                  • R_J
                    • 9632
                    I had asked if you had any voltage on L801,2,3 or 4.
                    If ic801 is a aoz1268, pin 2 is the enable pin, see if it connects to cn805 pin 9
                    • nicholas1110
                      • Aug 2012
                      • 127
                      • usa
                      Hi, this model commonly has no backlight symptom. Many people try the eeprom as they are sold on eBay and a lot of them available. We just repaired 3 of these models last week all same symptom and all same fix. Failed bga solder on main board. To fix it properly you will need to reball the bga on the main board. To test the theory you can heat the chip alittle and see if your symptom changes. Hope this helps and saves you from buying unneeded parts.
                      • Kaveman42
                        • Jun 2019
                        • 7
                        Where is the BGA located on the mainboard? I've already tried replacing the eeprom but no luck.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Usually under a heatsink, usually the biggest IC.
                          • neilc6
                            • Nov 2015
                            • 1550
                            The model P502UI-B1 is in the eeprom replacement video for M43-C1 on Shopjimmy with no backlight which I repaired by replacing the main board after a new eeprom didn't fix it. Thread linked in post #3. Probably had the same issues.
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • Hink85
                              Samsung UN65RU8000FXZA Led Driver Board
                              by Hink85
                              Hi All,
                              I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
                              I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
                              08-12-2020, 07:03 AM
