Re: LG 49lf510V no backlight
OK. I think i see where the error is:
I asked you to test the following in my post 10: check the DCV between the two legs of the lytics cap (33uf 100 Vdc) to the left C537.
Youe reply in post 10: C537 reading starts at 26 volts but slowly decreases.
So it means that the first stage booster is working and it is putting out about 49V (I expect the C513 (33uF 100V) will have about 49V between the two legs), it is the second stage that is not working.
In post 15 you indicated that you test the MOSFET BUT did you remove that MOSFET Q502 and test it off the board?
Also R551 tested OK (asked by other also)?
