LG service menu
  • sordids999
    • May 2013
    • 2161
    • uk
    LG service menu
    Hi guys
    Just wanted some advice changed complete set of backlights on a lg47ln578v but I'm wondering can you set up to keep backlight on say 70% in the service menu I have got into ez adjust and set this to 70 but everytime the TV turns off it's back on 100% when I turn it on again
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    Re: LG service menu
    Isn't there a normal B.Light setting in the user menu? Why to choose for a service menu item?
    • neilc6
      • Nov 2015
      • 1550
      Re: LG service menu
      I think the setting in the service menu is for the default for eco mode.
      • sordids999
        • May 2013
        • 2161
        • uk
        Re: LG service menu
        What I'm saying is everytime I set it to say 70% on backlight it changes back to 100 % so i was just wondering if i could permanently set it to 70%
        • Diah
          • Feb 2013
          • 6614
          Re: LG service menu
          at EZ-Adjust after change the value press OK, i am not sure if it work as service RC Save.
          however this value will effect on LOGO start up only before the firmware will start and the actual BL level come in place.
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • alltvrepairs
            Jvc Lt-65VU3000 reduce backlight from service menu
            by alltvrepairs
            I have just replaced led set of this vestel tv due to age.
            I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
            Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
            Thanks again....
            09-20-2025, 05:03 AM
          • sohail5307
            I need how to open this Dell service menu option in dell latitude e6420
            by sohail5307
            I need to open service menu of Dell laptops like image in attachment
            Ignore my English
            I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
            01-13-2023, 05:56 AM
