Sharp LC-80LE661U - Power's off after 4 seconds.
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp LC-80LE661U - Power's off after 4 seconds.
    :-( it appears that the structural design of the 80 is different from the 70 which has a plastic "plate" covering the lower edge boards. I am not sure that it is worthwhile doing further disassembly at this time. It is disappointing that the shutdown does provide some form of "code flashing" or otherwise to indicate some sort of error code. Your tests that the system does detect a totally disconnected tcon from the MB indicates that the system is somewhat functional and that some other fault is causing the shutdown.
    One note on disassembly beyond this point, I used blocks of wood strategically placed on the various points of the "metal back plane" to set the panel on so that I could leave everything connected and still get access to screws / hardware to remove the front bezel which then gives you access to edge boards / tabs that connect to the panel.
    One other note: there is a couple other threads dealing with 80 in panels that you should read... they might provide some further information.
    • nomoresonys
      • 12104
      • U.S.
      You can download firmware on this page, guess you put the usb with the update in then plug in tv, should update by itself. It won't fix it if firmware isn't the problem but it won't hurt any. https://siica.sharpusa.com/product-downloads
      • nomoresonys
        • 12104
        • U.S.
        Your problem seems similar to this one right below. https://www.badcaps.net/forum/showthread.php?t=63849
        • budwich
          • Jul 2015
          • 3097
          Originally posted by overlyAmbitiousSloth
          I see the following labels on the pin label for the cable between the mainboard and the powerboard:
          PNL12V
          GND
          UR13.2V
          UR13.2V
          GND
          GND
          PS_ON
          PNL_POW
          NC
          NC
          ERROR
          STB
          Would it be the PNL_POW pin that I need to short to ground?
          When taking power readings earlier I saw 5V on that pin. What type of resister would I need to use? Or, could I short it directly to one of the GND pins above (was seeing 4.5V on the two ground pins 5th and 6th from the top)?
          you night try monitoring the ERROR pin / connection at power plug in, power on, and at shut down to see if thats the "flag" for shutdown... probably... maybe.
          • overlyAmbitiousSloth
            • Jan 2019
            • 12
            Make sure you are identifying your pins correctly, you should have around 0 volts on the ground pins.
            Double checked and am definitely getting 4.5 - 4.8v on the ground pins when the TV is on (only for a few seconds until it shuts off, then it drops down to 0v).
            I believe you can use a 1k resistor and connect 5 volt stby with ps-on and panel 12v, maybe one of the super techs here can confirm procedure.
            Not sure exactly what you mean here. I tried using a 2k resistor (only thing I had on hand) between the ps-on and ground, then also between pnl_pow and ground, hoping it would turn on the LCD but didn't get any results.
            Did some digging and I saw some power board and backlight issues, and some issues that registered an error code, but I haven't spotted anything similar just yet. I'll do some more perusing to see if I missed anything.
            I so wish this was my problem. Sounds like these guys are getting stuck in a reboot loop. Mine powers up, stays on a few seconds and then shuts down completely. Tried it anyway with both a 2Gb and a 32Gb (didn't have any 1Gb USBs hanging around) and there was no change in behavior. Seems like it didn't even register it was plugged in and shut off as usual.
            Tried this and it does seem to be spiking in voltage after the screen blips out. While the screen is on (first 4 seconds) it is at 1.4v then bumps up to 2.5v after the screen shuts off, it stays at 2.5v for a few seconds until I hear a click from the power supply and then drops to 0v.
            • budwich
              • Jul 2015
              • 3097
              So you need to trace that error pin to see where it goes... I am assuming it comes from the tcon.... but you can confirm that. IF so, that would likely mean that the tcon is shutting the system down maybe.
              • nomoresonys
                • 12104
                • U.S.
                #27
                "Not sure exactly what you mean here. I tried using a 2k resistor (only thing I had on hand) between the ps-on and ground, then also between pnl_pow and ground, hoping it would turn on the LCD but didn't get any results" NO you don't use the ground, you use the 5 volt, you need to jump 5 volt with ps-on and pnl-pow. to see a display NOT ether or, you DO NOT use ground, afaik.
                • nomoresonys
                  • 12104
                  • U.S.
                  #28
                  • nomoresonys
                    • 12104
                    • U.S.
                    #29
                    Guess youy could try a tcon, one there for 32 bucks has a make offer option too. https://www.ebay.com/itm/SHARP-LC-80...-/371882999505
                    • jackf-nc
                      • Feb 2020
                      Any updates on this? I am having EXACT same issues. Have replaced main board with same results (sharp logo and then off) after 4-5 secs.
                      • Donmessi
                        • Nov 2021
                        • usa
                        #31
                        Where you able to fix the problem on your tv?
                        • ResoluteHawk
                          Alienware 17 R3 (LA-C912P) Powers on then powers off after 4-6 seconds
                          by ResoluteHawk
                          I have an Alienware 17 R3 (board is a C912P) that I recently starting trying to repair. Originally the issue was the charger going into protection mode when plugged in to the laptop. I found a short on the motherboard (one of the capacitors on the back of the board under the DRMOSes for the CPU) and the charger when plugged in now doesn't go into protection mode anymore. The laptop powers on, the lights on the keyboard, alien head, and alienware logo light up, and the fans spin. The issues are:
                          1) The battery doesn't charge. I've probed the charger jack and it's only receiving 0.633v...
                          06-17-2022, 01:04 PM
                        • survivalbloke
                          ASUS TUF 506 powers off after about 10 seconds due to heat
                          by survivalbloke
                          This laptop come in with liquid damage. I located a couple areas on the board which honestly didn't look bad at all. I ISA them and cleaned up - can't even tell anything happened. However, when I power up the computer, it will shut off after about 10 seconds. I discovered it seemed like the fans weren't coming on because the board was getting mad hot right around the battery charging mosfets and coil. Anyhow, I checked under the thermal camera with just the power adapter connected but the machine off. I have marked what is warm at that time. Once I power it up, the coils near CPU vcore start heating...
                          08-07-2023, 02:23 PM
                        • survivalbloke
                          Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                          by survivalbloke
                          I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                          Any ideas?
                          01-08-2024, 12:12 PM
                        • twonk9098
                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                          by twonk9098
                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                          I have tried a few new bios but exactly...
                          07-14-2024, 11:19 AM
                        • liquidzorch
                          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                          by liquidzorch
                          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                          10-18-2024, 05:19 PM
