Sanyo FW55D25F stuck in color test mode
  • cherokee.warrior
    • May 2017
    • 87
    Re: Sanyo FW55D25F stuck in color test mode
    Pin 18 i have notice that myself and am looking into it. Ive been trying to trace out the connector on the power board that runs to the main board. I need to try to figure out what is what there then see which pin they lead to on the main board. Try to see where pin 18 is coming from there. Maybe it's something that doesn't have power. Just got my florescent lights put up yesterday so now i can see what im doing. Just got to find spare time from normal work, stuff around the house and honey doos to get back to looking at it again.
    • cherokee.warrior
      • May 2017
      • 87
      Ok i have been working hard to find out what the pinout on the power board is so here is what i have come to.
      Pins 1 2 3 4 P-On 21v
      Pin 5 Board ground
      Pins 6 7 8 9 Amp +13v
      Pins 10 11 12 13 14 15 Board ground
      Pin 16 All 3.3v
      Pin 17 BL-ADJ
      Pin 18 P-on H2
      Pin 19 BL-SW
      Pin 20 Reset
      Pin 21 Protect 3
      Pin 22 Protect 1
      Pin 23 Does not seem to go to anything
      Its getting late so i will i will get to looking at it more at a later time. I hope what i have done so far here is redeemed me in a small way....
      • cherokee.warrior
        • May 2017
        • 87
        The white page is not what I intended to post ahhhh...
        • cherokee.warrior
          • May 2017
          • 87
          Here is the pinout i intended to post for power board
          • budwich
            • Jul 2015
            • 3097
            how about this combination / remote sequence.
            quote: "Press the power key first. If it does not solve the problem, then press the
            keys on the remote control in the order shown below to change the unit
            to the live mode.
            SLEEP L PIX SHAPE A L K L H L I L B"
            certainly unusual... I don't know if it applies to your particular model but who knows. You got the user manual for the set right.... :-)
            • cherokee.warrior
              • May 2017
              • 87
              not sure where the letters in the alphabet are on the remote but i tried converting the letters into numbers that you would see on a phone. That didnt work. where does the L A L K L H L I L B come from? how do i convert to what is on the remote?
              • Tvbob
                tvbob
                • 204
                #67
                Just my 2 cents.
                Disconnect cable (LDVS) between the main board and the panel with integrated T con.
                Jumper power from the power board to the smd fuse on the panel. You may need a ground path also. Turn set on.
                If your still in test mode, You have a panel problem
                  • 12151
                  • U.S.
                  #68
                  To turn off self test mode, first stand near your TV’s power cord going into the wall. On your TV remote control, first press the arrow up button then the arrow down button. After pressing the remote buttons, unplug your TV from power within 5 seconds. Wait 15 seconds and plug the TV back into the power outlet. Wait 10 more seconds and test the TV to see if the issue has been solved. If your TV is not working correctly still, repeat the complete procedure but press the left arrow button and the the right arrow button instead of the up and down buttons.
                    • 12151
                    • U.S.
                    #69
                    You could try getting a mainboard, saw some on ebay for about 50 bucks, seems like you need to make sure you match up your serial numbers like DS9, DS5 etc.
                    • budwich
                      • Jul 2015
                      • 3097
                      that's how sanyo describes it in the manual / guide.
                      • R_J
                        • 9535
                        This is for a funai tv
                        Service mode
                        How to set up the service mode
                        1. Turn the power on.
                        2. Press [MENU] button to display Setup menu.
                        3. Select “Software” in “OTHERS” and press [OK] button.
                        4. Press [0], [4], [2], [5], [7], [4] and [ INFORMATION (i) ] buttons on the remote control unit in this order. The following screen appears.
                        Purity Check Mode
                        This mode cycles through full-screen displays of red, green, blue, and white to check for non-active pixels.
                        1. Enter the Service mode.
                        2. Each time the [7] button on the remote control unit is pressed, the display changes
                        3. To cancel or to exit from the Purity Check Mode, press [BACK] button.
                          • 12151
                          • U.S.
                          #72
                          Maybe shopjimmy sent you a bad chip, they don't do refunds on those but they will probably send you another one with no charge.
                          • cherokee.warrior
                            • May 2017
                            • 87
                            Originally posted by Tvbob
                            Just my 2 cents.
                            I tried what you described and nothing happened the screen remained black. 12 volts to fuse and board grounded.
                            • djluis
                              • 12
                              #74
                              any update? did you found problem?
                              • SdlewisSr
                                • Oct 2015
                                • 146
                                To turn off self test mode, first stand near your TV's power cord going into the wall. On your TV remote control, first press the arrow up button then the arrow down button. After pressing the remote buttons, unplug your TV from power within 5 seconds. Wait 15 seconds and plug the TV back into the power outlet. Wait 10 more seconds and test the TV to see if the issue has been solved. If your TV is not working correctly still, repeat the complete procedure but press the left arrow button and the the right arrow button instead of the up and down buttons.
                                Thanks for this nomoresonys. It worked on my Sanyo (Funai) FW32D06F B.
                                  • 12151
                                  • U.S.
                                  #76
                                  • YellowJacket
                                    SHARP LC-32CHF5111K - stuck at color test mode
                                    by YellowJacket
                                    Hi friends,
                                    TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                    So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                    02-04-2023, 03:11 AM
                                  • gordesky1
                                    Hanns-G HG281D stuck on self test color mode?
                                    by gordesky1
                                    So 2 years ago a surge hit this monitor:/ which years before i got it going again replacing the 2 16v caps on the main board C80 and C83.
                                    After the surge all i had was a black screen with a blue led than it goes orange after secs.
                                    So i took it apart to check it which i didint find no issues.. But my dam luck a screw driver drop on the psu and big spark happen and it blew the small 250v box fuse.
                                    So it sat for a year till i ordered new fuses on amazon 2 days ago and got them in yesterday.
                                    So i took it apart replaced the fuse...
                                    10-11-2020, 06:15 AM
                                  • kiko1
                                    SHARP LC-49XUF8772ES stuck in color test mode
                                    by kiko1
                                    This is my third or fourth SHARP AQUOS with this symptoms....
                                    I did it every time...but this one is driving me crazy...there is no buttons on the TV...only remote control (OMG....RF one, not IR)
                                    Can someone post a solution for this one please??
                                    01-16-2021, 10:17 AM
                                    HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                    09-06-2024, 08:23 AM
