Samsung UE55H7080 black screen (sound is working)
    Re: Samsung UE55H7080 black screen (sound is working)
    Pictures provided by shopjimmy.
    There are many test points on the T-CON, some may be under the heatsink too.
      OK, since you can get backlights to come on by disconnecting the EXT 1 (connector with 6 black wires) and having EXT 2, 3, and 4 connected, since T-CON board does not need EXT 1 to be in place for T-CON to work (because it is the control signal sender to control the backlights level) then you can leave EXT 1 out for now.
      Next remove EXT3 then turn on the TV, the backights should be on and then observe what you see on the screen, then turn off the TV.
      Next, put EXT3 back in place, then remove EXT4 and turn on the TV, the backlights should be on then observe what you see on the screen.
      • Diah
        • Feb 2013
        • 6396
        YOURS OP that this set was working at night and next day only sound..??? are you sure the set was yours for long time ?
        BL come on when you disconnected MB from PSU or Dim socket from T-con doesn't mean BL are OK. because protection level at software was out .. disabled
        hard ware protection on PSU cant detect fault of open LED- it response only for short. only software detection can do this and this is the case
        first things you need to check visual by eyes all BL led going on by test.. if not and the sets belong to you long time.. change T-con. if you got this TV from some one then Panel fault or damaged
        • Steradiant
          • May 2019
          • 29
          • Austria
          #44
          The last weeks I was really terribly busy. I had no time to check more on the T-CON board, hence, I decided to buy a new one (or let's better say a working one from another TV from ebay). The TV works again!!!
            • 12206
            • U.S.
            #45
            Ok good job, you went a long mile, if I can find a low priced tcon and I have the symptoms, sound always present, no picture with torch test etc. I grab the tcon. I've also spent 20 hours testing this and that and chasing wild possibilities but was just a faulty tcon, sometimes if it looks walks and quacks like a duck, it's just a duck.
              • 12206
              • U.S.
              #46
              A good fact to remember at least for this particular model is a faulty tcon can keep the mainboard from sending the proper bl-on signal.
                Originally posted by jeffreyulrich
                Buy a bn44-00715a directly, no need to repair it
                htt******************************tml
                Did you not read which the faulty board is? Or you are just trying to sell boards? Read post #44.
                • ngth82
                  • Jul 2015
                  • 541
                  Looks like the guy has nothing but posts to that website. Anyway to ban?
                  -Thomas
                  I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #49
                    Anyone can report a spammer, if you click on the triangle road traffic sign looking thing under a username.
                      • 21087
                      The spam post is deleted,user banned and Budm`s post with the spam link edited. Cheers diff
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • mrtek
                        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                        by mrtek
                        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                        11-26-2024, 09:58 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • mar1in
                        Samsung TU8000, backlight and sound on, stuck in blue screen
                        by mar1in
                        I've got this Samsung here that would be stuck in a boot loop.
                        After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                        Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                        Thanks in advance
                        11-08-2023, 05:43 PM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
