Celcus DLED32167HD Dim Backlights - Sound but no Picture
  • sickboy
    • Jun 2015
    • 86
    I have the TV in the title which uses common Vestel chassis with 17IPS11 PSU and 17MB55 main board.
    When the TV switches on it gives a blank screen with normal backlight brightness (but no picture content) for maybe 2 seconds, then the backlight goes quite dim, but definitely still on. Sound works as normal.
    There's nothing on the screen at all when you shine a bright light onto it.
    The strange thing is that voltage on the backlight positive pin stays constant at around 85v whether bright or dim, the negative pin is around 30v - is this normal?
    Can anyone give me any pointers on how best to tackle this?
  • sickboy
    • Jun 2015
    • 86
    Re: Celcus DLED32167HD Dim Backlights - Sound but no Picture
    Tried freezing the eprom but it made no difference
      • 12113
      • U.S.
      Check tcon fuse, see if you have voltage on each side, negative probe on chassis ground positive on each side of fuse.
      • sickboy
        • Jun 2015
        • 86
        Appreciate your help. I've got -12v DC either side of the fuse, that's minus 12v. Is that normal?
          What did you use for GND? It cannot be minus reading, you probably has the Test probes connected wrong on the meter or on the tested end, etc... but at this point it is more likely that you do have +12V feeding the T-CON board.
          • sickboy
            • Jun 2015
            • 86
            I'm an idiot lol
            You're correct, I had the test probes in the wrong way round at the meter end..
            12v DC on the TCON board
              Can we see the pictures of the T-Con board?
              Does it have two ribbon cables between T-CON and the LCD panel? If it does then try having one ribbon cable connected one at a time to see what you see on the screen.
              • sickboy
                • Jun 2015
                • 86
                Big wide tcon board Budm, looks like it's directly bonded to the screen via one wide ribbon... so it's safe to say if the tcon board is at fault the set's a scrapper
                  Oh, it has integrated T-CON board, you can check the resistance of the MLCC (Muti Layer Ceramic Cap) to see if any one of them shows low resistance readings.
                  • sickboy
                    • Jun 2015
                    • 86
                    I can get the main board for this model (and screen number) on eBay for £14, is it worth a try? Or do you think it's most likely a tcon problem?
                    Edit: oops never saw your previous reply there, I'll try and find these MLCC devices and report back.
                    • sickboy
                      • Jun 2015
                      • 86
                      Ok, I wasn't quite sure which of the SMD caps you meant, but I tested all of the larger smd caps on the tcon but none had low resistance.
                      Here's some close-ups of the tcon if they help.?
                        Check them all.
                        I also see some Voltage test points that you should check, I.E. VCC, VSS, VCOM, etc....
                        • sickboy
                          • Jun 2015
                          • 86
                          Ok, test points as follows:
                          VDD1 = 0.58V
                          VDD1L = 0.58V
                          VSS = 0.8V
                          V0FFE = 0.2V
                          VCC = 0.58V
                          F_VCOM = 0.1V
                          V0NE = 0.0V
                          VCOM = 0.58V
                          F_VCOMR = 0.58V
                          I have to go out for the rest of the morning but when I get back I'll check some more components with power off. There a few diodes and plenty of resistors with a zero on them to test.
                          • sickboy
                            • Jun 2015
                            • 86
                            Well, nothing out of the ordinary found after some cold testing.
                            Could it be firmware causing this? I still have the option of buying a used mainboard - to rule it out if nothing else.
                            Other than that I think I have to assume the tcon board is faulty, and as it's bonded to the screen I'll probably just save the power board and main board then bin the rest.
                              • 12113
                              • U.S.
                              Your call, you could try the mainboard, suppose you could resell it if it isn't the issue.
                                VDD1 = 0.58V
                                VDD1L = 0.58V
                                VSS = 0.8V
                                V0FFE = 0.2V
                                VCC = 0.58V
                                F_VCOM = 0.1V
                                V0NE = 0.0V
                                VCOM = 0.58V
                                F_VCOMR = 0.58V
                                You sure do have problem on that integrated T-CON board based on those Voltage readings. You may want to trace out the VCC line to see why it is so low, typical VCC will be 1.8V, or 3.3V.
                                • stinger
                                  Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                  by stinger
                                  When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                  04-17-2024, 03:06 PM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
                                • jchang
                                  Samsung UN70NU6900F no picture and no sound
                                  by jchang
                                  Hi all
                                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                  Symptom:
                                  No picture no sound.
                                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                  No sound at all.
                                  What I tried:
                                  1. I tried unplugging the left or right ribbon...
                                  01-09-2023, 06:28 PM
