Power board
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Power board
    Hello can I have some help,I'm after a board with the part number ‘TP.MS6308.P83,it is in a Hisense lcd 32inch.
    Looking on a well known auction site ive noticed many board with this imbossed number,but has a variant numbered sticky white label which is different to mine.
    On looking everything is identical/number printed,could this tv use this same part in other lcd of the same size ?
    My white label is JHD315DH-E12 A15084411-0A00609 52% (unsure what these mean)
  • nomoresonys
    • 12145
    • U.S.
    Re: Power board
    You need to match up the numbers on the white sticker, the "imbossed" numbers are just the generic board numbers.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8146
      Re: Power board
      You will find the same TPMS board number in many other TV,s and they "look" identical. However the programming will be different including the LCD screen. So things have to match, or you make it match by programming and service menu. These TV's are the "everything on one board" wonders.
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: Power board
        Would there be another make/brand of tv same size with the same board ? Lhd32d50tuk
        • ducky29
          • Dec 2015
          • 370
          • Europe
          Re: Power board
          You need to match the screen, remote control, tuner etc. The exact same board is used only by ur model.
          Your best choice is https://www.ebay.com/itm/LCD-TV-MAIN...OeYF:rk:1:pf:0
          or https://www.ebay.com/itm/R16101235-M...JBE1:rk:2:pf:0
          • R_J
            • Jun 2012
            • 9535
            Re: Power board
            What is the problem you are having with the tv? maybe its not the board, or maybe the board can be repaired.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              Re: Power board
              Freezing is the issue,works for around five minutes,then you have to switch of the set then just shows ‘hisense’ what I mean by freezing is even scrolling through the menus etc also
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                Re: Power board
                Even the boards suggested have a different white label to mine but for the same TV set ?
                • ducky29
                  • Dec 2015
                  • 370
                  • Europe
                  Re: Power board
                  Do a factory reset from the service menu or reflash the firmware by usb drive.
                  • ducky29
                    • Dec 2015
                    • 370
                    • Europe
                    Re: Power board
                    Only this one is correct https://www.ebay.com/itm/LCD-TV-MAIN...OeYF:rk:1:pf:0
                    The first part of the white sticker "JHD315DH-E12" is your panel model.
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      Re: Power board
                      Where would I find the firmware flash ?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8146
                        Re: Power board
                        i don't find any firmware for that particular tv. But i'd try copying the existing EEPROM to a new EEPROM and go from there.
                        If you could take the EEPROM out, read and save the extracted flash, then "FF" the EEPROM, do a blank check, it will tell you if the EEPROM is bad or not.
                        • ducky29
                          • Dec 2015
                          • 370
                          • Europe
                          Re: Power board
                          I can try to order this firmware for you for 10$. Sorry but I don't have them on hand.
                          @Capleaker, this board doesn't have a eeprom but has a nand chip instead. So more expensive tools and better soldering skills are required for this repair.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8146
                            Re: Power board
                            yes, it is a nand. Looks like an S28 or S29... I just had a look at a picture. This repair isn't quite on the easy level, that is correct, as some soldering skills and special tools are required.
                            • nomoresonys
                              • 12145
                              • U.S.
                              Re: Power board
                              Might be easier to try to find a reasonably priced mainboard replacement.
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                Re: Power board
                                Yeah seen one but pricey for what I want to pay,
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • Hakuu
                                  by Hakuu
                                  Hi There,
                                  More Details
                                  TV Model - LG OLED77G1PUA
                                  07-12-2023, 02:37 PM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
