LG 47LN5400 - Overlay shift?
  • jason123
    • Oct 2015
    • 1068
    Just need an opinion on this please?
    Got this smaller 47" TV - initially, no backlight, turns out the connector for the Backlight is not plugged in all the way. Yay - easy fix.
    However the picture quality is off. With black background, about 1/5 or so of the left of the screen is brighter color (Almost like a lighter band) when the picture comes on the left hand side seems ok.
    However when the menu is turned on, the right hand side 1/5 of the screen shows color issues. Seems the overlay vs. picture is shifted and not aligned. See photos. TCON board? this has the usual Main, TCON and PS boards.
  • CapLeaker
    Leaking Member
    • 8153
    Re: LG 47LN5400 - Overlay shift?
    I'd go for the Tcon board.
    • jason123
      • Oct 2015
      • 1068
      Got the TCON today, and it does exactly what my original TCON is doing. Could it be the panel, or would a main board replacement fix this? Thoughts?
      • Diah
        • Feb 2013
        • 6370
        on LG plat forum LED LCD TV even also OLED, the first things we do send command IN_Stop to roll down all driver and firm ware as factory condition to be sure no effect of them. then go hard ware to check.. so star from in-stop
        • jason123
          • Oct 2015
          • 1068
          Thanks. This tv does not have ethernet and i don't have service remote. I attempted to enter the service menu (press and hold menu then enter one of 6 known password 0000, 7777, 0413, 8741, 8743, or 8878) and no success. I get Wrong Password. I then upgraded firmware to see if that helps and no luck. Any other way to enter service menu? Thanks
          • Diah
            • Feb 2013
            • 6370
            just today i recommend at other post 2 apk which worck with android mobile set built in IR transmitter
            • jason123
              • Oct 2015
              • 1068
              Yeah my s6 cracked and newer models don't have ir
              • jason123
                • Oct 2015
                • 1068
                Found the code 1105.... did a factory reset... still same issue
                • Diah
                  • Feb 2013
                  • 6370
                  disconnect ribbon cable between T-CON and Panel on the effected side and other side too one by one and check if the screen had same issue or not.
                  • jason123
                    • Oct 2015
                    • 1068
                    Disconnecting one, shows white half as expected. disconnecting the other one results in dark screen on one half and lighter slightly on the other side.
                    Disconnecting LVDS from Main to TCON results in just dark screen (none of the issues on right or left)
                    • Diah
                      • Feb 2013
                      • 6370
                      you have panel issue. check the panel board of the effected side , if there open R
                      also you can testing by exchange the ribbon cable of the effected side with the other side. check remain issue same side or not
                      just be carful when you remove the ribbon. as of the age of the tv and the heat the pins of them get easy to break
                      • CapLeaker
                        Leaking Member
                        • 8153
                        well, unfortunately you have a bad panel. Too bad...
                        • jason123
                          • Oct 2015
                          • 1068
                          Can you guy elaborate on the "Bad Panel"? What was expected from this last exercise? Just so I understand for future troubleshooting. Shouldn't I be getting the bad left / right when I disconnect the LVDS from main the TCON, if indeed bad panel?
                          • Diah
                            • Feb 2013
                            • 6370
                            NO. also this is wrong TEST by remove LVDS. nothing you will have from it.. black screen as you got. only ribbon remove its enough
                            • jason123
                              • Oct 2015
                              • 1068
                              Ok, thanks. What would you expect if I didn't have a bad panel when the left vs. right ribbon is disconnected from panel? What told you that I have a bad panel?
                              • Diah
                                • Feb 2013
                                • 6370
                                you wrote at your test of ribbon remove ((on one half and lighter slightly on the other side.)) this mean panel issue, but this issue of dimming part of the screen not whole the half 50% repairable as it may being one of resistor or ceramic capits value changed resulting this issue.
                                disconnect panel totally from T-CON and make access to the Tap board of the screen, you will have 2 side of same component, with DM at Ohm or Diode mode. you can compare the reading between each piece of parts of the good side of panel and the bad side of the panel. you will find one or more had different value i hope.
                                post clear photo of tap board the left and right one
                                • Unspun01
                                  • Jun 2011
                                  • 343
                                  I was just looking back at your photos. Is it just the left 1/5 of the screen? or is it both the left and right 1/5ths of the screen? Your photos appear to show that both the left side and the right side have symmetrical areas that are brighter/darker.
                                  In pictures 2 & 3, the text "No Signal" is facing up and appears at left side, and is facing up and appears at right side suggesting both sides of the panel display this issue?
                                  Is this accurate?
                                  This could be a panel error, but if you have symmetry in the error, perhaps is it mainboard signal error.
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Is this accurate?
                                    When you power it up with nothing on the screen, the left 1/5 or so of the screen seems lighter as you see in photo. Right hand side looks fine. When you display the menu, or put in a source, the left 1/5 of the screen is perfect image, and the right 1/5 of the screen seems messed up as you see in the photos. as if overlay (best way to describe it) is shifted. You are correct.
                                    Tcon replacement did not fix it. and the theory now is that it's a bad panel. I'll take a look at the tabs and see if I can find anything. I've ordered a main board, but I'm not sure it will fix it.. if it's a panel, then that's $20 down the drain I hope it's fixable
                                    • Unspun01
                                      • Jun 2011
                                      • 343
                                      Honestly, from your description it sounds like the issue doesnt happen permanently or randomly.
                                      The issue chases the signal sent to the panel. If tconn didn't fix it, I suspect main board. Possibly corrupted instruction or command. Try updating firmware if possible before new main board but I don't suspect panel issue
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        Thanks Unspun01 - That's where I'm leaning also - The tabs "Seem" to check out. Dirty components (cleaning didn't help) - I did update firmware and no luck.
                                        Here are photos of the tabs, just for completeness
                                        Left Tab (Bottom left when facing the tV) photos first starting from ribbon cable in the center
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                          HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-06-2024, 08:23 AM
