Samsung UA40H6400AW Is it a bad T-Con Panel or Power supply?
  • omnivortex
    • 20
    • Indonesia
    Good day everyone , i need some help with my samsung my tv picture suddenly went from a perfectly normal bright and contrast into a plain dark with no contrast at all right after my little niece accidentaly plug out the power cable the tv condition at that time is on the process of updating firmware. after i turn it back on the very first thing i notice right away is there's a difference on the smart tv logo that appear at the startup when the logo appear it's dark and after about 1 second it turns into a little bright before this happen the logo appear bright right at the start. all the other function and feature still working normally there's no issue at all besides on what i have describe
    the picture are normal and still quite visible its just not as bright and contrast as before
    What do u guys think? Thanks
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Samsung UA40H6400AW Is it a bad T-Con Panel or Power supply?
    unplugging the TV during firmware update is a big no no. You can try to update the firmware again. Try doing a factory default and set the TV's picture up again to your liking. If that isn't satisfactory, you can try to find a dump file and flash the chip directly with a programmer, or a new main board.
    • omnivortex
      • 20
      • Indonesia
      Oh i see , yeah luckily the tv is still running fine it could have been worse. okay i'll try it later see if it does solve the issue thanks
      • omnivortex
        • 20
        • Indonesia
        Or maybe is it possible that when the unplugging happen it also damaged the other board or panel component
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8325
          that would be a coincident.
          • omnivortex
            • 20
            • Indonesia
            Good day , I have already done the factory reset and firmware update successfully but
            the picture doesn't change at all its still dark.
            • nomoresonys
              • 12269
              • U.S.
              And you redid your tv settings brightness backlight settings etc?
              • omnivortex
                • 20
                • Indonesia
                Yes , i resetting the picture setting exactly the same as before
                • nomoresonys
                  • 12269
                  • U.S.
                  Head scratcher, wonder if a service menu setting got messed up somehow, have to be very careful if you do go in service menu tho, can mess up tv if done wrong.
                  • omnivortex
                    • 20
                    • Indonesia
                    No , i didn't change the service menu at all its out of the box setting
                    Is there any chance that a failure power suply or T-con board can cause the tv picture into dark lack of brightness and contrast?
                    • nomoresonys
                      • 12269
                      • U.S.
                      Was reading where a sony update made picture dark, wonder if it's just a bad firmware they put out, wonder if you can downgrade the firmware as in go back to the last one you had before update?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8325
                        read this maybe: https://www.samsung.com/in/support/t...hile-watching/
                        • nomoresonys
                          • 12269
                          • U.S.
                          ^ Yes good things to try there. ^
                          • omnivortex
                            • 20
                            • Indonesia
                            Oh i see , actually i've been thinking about it couple times too and luckily there's a friend of mine that has a same tv as mine and i have an idea to swap my tv mainboard into his tv to make sure is it really the firmware. maybe tonight im gonna test it with my friend
                            • omnivortex
                              • 20
                              • Indonesia
                              Yes that's it my tv condition right now is exactly the same like the example on the link that you posted. it used to be that bright & contrast then it becomes dark & no contrast. i also have check all of my eco + power setting but all of them is already disabled
                                If you go to OSD '?'OSD/Self Diagnostic/Picture Test does the pictures look normal with nice and bright and good contrast?
                                I have UN40C7000 that has dark pictures 2 years ago, pictures look great in self test mode, so I did factory reset mute-1-8-2 and it has been working fine ever since, I use it everyday in my bed room.
                                Since my TV is not the same as yours so yours may not have self test mode.
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  09-07-2024, 05:50 AM
                                • cheeky2
                                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                  by cheeky2
                                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                  06-15-2025, 05:12 AM
                                  03-31-2024, 02:12 PM
                                • Cookybaby
                                  Samsung UN60ES6500FXZA Power Supply Issue
                                  by Cookybaby
                                  Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                  I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                  Make: Samsung
                                  Model: UN60ES6500FXZA
                                  Power Supply P/N: BN44-00525A
                                  Symptoms: The TV was...
                                  08-20-2023, 12:26 PM
