Re: Sharp LC-80LE661U - Power's off after 4 seconds.
Where you able to fix the problem on your tv?
Any updates on this? I am having EXACT same issues. Have replaced main board with same results (sharp logo and then off) after 4-5 secs.Leave a comment:
Guess youy could try a tcon, one there for 32 bucks has a make offer option too. https://www.ebay.com/itm/SHARP-LC-80...-/371882999505Last edited by nomoresonys; 02-14-2019, 05:17 AM.Leave a comment:
.Last edited by nomoresonys; 02-14-2019, 05:15 AM.Leave a comment:
"Not sure exactly what you mean here. I tried using a 2k resistor (only thing I had on hand) between the ps-on and ground, then also between pnl_pow and ground, hoping it would turn on the LCD but didn't get any results" NO you don't use the ground, you use the 5 volt, you need to jump 5 volt with ps-on and pnl-pow. to see a display NOT ether or, you DO NOT use ground, afaik.Last edited by nomoresonys; 02-14-2019, 04:35 AM.Leave a comment:
So you need to trace that error pin to see where it goes... I am assuming it comes from the tcon.... but you can confirm that. IF so, that would likely mean that the tcon is shutting the system down maybe.Last edited by budwich; 02-14-2019, 12:12 AM.Leave a comment:
Your problem seems similar to this one right below. https://www.badcaps.net/forum/showthread.php?t=63849
Tried this and it does seem to be spiking in voltage after the screen blips out. While the screen is on (first 4 seconds) it is at 1.4v then bumps up to 2.5v after the screen shuts off, it stays at 2.5v for a few seconds until I hear a click from the power supply and then drops to 0v.Leave a comment:
I see the following labels on the pin label for the cable between the mainboard and the powerboard:
PNL12V
GND
UR13.2V
UR13.2V
GND
GND
PS_ON
PNL_POW
NC
NC
ERROR
STB
Would it be the PNL_POW pin that I need to short to ground?
When taking power readings earlier I saw 5V on that pin. What type of resister would I need to use? Or, could I short it directly to one of the GND pins above (was seeing 4.5V on the two ground pins 5th and 6th from the top)?Leave a comment:
Your problem seems similar to this one right below. https://www.badcaps.net/forum/showthread.php?t=63849Leave a comment:
You can download firmware on this page, guess you put the usb with the update in then plug in tv, should update by itself. It won't fix it if firmware isn't the problem but it won't hurt any. https://siica.sharpusa.com/product-downloadsLast edited by nomoresonys; 02-13-2019, 05:24 PM.Leave a comment:
:-( it appears that the structural design of the 80 is different from the 70 which has a plastic "plate" covering the lower edge boards. I am not sure that it is worthwhile doing further disassembly at this time. It is disappointing that the shutdown does provide some form of "code flashing" or otherwise to indicate some sort of error code. Your tests that the system does detect a totally disconnected tcon from the MB indicates that the system is somewhat functional and that some other fault is causing the shutdown.
One note on disassembly beyond this point, I used blocks of wood strategically placed on the various points of the "metal back plane" to set the panel on so that I could leave everything connected and still get access to screws / hardware to remove the front bezel which then gives you access to edge boards / tabs that connect to the panel.
One other note: there is a couple other threads dealing with 80 in panels that you should read... they might provide some further information.Leave a comment:
hmmm the fact that you can't connect with any external inputs doesn't sound good and points towards the amin board which houses those (I think). further, you still need to try to disconnect the small corner cables that interconnect the bottom and side edge boards... this may give you a better understand of what it happening.Leave a comment:
multitudes of dvds (thx ones and others) have special features for tv setup / colors etc. In addition, there are computer files that provide various test patterns.
Since the system still shuts down, regardless of the tcon connections, that would imply a problem back from there. However, it may depend on why the shutdown.... voltages out of range? main board issues?
The corner cable test that I suggest is potentially still valuable depending on what happens. Still concerned about the lack of uniform white on the disconnected side.
Oh, and I can't get any external inputs to display. TV powers up, shows Sharp logo and then shuts off in a few seconds. I've tried multiple inputs and haven't seen anything displayed (don't see menu's either and can't get the service menu to pop up with button combinations). So that puts in me a tight spot with getting test patterns to display.
Anyway, I've got some pictures attached.
