Sony KDL52NX800 lines in the picture.
  • capwizard
    • Jun 2016
    • 1991
    Sony KDL52NX800 lines in the picture. this symptom is screen problem?
    Screen has 4 flex cables go into. Fist take 2 off then other 2 flex cable.
    Yes it is Sharp panel.
    Re: Sony KDL52NX800 lines in the picture.
    It looks similar to the pictures I save from one of the SONY thread, do not remember which one it was but it was bad T-CON according to OP.
    • capwizard
      • Jun 2016
      • 1991
      Thank you very much
      T-Con Board RUNTK4400TP CPWBX before I order T con I will reflow and oven bake. See what happens?
      I will be back.
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • CyberPhoenix
        Issue with picture quality of Sony bravia TV
        by CyberPhoenix
        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
        01-22-2024, 02:08 AM
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • Glaval
        Sony OLED XBR-65A8G 4 flashes
        by Glaval
        Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
        01-23-2025, 04:04 PM
