Ordering SMD LED for backlight
  • Mcologist
    • Jan 2019
    • 20
    I am currently working on a Haier 55UFC2500b that has two backlight LED's out.
    my question is does anyone know of a model number to order individual SMD LED's that works on most backlight strips? I have it narrowed down to 3001 results on digikey.ca based of Physical dimension alone.
    Thanks!
  • Wilderone
    • May 2018
    • 76
    Re: Ordering SMD LED for backlight
    Measure the dimensions of the smd ie 2.8mm * 3.5mm would be (2835) there will be differences in the pads & color (warm white/cool white) check this against your old ones.
    For example LG 2835;
    https://s.click.aliexpress.com/e/cb1GobpA
      You need to know the Forward Voltage (Vf) rating, the current rating, and the footprint I.E large solder pad is Anode or Cathode.
      You need to remove the bad one and look at the solder pad, you can also measure Vf.
      Current rating of 400mA is typical for backlights application.
      Pictures of your LED's?
      LED strip P/N?
      Dimension?
      LED drive Voltage/Currnet rating as printed on the board?
      • Mcologist
        • Jan 2019
        • 20
        Okay so size is 3mmx3mm, large pad is - small pad is +. As for current or voltage there is nothing printed on any of the LED strips for it and there is nothing I can see on the power board that indicates either value.
        • Diah
          • Feb 2013
          • 6358
          yours SMD LED 3030 6V 1-2 W easily can find them with Lens or just the LED
          • Mcologist
            • Jan 2019
            • 20
            How do you know it is a 6V?
            • Diah
              • Feb 2013
              • 6358
              you have 55 size TV. the range of SMD LED with 5600K 4.7V. as yours..
              in the market there are 3030 Single LED of 3 Volts and 6 Volts. if you use now at yours set 3 Volts it will burn other old LED
              • Mcologist
                • Jan 2019
                • 20
                Thanks everyone for the help I have ordered a few and hopefully can test it out before the end of the week
                  Set meter to diode mode, the 3V LED will dimmly lights up and look at the readout on the meter, the 6V probably will not due to meter does not have high enough potential Voltage to bias on 6V LED.
                  • Diah
                    • Feb 2013
                    • 6358
                    SMD LED when it say 6V. mean maximum. with DM diode mode. most DM are 9.volts Battery this will not make sense. average all direct LED back light are 4.7 V. this is my calculation always on how many mount of LED used on one LINE. of course each Brand use 1 line or 4 line or 2. but still PSU will provide 126V for line. BTW Haier Pure Chinese. which they use 3030 6V SMD LED
                      If meter can forward on the 6V LED (Vf will be much lower at low current which the meter is limited to, so the readout on the meter will be <6V, the meter in diode mode will show Vf of the semiconductor. So the 3V LED may show something like 2.7V on the meter. Easy enough for OP to use his meter to test his working LED to verify, no t hard to do, is it? The spec of the meter will also show what the output limit is in diode mode.
                      LG 3030 Dual-LED.
                      • Diah
                        • Feb 2013
                        • 6358
                        you are right with RGB SMD LED, this will not work at white 5600K designed for TV back light. VF here in TV don't play any roll. but current yes and this why we have 0.5W- 1W-2W etc and all of those use 12V for example
                          "VF here in TV don't play any roll" What do you mean Vf of LED does not play any roll?
                          OP just have to use his meter in diode mode and report what the Vf shows on the meter. If is is single 3V LED it should show something on his meter in diode mode.Why just not wait and find out the result from OP?
                          BTW, my FLUKE 87 uses 9V Battery, in Diode mode it has open circuit of 3.50VDC, and 1mA (shorted current).
                          • Diah
                            • Feb 2013
                            • 6358
                            budm.. sorry to say you still don't have the deep understanding of LED in General and how it built with LID and Ziner D on opposite direction.
                            volts had nothings to do... only current CURRENT .. go back refer to yours attached pdf.. where are the VF ? and how it calculated with current forward.
                            many years ago i posted here complete post on General TV LED back light edge and direct one. sorry .. if you believe what you write here VF volt forward...o say.. its wrong and i should correct it with my respect to yours knowledge
                              Sorry I am just too stupid to understand that you have to have enough Voltage potential on the semiconductor to bias it on for it to start conducting current. BTW, you use curve tracer before, correct?
                              BTW, I only from 1978 ~ 1986 at Fairchild Semiconductor Discrete Division which makes Transistor, MOSFET, Diode, and LED.
                              Please look at the VF/If chart of the LG spec I provided.
                              • Mcologist
                                • Jan 2019
                                • 20
                                I measured the voltage on the LED connector on the power board and am getting 252V so drop across all 50 LEDs would be about 5v each. Diah is correct in his answer of 4.7V or 6V LED's I believe.
                                  252V reading with ref. to chassis GND and working LED in place? I thought you have bad LEDs so the LED string does not light up. It is always best to verify.
                                  BTW, most power supply board will have Voltage chart showing the Voltage and current rating for each outputs.
                                    BTW, what is the LCD panel number?
                                    You may want to really think about replacing just the bad LED's only or not, it is big screen so if some already went out, the other may well go bad later on, it is big panel which will be bad if you have to take it apart aging if some other LED's go out. They drive those LED at the max rating without good thermal management.
                                    • Mcologist
                                      • Jan 2019
                                      • 20
                                      Measured the voltage with the bad LEDs in place as they are failed open. And the only voltage chart is for the main board power connector this brand seems bad with their marking and obviously their engineering as the tv is not very old. I'm planning to just replace the two burnt out LEDs and apply thermal paste to the back of the strips to help transfer the heat better to the back panel of the tv.
                                        That is why you are getting 252V because there is no load due to open circuit, that is how it will react when no load is present for constant current power supply source.
                                        Can we see good clear pictures of the power supply/LED driver board?
                                        How many are there on the LED connector?
                                        LCD panel number?
                                        BTW what does it show on your meter when you check 1 LED with your meter in diode mode?
                                        If you look at the LED Vf VS If I porvided for the LG LED, Vf is a 6.5V at 175mA so total Vf of the LED string (if all 50 LED's are connected in series o form one large LED string) will be 6.5V x 50 LED's = 325V + the Vdrops on the PWM Control MOSFET on the low side for maintaining constant current (25 ~ 30V is typical, it will vary with the current) and on the current sensing resistor.
                                        LED strip P/N CRH-K55EMD30301005684
                                        https://www.shopjimmy.com/haier-crh-...-strips-10.htm
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