Does this look like a panel issue? If that's the case, do these type of tv's have backlight LEDs that could be replace? Or does it just mean the panel is shot?
Thanks for the help and advice.Last edited by overlyAmbitiousSloth; 02-12-2019, 08:34 PM.Leave a comment:
The corner cable test that I suggest is potentially still valuable depending on what happens. Still concerned about the lack of uniform white on the disconnected side.Leave a comment:
as you can see from your pictures, the "issue" seems to be on the left side... when that side is disconnected.... while opposite "test" appears quite a bit better in terms of "uniform white". My concern would be that perhaps it is a "marginal panel issue". It would help if you feed in a known test pattern (color bars) which will potentially highly issues better. Further, you indicate at the start, that the set shuts down after 4 seconds. does it still do this with either side of the tcon disconnected? IF not, then that would point to a panel issue.... but if so, then it might indicate a problem away from the panel and more dealing with controls / boards.
One other point.... I know the panel is huge (previously I work with a 70in that was tough)... so be careful. There are small white cables in the bottom corner of the panel on each side. These cables interconnect the bottom edge boards to side edge boards. If you are careful, you can disconnect those cables... again one at a time and see the result.... keep all other cabling connected. You should see a full picture with some darkness... again use a test pattern (color bars) and perhaps your display will show you something.
I've been doing some reading on feeding the t-con board a test pattern and am not finding any instructions on this type(G477FM05). I see some other boards have pins that can be jumped or shorted but I don't see anything on this board that screams 'bridge me' (I also don't really have a clue what I'm looking for, just comparing to the pictures in this post https://www.badcaps.net/forum/showthread.php?t=26790 ). I've attached a picture of the board for reference (can take better pictures later if it helps).
Any idea's on how I can get it to display a pattern?
When I get home I'll check for those cables running the bottom corner/edge of the LCD and see if disconnecting those shows new results.
PS - Found documentation on the RS232 port that I asked about earlier in the Operation Manual for the LC-80LE661U. Looks like its designed for remote control of the TV. No help in this scenario but kind of a cool option to have.Leave a comment:
One other point.... I know the panel is huge (previously I work with a 70in that was tough)... so be careful. There are small white cables in the bottom corner of the panel on each side. These cables interconnect the bottom edge boards to side edge boards. If you are careful, you can disconnect those cables... again one at a time and see the result.... keep all other cabling connected. You should see a full picture with some darkness... again use a test pattern (color bars) and perhaps your display will show you something.Last edited by budwich; 02-12-2019, 01:24 PM.Leave a comment:
so... the pictures that you posted seem to show some "issue" with the display.... perhaps although it could be the "photography". The "white" side that indicates the side of the tcon that is disconnected should be uniformly white. One picture appears to show some horizontal "banding" of darkness. Was this actually there or just a "poor photo" not really representative of the image that was there?
Would that point towards a poor LCD?Leave a comment:
so... the pictures that you posted seem to show some "issue" with the display.... perhaps although it could be the "photography". The "white" side that indicates the side of the tcon that is disconnected should be uniformly white. One picture appears to show some horizontal "banding" of darkness. Was this actually there or just a "poor photo" not really representative of the image that was there?Leave a comment:
I believe you can use a 1k resistor and connect 5 volt stby with ps-on and panel 12v, maybe one of the super techs here can confirm procedure.Leave a comment:
by ResoluteHawkI have an Alienware 17 R3 (board is a C912P) that I recently starting trying to repair. Originally the issue was the charger going into protection mode when plugged in to the laptop. I found a short on the motherboard (one of the capacitors on the back of the board under the DRMOSes for the CPU) and the charger when plugged in now doesn't go into protection mode anymore. The laptop powers on, the lights on the keyboard, alien head, and alienware logo light up, and the fans spin. The issues are:
1) The battery doesn't charge. I've probed the charger jack and it's only receiving 0.633v... -
This laptop come in with liquid damage. I located a couple areas on the board which honestly didn't look bad at all. I ISA them and cleaned up - can't even tell anything happened. However, when I power up the computer, it will shut off after about 10 seconds. I discovered it seemed like the fans weren't coming on because the board was getting mad hot right around the battery charging mosfets and coil. Anyhow, I checked under the thermal camera with just the power adapter connected but the machine off. I have marked what is warm at that time. Once I power it up, the coils near CPU vcore start heating...
I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
Any ideas? -
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... - Loading...
