LG 49UJ701V (Display Problem)
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    hi guys I have the above tv,
    I've now got a problem with after a year of use the screen is now garbled then normal and then garbled but the top is perfect.
    the tab bonds are at the bottom of the tv I have checked by pressing on them lightly to see if the symptom changes but sadly it don't,
    ive noticed the tcon is all part of the mainboard on this TV,
    could it be the tcon has failed ?
    as if I disconnect one side of the panel I get a perfect picture and a grey screen on the side disconnected.
    but if I disconnect the working side of the panel and then leave the opposite side connected I just get a black screen on the half nothing else.
    thanks for any help
    Jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: LG 49UJ701V (Display Problem)
    here is 2 photo's of the fault I forgot to add them to my original post I will also post a video shortly
    thanks
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • Diah
      • Feb 2013
      • 6376
      one by one do folowing
      1- send command IN-Stop to reset the TV , use android apk with any mobile built in IR sender ( we post it over here many time at LG posts )
      2- clean the LVDS and reset it then check
      3- use pressure from the TOP on the Main Board and check
      • jasonr2000
        Advance Tech
        • Nov 2013
        • 209
        hi Diah thanks for the reply,
        I will check all that you have said but here is a video of the fault.
        https://youtu.be/ppzGPuoXgnE
        Samsung UE46D6530
        Samsung BD-F7500
        Samsung HT-ES6200
          It looks like Gate drive problem in the panel.
          • Diah
            • Feb 2013
            • 6376
            its look disruption from right side tap. but let hope first with first test i mentioned
            please upload whole photo of the tv boards at back side.
            • Unspun01
              • Jun 2011
              • 349
              Hi jasonr2000:
              Could be a panel problem.
              I have a 50" LG LED TV model 50LN5700. The TV works but has a similar fault as yours (good image on top 2/3s of screen and double vision on lower 1/3).
              The boards work properly with a different (good) panel.
              The (bad) panel produces the same problem with different (good) boards from another TV.
              My panel problem is permanent and does not flicker or change over time.
              Your problem may be fixable if you can find out what part is intermittent.
              I'm not saying your problem is the panel for sure, but on my TV with similar issue it is the panel.
                • 12206
                • U.S.
                Try turning backlights down if possible, see if your double image gets any better.
                  • 12206
                  • U.S.
                  The "cut tape" method might get you a good image.
                  • jasonr2000
                    Advance Tech
                    • Nov 2013
                    • 209
                    hi guys thanks for the reply
                    all of what Diah suggested didn't make a difference,
                    also its not the backlight that seems to be the issue here,
                    I've adjusted that and no change to the image,
                    what else would you guys suggest I try ?
                    Samsung UE46D6530
                    Samsung BD-F7500
                    Samsung HT-ES6200
                    • jasonr2000
                      Advance Tech
                      • Nov 2013
                      • 209
                      pictures as requested
                      thanks all
                      Samsung UE46D6530
                      Samsung BD-F7500
                      Samsung HT-ES6200
                      • jasonr2000
                        Advance Tech
                        • Nov 2013
                        • 209
                        hi budm is there anyway I can find the fault ?
                        as I know on the side of the display panel there is no side bond tabs at all.
                        Samsung UE46D6530
                        Samsung BD-F7500
                        Samsung HT-ES6200
                        • Diah
                          • Feb 2013
                          • 6376
                          UHD panel had on side taps. and yours T_con on the down side TAP start with left side when u stand facing the panel
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            how does one do the cut tape method ?
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • jasonr2000
                              Advance Tech
                              • Nov 2013
                              • 209
                              sorry im new to all this can you explain what you mean (probably sound thick more of a Computer TECH)
                              Samsung UE46D6530
                              Samsung BD-F7500
                              Samsung HT-ES6200
                              • Diah
                                • Feb 2013
                                • 6376
                                well i don't believe on repair by cutting taps bond.. but you can start as i read over here.. the side which you disconnected and got perfect half picture. try to cover the first 4 line with thin type from left of the LVDS at panel side then set it in place. hope u will have the disruption out from screen
                                • jasonr2000
                                  Advance Tech
                                  • Nov 2013
                                  • 209
                                  hi diah thanks for the reply,
                                  ill try what you have suggested and go from there first,
                                  I've nothing to lose as the tv is not in warranty no longer,
                                  could it be the mainboard is bad ?
                                  thanks
                                  Samsung UE46D6530
                                  Samsung BD-F7500
                                  Samsung HT-ES6200
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    thanks
                                    i think yours discounted LVDS you did it from MB side... you need to reset them from Panel side too
                                    • jasonr2000
                                      Advance Tech
                                      • Nov 2013
                                      • 209
                                      hi Diah I have reseted them both sides cleaned them with isopropyl alcohol and made no difference although as I've said previous,
                                      if I disconnect the one side I get a perfect picture and if I disconnect just the other side I get a black screen,
                                      im going to try the tape trick and see how it goes (im sure it can't get any worse)
                                      thanks for the reply's so far.
                                      Jason
                                      Samsung UE46D6530
                                      Samsung BD-F7500
                                      Samsung HT-ES6200
                                      • jasonr2000
                                        Advance Tech
                                        • Nov 2013
                                        • 209
                                        hi again,
                                        I have tried the tape fix got a picture of a normal variety but I've noticed now the colour is off on the left side of the screen where the fault existed
                                        I've taken a photo but I dunno if it will come out or not,
                                        Samsung UE46D6530
                                        Samsung BD-F7500
                                        Samsung HT-ES6200
