Grundig CUC 2401 CRT TV - Brightness is too high
  • Flybacks
    • Nov 2021
    • 13
    • Spain
    Hello, I'm trying to fix a Grundig CUC 2401 with picture brightness too high.
    The problem seems to be in the brightness voltage supplied by pin 16 of TDA8442 that should be in the 1-3V range instead it is about 3.2V.
    If I manually lower the brightness the voltage goes in the right range of about 2V and doesn't increase but I don't understand why at start up it is set wrong ?
    I've already changed TDA8442, the video output IC TDA3505 and the microcontroller IC811 but it didn't fix.
    The collector of RGB transistors on crt board are about 170V for red and blue but 150V for the green, shouldn't be all equal ?
    Could someone please help me to troubleshoot it ?
    Schematic: https://elektrotanya.com/grundig_cuc.../download.html
    The TDA8442 is at page 4
    Many thanks!
  • R_J
    • Jun 2012
    • 9553
    Re: Grundig CUC 2401 CRT TV - Brightness is too high
    Too high brightness can be due to a bad screen bypass capacitor, this cap is usually near the hi voltage/flyback transformer and is usually an electrolytic with a value of 2.2µf ~ 10µf 250v ~350v (C515?)
    Check CT741 2.2µf/350v on the crt drive board.
    The voltages on the rgb outputs will not be equal because the ratio to make white is not equal. roughly 30% red, 59% green, 11% blue
    • Flybacks
      • Nov 2021
      • 13
      • Spain
      Hello, the screen voltage is correct I don't think it is related to that because lowering the brightness manually from the menu option fixes the problem and pin 16 of TDA8442 goes in the right range of about 2V.
      But every time I switch on the tv it comes back to 3.2V and I have to lower brightness again.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Is that the only setting that does this?
        • R_J
          • Jun 2012
          • 9553
          Could it be a bad cap on that line? C9548 (4.4µf/16v) [page 28]
          As for the screen voltage, even if it is close to correct, the high frequency ripple from the supply can effect the screen.
          • Flybacks
            • Nov 2021
            • 13
            • Spain
            The voltage of contrast and colour of pin 1 and 2 of TDA8442 are also a little higher but don't disturb the picture as much as the brightness.
            I've already replaced C9548 but didn't fix it
            • dskall
              • Oct 2016
              • 2905
              • usa
              Are these settings digitally set? Values stored in eeprom.
              • Flybacks
                • Nov 2021
                • 13
                • Spain
                Yes they are digitally set.
                On the tv there are two eeprom, one is SDA2216 inside the tuner unit (page 11 of schematic) and the other is on the teletext board (page 17, there are two SDA2216 on the schematic but my teletext board only has one SDA2526).
                Could any of these store the brightness value ?
                Or could be stored inside IC811 and sent to TDA8442 at start ?
                Thank you
                • Nick868
                  Grundig High Performance Cyclone Battery Led blinking
                  by Nick868
                  Hello there,
                  i've got a a grundig high performance cyclone that seem the board doesn't charge the battery. What should i check? I notice that d6 is very hot
                  07-27-2024, 05:00 AM
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                  LM358 LM358S-13 Datasheet
                  The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                  Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                  10-07-2024, 04:12 AM
                  ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                  Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                  The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                  for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                  Narrow VDC applications where the system power source is
                  either the battery pack or the regulated output of the charger.
                  This makes the max voltage to the system equal to the max
                  battery voltage instead of the max adapter voltage. Operating
                  at lower system voltage can improve...
                  11-05-2024, 04:43 PM
                  Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                  I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                  I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                  I tested the battery cells there are installed right now and they are testing good with no issues that I...
                  02-04-2025, 08:08 PM
