Samsung 39 LCD TV no light
  • yobbgsm
    • May 2017
    • 63
    I have an exactly the same issue with this post, any idea please?
    https://www.badcaps.net/forum/showpo...9&postcount=19
    Re: Samsung 39 LCD TV no light
    Well, did you at least make any Voltage measurement to see what you get?
    • yobbgsm
      • May 2017
      • 63
      Yes, same as mentioned above. Sometimes 206V or 210v. As quoted below.
      "I have voltage only on 1 - D+ and 2 D+, When i switch the tv on voltage goes up to 221 the comes down to 218 on these two connections. I have no voltages on other pins."
      • diif
        • Feb 2014
        • 6978
        • England
        Why not fix it exactly the same way?
        • yobbgsm
          • May 2017
          • 63
          What's the fix?? That post was not fix. Same here I replaced the leds but it keep on blowing up...
          • diif
            • Feb 2014
            • 6978
            • England
            What LEDs did you use. They didn't answer the question.
            • yobbgsm
              • May 2017
              • 63
              Hi diif,
              I used same 3v led, 3528 2835 1W. There is an a 8 leg IC close to CNL802, I am wondering if that is a led driver IC?
              https://www.badcaps.net/forum/attach...1&d=1510788361
              • diif
                • Feb 2014
                • 6978
                • England
                Hi diif,
                Some LEDs have the anode and cathode switched around, did you check you have the correct ones ?
                What's the markings on the IC ?
                • yobbgsm
                  • May 2017
                  • 63
                  I tested the LEDs using my backlight tester. All strips / led are good prior to installing. IC appears 421 3013x 8609. That's the marking.
                  • R_J
                    • 9550
                    The ic's number is 3013X
                    • yobbgsm
                      • May 2017
                      • 63
                      Its a Octal, 8-Bit Voltage Out DAC, not sure if that is related to the LED supply?
                      Thanks.
                      • R_J
                        • 9550
                        Nope, It is a 3013x, Very similar to a HV9910B or TS19450 LED DRIVER
                        The other numbers are mfg./date codes
                        • yobbgsm
                          • May 2017
                          • 63
                          Thanks guys I was able to resolved this issue. It's the backlight I changed all the beads.
                            09-07-2024, 05:50 AM
                          • Kaar3l
                            Samsung QLED QE65Q7FNAT only standby light
                            by Kaar3l
                            TV: Samsung QLED QE65Q7FNAT
                            PSU: BN4400940A
                            MB: BN94-12832K
                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                            09-24-2024, 01:35 PM
                          • marcinq
                            Samsung UE60KS7000 No Standby Light
                            by marcinq
                            I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                            I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                            05-26-2025, 11:36 AM
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
                          • DXseekerMO
                            Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                            by DXseekerMO
                            Hello everyone!
                            Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                            Symptoms:
                            1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                            2) TV does not appear to turn on
                            3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                            4) "Power on" terminal on Power Supply has 3.26v
                            5) "A13V" terminals have 12.9v
                            6) Stand-by test jumper on Power Supply has 12.9V
                            7) Optical audio jack on Main Board illuminates
                            8) With stand-by...
                            06-09-2021, 12:19 AM
