intermitted shutdown at high brightness
  • Demonata08
    • Jan 2019
    • 116
    Just curious. What board is typically at fault in a lcd tv that shuts down around 10-20 minutes. It turns right back on and normally works fine after it goes off. Lowering the brightness seemed to elevate the issue.
    all caps on the P board and the voltage is all good. I can post pictures if needed but im just curious what the typical issue is.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: intermitted shutdown at high brightness
    Faulty LED(s)
    • petehall347
      • Jan 2015
      • 4438
      turn back lights down problem solved for now and x amount of time .
      • Demonata08
        • Jan 2019
        • 116
        Originally posted by diif
        Faulty LED(s)
        It fails after about 2 minutes even if the panel isnt plugged up and just with the backlight. with it unplugged i can still hear the sound. it goes off at the same speed ><
        the voltage is steady 13 until it recieved the error signal. thinking its the main board at the moment
          Makes, model, and pictures will help since we have no idea what you have at all.
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Is it LG?
            • Demonata08
              • Jan 2019
              • 116
              Its a sharp lc-c3234u i believe. I learned something new about esr testing. So right now the p board may actually be the problem. Got an esr meter on the way now.
              • nomoresonys
                • 12272
                • U.S.
                Heat the powerboard with a hairdryer, see if tv stays on longer.
                  You need to show us the pictures of the whole backside of the TV showing all the boards, this TV has more than one versions: It has CCFL backlights.
                  https://www.shopjimmy.com/catalogsea...harp+lc-c3234u
                  • Demonata08
                    • Jan 2019
                    • 116
                    Heres the back.
                    Thanks guys.
                    • Demonata08
                      • Jan 2019
                      • 116
                      So just a quick update. ive now went through every component on the power board that i can check. the esr meter i got in has shown every capacitor is in excellent condition except the two big ones on the board. They are 220v 470uf but are showing 450uf, .23esr, I do believe thats close enough to the marked value to not cause problems, but since everything else on the board is good im not sure what else it could be.
                      I do notice when its on the main transformer gets remarkably hot. Not like, burn to the touch hot, but still pretty hot.
                      • jetadm123
                        • 2169
                        Sounds like you have a heat related problem. Maybe a bad solder joint? I suggest you do as nomoresonys recommended and heat up each board with a hairdryer to see if you can shorten the shutdown time.
                        • Demonata08
                          • Jan 2019
                          • 116
                          I shorted out the error detection on the power supply board to see if it was the LEDs or power supply and so far its been on for about an hour at full brightness. I have no idea what to think about that.
                          Ive been thinking it was either the leds or the power supply board. if i short out the error code it wont turn off when it detects an error so if the leds are bad i can shine a light through the tv and see the picture and if its the power supply i would imagine the whole tv would just power off.(or so thats my thinking)
                          gonna continue to let it run and see what happens.
                            Your TV dose not use LED for backlights, it uses CCFL for backlights. If one lamp is bad it will shutdown the inverter circuit.
                            Remove the inverter board from the sockets and inspect the sockets and the contact fingers of the inverter board that fit into the sockets.
                            Try turning down backlights level (not Brightness) to see if it will take longer for the backlights to go off. You may have worn backlights, you can also check to see if any one of the Inverter transformer is hotter that the other, check it after the Bcklights go off and TV is unplugged.
                            • Demonata08
                              • Jan 2019
                              • 116
                              Yep didnt realize the led thing when i was thinking about it. went back to it and realized afterwards. There wasnt any kind issue with the sockets that i could see. I wasnt sure how to test the inverter transformer and i had already had a power supply from a similar board with the same exact numbered inverters. so i swaped them over carefully and so far its been on for about 4 hours straight at highest backlight. I'm not sure which one of these transformers is bad, i wish i did, because i feel like itd be a good spare part to have around haha.
                              But either way its fixed, hazzah!
                              (EDIT: I shouldnt say its fixed just yet. Im gonna let it run for the rest of the day, But it before it would last around 5 minutes at high backlight so im pretty confident it is fixed )
                              • nomoresonys
                                • 12272
                                • U.S.
                                Was probably just one bad transformer, some model tvs are easier to test transformers than others.
                                • Demonata08
                                  • Jan 2019
                                  • 116
                                  I have a pretty good feeling it was just one. But short of taking turns putting one at a time back in til it errors again is way not worth my time.
                                  This one stayed on for 24 hours straight so i felt comfortable enough selling it. As it turns out the exact same model with the exact same problem has popped up again except this one only stays on for a few seconds(not enough time to adjust the backlight) im gonna crack it open in a few days and hopefully its the same problem.
                                  • nomoresonys
                                    • 12272
                                    • U.S.
                                    NAH, I wouldn't do that either, I'd just test each transformer. http://jestineyong.com/test-lcd-inverter-transformer/
                                    • Flybacks
                                      Grundig CUC 2401 CRT TV - Brightness is too high
                                      by Flybacks
                                      Hello, I'm trying to fix a Grundig CUC 2401 with picture brightness too high.
                                      The problem seems to be in the brightness voltage supplied by pin 16 of TDA8442 that should be in the 1-3V range instead it is about 3.2V.
                                      If I manually lower the brightness the voltage goes in the right range of about 2V and doesn't increase but I don't understand why at start up it is set wrong ?
                                      I've already changed TDA8442, the video output IC TDA3505 and the microcontroller IC811 but it didn't fix.
                                      The collector of RGB transistors on crt board are about 170V for red and blue but 150V...
                                      12-30-2021, 07:20 AM
                                    • kacangpolo
                                      Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                                      by kacangpolo
                                      I have problem with my laptop, with code board X415EA 2.0,
                                      laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                                      I did :
                                      1. Flash Bios
                                      2. RTC_RST 3.3V
                                      3. LID_SW 3.3V
                                      4. WLAN_WAKE# 3.3V
                                      08-26-2025, 04:42 AM
                                      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                      I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                      02-04-2025, 08:08 PM
                                    • DynaxSC
                                      Extreme High Current & Low Voltage Short Killer ??
                                      by DynaxSC
                                      Hi Folks
                                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                      After taking off the socket, the shorts dissappear again.
                                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                      10-15-2024, 10:13 AM
                                    • cruiser_
                                      A1466 820-00165 intermittent shutdown
                                      by cruiser_
                                      hi there,
                                      Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                                      Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                                      Gives shutdown cause -128.
                                      Seem to work fine in SMC bypass.
                                      Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                                      Observations:
                                      - SMC_RESET_L - when pulled down - plug goes orange/green and...
                                      10-11-2022, 12:06 PM
