Samsung UN46C6400RFXZA audio but no picture (pics incl).
  • GLInick
    • Feb 2019
    • 31
    It turns on, and the welcome chime plays. The LEDs light up, there is a glow on the screen, but no picture is shown.
    There is a ticking sound from a large component on the power board that is a coil of some type (easier to see on the back side). It has a white plastic cover with markings -- see pics.
    Power board:
    I inspected all electrolytic caps and none looks obviously burnt.
    I measured the voltages at connector CNL801 (goes to the LEDs, and according to the chart on the PCB they are LED1 +/- and LED2 +/-, with some pins marked N.C). The voltage fluctuates quite a lot between 2v-7v (I could be off, it changes quite fast)
    I measured voltages at connector CNM801 (goes to main board), and based on the chart printed on the PCB, here is what I measured (all voltages wrt ground, i.e., black lead to chassis):
    PIN#-Measured Indicated_on_chart
    Pin1-12.6 12V
    Pin2- N.C
    Pin3-12.6 12V
    Pin4- 4.83 BL_ON
    Pin5-12.6 12V
    Pin6-0.47 P_DIM
    Pin7- GND
    Pin8-0.30 H_SYNC
    Pin10- GND
    Pin11-5.2 5.3V
    Pin12- GND
    Pin13-5.2 5.3V
    Pin14-5.2 5.3V
    Pin15-17.24 Vamp
    Pin16-5.21 STBY
    Pin17-17.27 Vamp
    Pin18-1.53 PS_ON
    Main board (HDMI and antenna inputs, ethernet port):
    On the main board, there are a lot of test points on the underside, but I don't know what to test for.
    T-CON board:
    I tested both sides of the T-CON board fuse (white, with gold tips, and it measures 12.46 Volts
    I am hoping the buzzing sound of the component on the power board is an indication that the fault is there.
    Pics are here: https://photos.app.goo.gl/nfR6V7KXUCJWHT3K9
    Any pointers would be really appreciated.
    Re: Samsung UN46C6400RFXZA audio but no picture (pics incl).
    Please upload good clear pictures here.
    • GLInick
      • Feb 2019
      • 31
      I wasn't able to see the full-featured editor with the "manage attachments" feature when I posted originally.
      - Power supply board
      - Main board
      - TCON
      - component on power supply board that makes ticking noise.
        Samsung BN44-00356A power supply/LED driver board.
        That is power transformer for the LED driver and for 12V, Vamp, and switched 5V.
        Try having the ribbon cable between the T-con and the LCD panel connected one at a time to see what you get on the screen.
        What is the history of the TV?
        • GLInick
          • Feb 2019
          • 31
          History: we don't use it very much but it stopped working one day.
          What do those ribbon cables from the TCON to the panel map to, horizontal/vertical or left/right? Curious to know what I should expect to see if one or the other gets disconnected.
          also, on that power transformer, is the ticking normal? Any voltage tests I can do?
          Should I have any inputs connected? I don't currently, I just try to bring up the system menu.
          P.s. can you point me to the moderator please. I'd like to edit the OP for better formatting now that I have full wysiwyg.
            • 12331
            • U.S.
            " Curious to know what I should expect to see if one or the other gets disconnected": You should see a good picture on half the screen if working correctly.
            • GLInick
              • Feb 2019
              • 31
              I don't get picture on either half when I unplug each of the two T-CON cables on the bottom.
              The backlight/glow will become brighter as I cycle through the input sources (but it is unclear what the current input source is).
              What is next, anything else to try?
              • budwich
                • Jul 2015
                • 3097
                I think that a "picture outcome" is the "optimum"... you are likely looking for a change. Lots of sets display a white screen for the disconnected side. You have checked voltages at the PS but there are also voltage points labeled on the tcon that may help.
                • GLInick
                  • Feb 2019
                  • 31
                  I'll check the test points on the T-CON then. Is there some writeup on it somewhere?
                  • GLInick
                    • Feb 2019
                    • 31
                    I am pasting the voltage measurements I posted originally for the Power Supply, formatted for easy reference.
                    Voltages at connector CNM801 (goes to main board, all voltages wrt ground, i.e., black lead to chassis):
                    Code:
                    [U]PIN#	Measured	Indication on PCB chart[/U]
                    Pin1	12.6		12V
                    Pin2			N.C
                    Pin3	12.6		12V
                    Pin4	 4.83		BL_ON
                    Pin5	12.6		12V
                    Pin6	0.47		P_DIM
                    Pin7			GND
                    Pin8	0.30		H_SYNC
                    Pin10			GND
                    Pin11	5.2		5.3V
                    Pin12			GND
                    Pin13	5.2		5.3V
                    Pin14	5.2		5.3V
                    Pin15	17.24		Vamp
                    Pin16	5.21		STBY
                    Pin17	17.27		Vamp
                    Pin18	1.53		PS_ON
                    • GLInick
                      • Feb 2019
                      • 31
                      The T-CON board, both sides.
