LG 65UH5500 Dead
  • Diah
    • Feb 2013
    • 6374
    Re: LG 65UH5500 Dead
    disconnect the LED driver converter voltes board from power supply and read your voltage of 13 and 80
    • Diah
      • Feb 2013
      • 6374
      if there no change. i advice you to solder out the both transformer near the R you replaced it and check them, they may have bad inside pin connection .. i faced this under other platform
      • hbdeals
        • Oct 2014
        • 55
        No change 45v and 8V.
        The 13 volt rail does pulse from 7 to 8 volts as it "tics".
        • R_J
          • 9535
          What is the voltage across C48, that voltage comes from the circuit that had the open resistor
          Then, using hot ground (TP21) check the voltage on the opto (ic1) pins 3 & 4 (or zd2)
          Voltage on C48=
          Voltage on ZD2 anode=
          voltage on ZD2 cathode=
          RF1 was open, did you check r39 (0Ω). R38 (51Ω), R10 (51Ω) and all 5 diodes
          I know no one wants to believe me but this power supply can operate in standby (burst mode)
          • hbdeals
            • Oct 2014
            • 55
            Voltage on C48=
            Voltage on C48= pulses between 15 and 19.6 volts
            Voltage on ZD2 anode= 0 volts
            Voltage on ZD2 cathode= pulses to 2.5 volts
            • R_J
              • 9535
              Check the voltage across C56, then using hot ground check the voltage on D2 cathode, then ZD3 cathode
              That voltage on C48 may be coming from the ic's startup cell
              When U1 starts, the internal startup cell will produce around 20v on pin 6 (SUPIC), this voltage needs to be sustained from an aux source, In this case that is the VCC supply of T1, Pins 5&6 diodes D4,12,18,19, charging C56. That voltage goes through diode D2, R38, clamped by ZD3 and through R10 to U1 pin6
              • hbdeals
                • Oct 2014
                • 55
                Voltage across C56= 14.8 volts
                D2 cathode= 19.6 volts
                ZD3 cathode= 19.6 volts
                R39 = 0Ω
                R38 = 48Ω
                R10 = 48Ω
                • hbdeals
                  • Oct 2014
                  • 55
                  Which side of ZD3 is supposed to be the cathode. It don't have a stripe.
                  • R_J
                    • 9535
                    zd3 cathode is connected to R10. But I can see there is not enough voltage produced on C56.
                    That 19.6 is coming from U1 and not being produced by T1 VCC winding, check that the winding pin 5~6 is not open.
                    This could just be because the power supply IS in standby.
                    Check the voltage (cold side) on IC1 pin 1 and pin 2 , pin 1 is likely close to 8 volts (comes from 13v supply) pin 2 should be less, Check the voltage across pins 1 & 2, if it is 0 volts the led in the opto is not lit.
                    Find Q1 and short the collector to ground (C is connected to R57) that should turn on ic1
                    • hbdeals
                      • Oct 2014
                      • 55
                      ZD3 cathode is for sure 19.6v
                      T1 VCC winding 5 to 6 = 0Ω
                      IC1 Pin 1 = 6.7v
                      Pin 2 = 5.7v
                      Across Pins 1 and 2 = .98v (1volt)
                      • Diah
                        • Feb 2013
                        • 6374
                        okay. put the socket back. and just disconnect the LED back light socket from driver board and check you still have the tics ?
                        • hbdeals
                          • Oct 2014
                          • 55
                          It tics no matter what's connected. I think this TV was a clock in a previous life.
                          • Diah
                            • Feb 2013
                            • 6374
                            may be..LOL or yours hair dryer u used before was soldering hot air gun..LOL spare time and replace this boards but be alarm that you will just go back to first point to read 80 13 volts only
                            • Diah
                              • Feb 2013
                              • 6374
                              can we see you DM you used measuring the 80 Volts and 13.. where you put the probe and on which setting your DM
                              • hbdeals
                                • Oct 2014
                                • 55
                                At least then, it didn't tic. I'm using a good digital meter.
                                • hbdeals
                                  • Oct 2014
                                  • 55
                                  I did that, and get these voltages now.
                                  IC1 Pin 1 = 8.2v
                                  Pin 2 = 7.5v
                                  Across Pins 1 and 2 = pulses to 1.5v
                                  • R_J
                                    • 9535
                                    So with Q1 collector connected to ground, you had 1.5v across the opto pins 1&2 did the power supply give you 13 & 80volts? if not we can confirm that the opto is working by checking the:
                                    with 1.7 volts across pins 1 & 2, the voltage on ZD2 should be very close to the same on anode & cathode.
                                    Do you ever get the full 13 & 80 volts like you did before?
                                    • hbdeals
                                      • Oct 2014
                                      • 55
                                      Voltage across ZD2 starts out at 3.8 volts, then with each (tic) it drops in voltage until it reaches 2.2 volts and then recycles at 3.8 volts.
                                      Voltage on ZD2 anode= 0 volts (at times it hit .5 volts maybe) strange
                                      Voltage on ZD2 cathode= 2.5 to 3.7 and anywhere in between on the (tics)
                                      80v and 13v are still 45v and 8V
                                      • R_J
                                        • 9535
                                        so when you have 1.7 volts across pins 1 & 2 of the optocoupler (led side), the photo transistor side (pins 3 & 4) should be conducting and close to the same voltage on each pin so the same voltage should be on both pins of the ZD2 diode.
                                        You could have a bad optocoupler. Whats the number on it?
                                        You could monitor either 13v or 80v supply line and short pins 3 & 4 of the optocoupler, if the opto is at fault the voltage should come up to or slightly above spec.
                                        • hbdeals
                                          • Oct 2014
                                          • 55
                                          I'll see if I have any spares.
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • Nagyesz
                                            Lenovo ideapad 330ICH - Dead, no volts on coils
                                            by Nagyesz
                                            Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                                            I've never encountered something like this before;
                                            No charging light, full dead
                                            Lenovo Ideapad 330-17ICH
                                            • PL3102: 5 ohms
                                            • PL3001: 3.2 ohms
                                            • PL3101: 2 ohms
                                            • PL5801: 3.5 ohms
                                            • PL5501: 270 ohms
                                            • PL701: 35 ohms
                                            • PL501: 146 ohms
                                            • PL503: 390 ohms
                                            • PL402: OL (0.27V) +5VALW_P
                                            • PL301: OL
                                            • PL401: OL (0.03V) +3VALW_P
                                            + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                                            10-11-2024, 10:12 AM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • Ghostalker
                                            Zephyrus G14 GA401QM dead
                                            by Ghostalker
                                            Hello I have an ASUS Zephyrus Laptop (Model GA401QM), bought on ebay and the previous owner claims he was using and the laptop stopped, He then tried to change battery and broke the connector on the battery and also on ripped a GND pad on the MB.
                                            I was searching on internet and found two posts on this forum about a similar problem “ASUS ROG G14 (GA401) battery spark, dead.” and “Dead ASUS ROG G14 (GA401)” both by the user jacobtc.
                                            I already made some measurements based on the “Dead ASUS ROG G14 (GA401)” post using GA401QM schematic provided here and Boardview provided...
                                            09-06-2023, 03:20 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
