LG 50lf580v stuck on start up logo
  • sordids999
    • May 2013
    • 2158
    Hi
    Has anyone come across this fault before the tv turns on but it's stuck on lg logo
  • CapLeaker
    Leaking Member
    • 8325
    Re: LG 50lf580v stuck on start up logo
    corrupted flash, bad spi or eeprom.
    • sordids999
      • May 2013
      • 2158
      What's my options new main board ?
      • CapLeaker
        Leaking Member
        • 8325
        depends what you got or what you can get. Maybe you can buy just a eeprom preprogrammed, so you'd just have to swap it out. OR a new main board. You can try to freeze the eeprom with a can of air upside down, then turn the TV on. See if it will boot all the way. If you have a programmer (something like a TL866 or similar) you can purchase a replacement eeprom, look for a dump file for this TV and do up a epprom yourself. I did look around on the quick for a dump file, but couldn't find one for this particular TV.
        • Diah
          • Feb 2013
          • 6435
          when eeprom spi flash turn on and send script 3.3 V to PSU to start. this issue never being fault at eeprom or spi. as its run and give signal. the next will be the Soc handle to load its firmware. and those not at eeprom.
          in short this issue BGA on Soc or firmware. which easy to reset it in LG with INSTOP command if the tv response to RC if not then upgrade can be done or the INSTOP via UART to send.
          • CapLeaker
            Leaking Member
            • 8325
            EEPROM: https://www.shopjimmy.com/sanyo-fw65...eprom-only.htm
            IMPORTANT:
            These main boards can have multiple failures, in addition to the EEPROM.
            If EEPROM replacement does not repair your board, there are likely additional problems.
            Symptoms EEPROM replacement MAY fix:
            - On screen display is stuck on logo screen
            - TV won’t power on with remote or buttons (LED indicator remains same color)
            - TV won’t turn on after being off for 30+ minutes
            - TV shuts off by itself during channel scan or when switching inputs
            - TV turns on and is stuck in color test pattern mode forever
            - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)
            • Diah
              • Feb 2013
              • 6435
              IMPORTANT:
              - TV won't power on with remote or buttons (LED indicator remains same color)
              - TV won't turn on after being off for 30+ minutes
              hahah i cant see SJ here but its so nice to add this at first point - On screen display is stuck on logo screen...
              other points are correct belong to SPI
              • CapLeaker
                Leaking Member
                • 8325
                got no VPN? Geez...
                • Diah
                  • Feb 2013
                  • 6435
                  no need vpn sj its yours sources not here.. i don't need it
                    • 12269
                    • U.S.
                    So what's the verdict, it's NEVER the eeprom or it is the eeprom?
                    • CapLeaker
                      Leaking Member
                      • 8325
                      I am not saying that Diah is totally wrong. There are instances where a simple reflow of the main IC causes the TV to work again, BUT yet Samsungs do fail stuck on the start up screen and it was the eeprom causing the issue. I know this is an LG, but "it could be an eeprom issue" to me remains.
                      All I say is this: Never say Never!
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        app for lg remote with instop (re post 5)
                        • benqx80
                          • May 2015
                          • czech republic
                          Good day,
                          power you all present please
                          Does anyone have a dump to EEPROM and SPI flash for this TV?
                          I can't find her anywhere
                          • x_orange90_x
                            Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                            by x_orange90_x
                            I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                            12-28-2023, 06:26 AM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
                          • justice171
                            JVC LT-50N795 Stuck on Wisdom Share Logo
                            by justice171
                            I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                            It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                            Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                            Thanks in advance!
                            11-04-2024, 02:55 AM
                          • mr.Data
                            Macbook A1990 stuck on logo
                            by mr.Data
                            This Macbook Pro 2018 boots up and then gets stuck on the logo.
                            All the normal methods of resetting this Macbook have been tried but do not work.
                            I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                            Any help would be greatly appriciated....
                            04-18-2024, 11:51 PM
                          • platinumsteel
                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                            by platinumsteel
                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                            03-18-2024, 05:16 PM