                      Any pointers to where to check voltages would be appreciated.
                      • GLInick
                        • Feb 2019
                        • 31
                        Also, I noticed there is a schematic posted by budm. Is this applicable to the T-CON I have?
                        See:
                        https://www.badcaps.net/forum/showpo...&postcount=401
                          Start checking Voltage at the test points, I can see:
                          VCC12
                          VCC33
                          AVDD
                          VCOMxxx
                          VOFFE
                          • GLInick
                            • Feb 2019
                            • 31
                            I am attaching an updated image of the T-CON board with a grid for easy reference.
                            Here are the values I have measured with TV on, and no input sources.
                            Please let me know what other values I will need to check.
                            A big thank you for all this help. I'd lie to save this from becoming e-waste.
                            Code:
                            [B][U]LOC	TEST_POINT	MEASURED (to chassis, in DC VOLTS)[/U][/B]
                            [B]CON1 connector	[/B]
                            J14	VIN		12.65
                            J14	GND
                            [B]RIGHT of CON1 connector[/B]
                            J18	AVDD		0.5-0.9
                            E16	VCC12		1.21
                            F15	VCC33		3.25 - 3.27
                            H22	VOFFE		-2.x - 1.x
                            F19	VSS		-2.x - 0.x
                            E20	VONE		0
                            [B]LEFT of CON1 connector[/B]
                            L3	VR		0
                            K9	SDA		0.33 - 1.46
                            K9	SCL		1.6 - 3.10
                            K8	WP		3.26
                            JK6	SDA_EXT		3.26
                            JK6	SCL_EXT		3.26
                            J7	SDA_I		3.26
                            I7	SLC_I		3.26
                            [B]LEFT OF MAIN CHIP	[/B]
                            G7	RST		0.5 - 3.25
                            G8	B_INT		0
                            F9	SYNC_OSCB	0.17
                            E6	STV0		0
                            E8	DEO		0.46 - 2.75
                            D8	T_RDY		0.00 - 0.12
                            D7	CPV1		0
                            D7	CPV2		0
                            D7	CPV3		0
                            D6	STV		0
                            [B]RIGHT OF MAIN CHIP	[/B]
                            F13	KB		0.27 - 1.75
                            F13	HSYNC_0		0.00 - 0.07
                            F13	VSYNC_0		0.00 - 0.06
                            F13	S_STT		0
                            F13	S_DATA		0
                            F13	S_CLK0		0
                            G13	SYNC_DEO	0
                            [B]FPC_LEFT connector	[/B]
                            C8	VDDMHL_1	0.04 - 0.10
                            C8	VCOMS2		0.06 - 0.25
                            C7	VCOMS1		0.06 - 0.25
                            C7.9	F_VCOML		0.07 - 0.26
                            C7.25	AP_SYNC		0.03 - 1.2x
                            C4	VCOMG1		0.08 - 0.26
                            C4	VCOMG2L		0.06 - 0.25
                            [B]FPC_RIGHT connector	[/B]
                            C21	VDOMHL_2	0.05 - 0.10
                            C21	VCOMG3		0.06 - 0.26
                            C21	VCOMG2R		0.05 - 0.25
                            C20	VST2		0.05 - 0.25
                            C16	VCOMS3		-0.07 - 0.25
                            C16	VCOMS4		-0.05 - 0.25
                              It looks like ICD1 is not running. P/N of that IC? I can see MX17?????
                              Try not having both ribbon cables between the T-CON and the LCD panel disconnected and see if the AVDD will be present or not, if not then check the resistance between AVDD test point and GND to see what kind of resistance you have.
                              • GLInick
                                • Feb 2019
                                • 31
                                Here is the image without the grid lines.
                                ICD1 is
                                MAXIM
                                MAX17122
                                ETL 013
                                ITXBZB0
                                I will follow up with the measurements and tests shortly.
                                • GLInick
                                  • Feb 2019
                                  • 31
                                  Just to be clear, all of the measurements I posted above were taken with everything connected, so both of the ribbon cables from the LCD were in circuit.
                                    So try disconnecting the two cables between T-CON and the panel to see what you will get on AVDD.
                                    • GLInick
                                      • Feb 2019
                                      • 31
                                      I get the following results regardless of whether any or both ribbon cables are connected:
                                      • voltage fluctuates between 0.5 - 1.02 V
                                      • resistance between AVDD and ground is about 7.9x KOhm
                                        AVDD should be around 15 ~ 20VDC so there is malfunction in that section of the ICD1.
                                        See the application circuit of the IC.
                                        MAX17122: https://www.maximintegrated.com/en/p.../MAX17122.html
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
