LG service menu
  • sordids999
    • May 2013
    • 2155
    LG service menu
    Hi guys
    Just wanted some advice changed complete set of backlights on a lg47ln578v but I'm wondering can you set up to keep backlight on say 70% in the service menu I have got into ez adjust and set this to 70 but everytime the TV turns off it's back on 100% when I turn it on again
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4346
    • Italy - Milan
    Re: LG service menu
    Isn't there a normal B.Light setting in the user menu? Why to choose for a service menu item?
    • neilc6
      • Nov 2015
      • 1550
      Re: LG service menu
      I think the setting in the service menu is for the default for eco mode.
      • sordids999
        • May 2013
        • 2155
        Re: LG service menu
        What I'm saying is everytime I set it to say 70% on backlight it changes back to 100 % so i was just wondering if i could permanently set it to 70%
        • Diah
          • Feb 2013
          • 6380
          Re: LG service menu
          at EZ-Adjust after change the value press OK, i am not sure if it work as service RC Save.
          however this value will effect on LOGO start up only before the firmware will start and the actual BL level come in place.
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • sohail5307
            I need how to open this Dell service menu option in dell latitude e6420
            by sohail5307
            I need to open service menu of Dell laptops like image in attachment
            Ignore my English
            I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
            01-13-2023, 05:56 AM
          • Daniel Valdez
            Samsung UN70RU7100K halfway bricked after messing with service menu
            by Daniel Valdez
            Dear All,
            FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
            12-06-2024, 06:56 PM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
